WSUS problem connection
    질문
  • Hello,
    I have wsus integrated with sccm. When i opened the console of WSUS i see this error:
    The WSUS administration console was unable to connect to the WSUS Server via the remote API.
    Verify that the Update Services service, IIS and SQL are running on the server. If the problem persists, try restarting IIS, SQL, and the Update Services Service.
    The WSUS administration console has encountered an unexpected error. This may be a transient error; try restarting the administration console. If this error persists,
    Try removing the persisted preferences for the console by deleting the wsus file under %appdata%\Microsoft\MMC\.
    System.IO.IOException -- The handshake failed due to an unexpected packet format.
    Source
    System
    Stack Trace:
       at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)
       at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)
       at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest)
       at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult)
       at System.Threading.ExecutionContext.runTryCode(Object userData)
       at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
       at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
       at System.Net.TlsStream.ProcessAuthentication(LazyAsyncResult result)
       at System.Net.TlsStream.Write(Byte[] buffer, Int32 offset, Int32 size)
       at System.Net.PooledStream.Write(Byte[] buffer, Int32 offset, Int32 size)
       at System.Net.ConnectStream.WriteHeaders(Boolean async)
    ** this exception was nested inside of the following exception **
    System.Net.WebException -- The underlying connection was closed: An unexpected error occurred on a send.
    Source
    Microsoft.UpdateServices.Administration
    Stack Trace:
       at Microsoft.UpdateServices.Administration.AdminProxy.CreateUpdateServer(Object[] args)
       at Microsoft.UpdateServices.Administration.AdminProxy.GetUpdateServer(String serverName, Boolean useSecureConnection, Int32 portNumber)
       at Microsoft.UpdateServices.UI.AdminApiAccess.AdminApiTools.GetUpdateServer(String serverName, Boolean useSecureConnection, Int32 portNumber)
       at Microsoft.UpdateServices.UI.SnapIn.Scope.ServerSummaryScopeNode.GetUpdateServer(PersistedServerSettings settings)
       at Microsoft.UpdateServices.UI.SnapIn.Scope.ServerSummaryScopeNode.ConnectToServer()
       at Microsoft.UpdateServices.UI.SnapIn.Scope.ServerSummaryScopeNode.ConnectToServerAndPopulateNode(Boolean connectingServerToConsole)
       at Microsoft.UpdateServices.UI.SnapIn.Scope.ServerSummaryScopeNode.OnExpandFromLoad(SyncStatus status)
    i tried restarting the server and all the services but doesnt work!!!
    any ideas'?
    thanks
    2013년 7월 12일 금요일 오후 8:50
답변
모든 응답
