WSUS Not Syncronizing, Not Connecting & Not There after attempting movecontent. Need Help.
  • Hello, I have been working on this issue for about a week now with no success and I'm at a loss.
    I am running a SBS 2013 Standard server with WSUS 3.0, nothing fancy
    I ran the Move Windows Update Repository Data utility from within the Standard Console to move WSUS data from E:\ to D:\
    This went fine.
    Shortly after I realized that I wanted the data back to where it came from on E:\
    I ran the utility again and received and error: The WSUS repository location cannot be set
    I then tried to run wsusutil.exe movecontent E:\WSUS\ E:\move.log from the command prompt.
    This is when I received: Fatal Error: The WSUS synchronization service <WsusService> cannon be stopped
    I rebooted the server and tried using the utility getting the same error and then the command getting the same error.
    In the Update Services mmc It tries connecting to the server and after a few minutes it gives me: Error: Connection Error. An error occurred trying to connect the WSUS server. The error can happen for a number of reasons. Check connectivity with the server.
    In Application Event Viewer Im getting Error 7053 and Warning 7032
    I looked in the SoftwareDistribution.log file but there are literally hundreds of lines and there are many many errors but I am not sure what they mean.
    Yesturday I ran wsusutil.exe reset for the first time but it does nothing. It simply goes right back to the prompt with no message of any kind.
    Please any advice and I would be very greatful. I am totally confused.
    Is it time to completely try and remove WSUS and reinstall?
    gam
    Tuesday, August 27, 2013 2:06 PM
  • Can you please post the logs so we can have a look? If it is very long you can use a site like www.pastebin.com and post a link here.
    Tuesday, August 27, 2013 5:17 PM
  • Thanks Ben,
    I have been working for abount an hour now trying to get the SoftwareDistribution.log file up to PasteBin so I can send a link but I'm not having a heck of a lot of luck at this point. Perhaps I will have to do it in a few different files. I will figure it out and I will have it linked soon.
    Thank you again
    gam
    Tuesday, August 27, 2013 6:45 PM
  • How big is the log file? Maybe you can take the most recent lines from the log file and supply more if we need it.
    Tuesday, August 27, 2013 7:13 PM
  • OK that is what I will try because the file is over 3,000 pages long and even broken up by day PasteBin is telling me I have exceeded the allowable file size (each day is between 350 and 800 pages). Ill break it up into even smaller sections.
    The issue started on 08-23-2013 so here is the point where I believe I ran into problems. The file prior to this point had no errors of any kind.
    http://pastebin.com/kKvSs3DK
    Here is a section further down on the 23rd
    http://pastebin.com/UBz2FPCr
    Here is a section from the end of the 23rd
    http://pastebin.com/rjgh8MtB
    Here is the beginning of the 24th
    http://pastebin.com/SacTZtRQ
    Here is the beginning of the 25th
    http://pastebin.com/MKsruPzi
    Here is the beginning of the 26th
    http://pastebin.com/bWU1xCg5
    Here is the beginning of the 27th.
    http://pastebin.com/bafeCCNG
    Also, here is a link to the move.log file from the movecontent command
    http://pastebin.com/5ax9U850
    Please let me know if you need anything else. Thank you again for any assistance you can give me.
    gam
    Wednesday, August 28, 2013 1:50 PM
  • Is there anybody who can give me some advice. Even just "Your screwed" would be helpful. Anything would help.
    I tried posting another question on this same subject here and I got the same result. I was asked a couple of questions and then the person just stopped responding. No reccomendations.
    Does anybody have any ideas. Thank you
    gam
    Thursday, August 29, 2013 1:12 PM
