Problem with 0x0000007b
    السؤال
    my software: Windows 2008 R2 Ent
    my hardware: vmware virtual machines, scsi controller: paravirtual
    what's the history:
    I have two virtual machines with Windows 2008 Std R2 on them. They are the same (same hardware, software, history) so from now on to the point where they differ I will describe only one of them.
    About two months earlier I've installed Windows on them. They had one virtual disk, so it had to be partitioned to parts. It wasn't the best solution so we decided to put the partitions to single disks, so we could extend the partitions along with disks with no decrease in performance. In that time the server were used in production environment so the reinstallation wasn't an option. There were 6 partitions, so we attached 5 new disks to machine (one disk for both 100MB reserved and system partitions, the rest was mapped 1-1). We created RAID1 for each partition and disk. After RAID resynchronization server was shutdown, the main disk with all the partitions was disconnected and the serwer was started up. Obviously it used secondary plex, but was working fine.
    Two weeks ago, decision was made to upgrade Windows to Enterprise version.
    Upgrade was made with command:
    Dism /online /Set-Edition:ServerEnterprise /ProductKey:489J6-VHDMP-X63PK-3K798-CPX3Y
    It worked and server restarted with no problems.
    Minutes later I needed to shutdown the server to change some settings on vmware side. The "memory hotplug" and "cpu hotadd" settings were turned on. The the problem occured for the first time.
    what's the problem:
    After changes in vmware the server gets 0x0000007b BSOD during boot time. We've noticed that the only way to boot system was to use "Last Known Good Configuration" option. After that it is possible to shutdown and startup server with standard options couple times(variable number), but after that it gets 0x0000007b again and needs to start with "Last Known Good Configuration".
    Turning off "memory hotplug" and "cpu hotadd" didn't fixed the thing.
    Now, where the servers differ:
    To leave the production servers to production decision was made to create copies of both machines including the system disks only. On those copies one server behaves just like the original one (possible 0x0000007b), the other one gets 0x0000007b all the time, no matter what boot options are chosen.
    We've tried installing hotfix http://support.microsoft.com/kb/2344941 , but after installing it on the "working" machine copy,
    we get 0x0000007b all the time.
    Any suggestions how to repair the system or what is the cause of the problem?
    Cheers,
    dimongoo
    • تم التحرير بواسطة dimongoo 18/شعبان/1432 02:15 م
    18/شعبان/1432 11:10 ص
الإجابات
    I found solution to the problem, no need to contact Microsoft CSS. After using RAID1 the disks where dynamic. Probably after disconnecting the main disk, and then doing licence upgrade cause some inconsistency in LDM database. I converted all disks from dynamic to simple and it worked beautifully.
    The only problem I'm facing now is that with appropriate licence(Enterprise) key the system gets activated properly but it uses only 1CPU, 4GB and cannot RDP to server. When it's disacctivated there's no problem.
    • تم وضع علامة كإجابة بواسطة dimongoo 19/رمضان/1432 08:01 ص
    • تم التحرير بواسطة dimongoo 20/شوال/1433 09:36 ص
جميع الردود
  • Hello,
    bug check code 0x7F: http://msdn.microsoft.com/en-us/library/ff559244(VS.85).aspx
    Please use Microsoft Skydrive to upload dump files (c:\windows\minidumps). Once done, post a link here.
    You can also contact Microsoft CSS.
    This posting is provided "AS IS" with no warranties or guarantees , and confers no rights.
    Microsoft Student Partner 2010 / 2011
    Microsoft Certified Professional
    Microsoft Certified Systems Administrator: Security
    Microsoft Certified Systems Engineer: Security
    Microsoft Certified Technology Specialist: Windows Server 2008 Active Directory, Configuration
    Microsoft Certified Technology Specialist: Windows Server 2008 Network Infrastructure, Configuration
    Microsoft Certified Technology Specialist: Windows Server 2008 Applications Infrastructure, Configuration
    Microsoft Certified Technology Specialist: Windows 7, Configuring
    Microsoft Certified IT Professional: Enterprise Administrator
    18/شعبان/1432 12:15 م
  • Please provide you VM environment version, I have seen this on ESX3 and ESX4 where you have the old VM Client tools installed.
    18/شعبان/1432 01:28 م
    environment version  ESX4.1
    all of possible dumping options:
    - Kernel dump
    - Mini memory dump
    - Memory dumps
    are not working. Moreover, after changing dumping option, I always get BSOD. As usual Last Known Working Configuration, allows me to boot system and the dumping option is set as it was before changing.
    As addition I include boot log:
    Microsoft (R) Windows (R) Version 6.1 (Build 7600)
     7  1 2011 15:50:46.328
    Loaded driver \SystemRoot\system32\ntoskrnl.exe
    Loaded driver \SystemRoot\system32\hal.dll
    Loaded driver \SystemRoot\system32\kdcom.dll
    Loaded driver \SystemRoot\system32\mcupdate_GenuineIntel.dll
    Loaded driver \SystemRoot\system32\PSHED.dll
    Loaded driver \SystemRoot\system32\CLFS.SYS
    Loaded driver \SystemRoot\system32\CI.dll
    Loaded driver \SystemRoot\system32\DRIVERS\sacdrv.sys
    Loaded driver \SystemRoot\system32\DRIVERS\NDIS.SYS
    Loaded driver \SystemRoot\system32\DRIVERS\msrpc.sys
    Loaded driver \SystemRoot\system32\DRIVERS\NETIO.SYS
    Loaded driver \SystemRoot\system32\drivers\Wdf01000.sys
    Loaded driver \SystemRoot\system32\drivers\WDFLDR.SYS
    Loaded driver \SystemRoot\system32\DRIVERS\ACPI.sys
    Loaded driver \SystemRoot\system32\DRIVERS\WMILIB.SYS
    Loaded driver \SystemRoot\system32\DRIVERS\msisadrv.sys
    Loaded driver \SystemRoot\system32\DRIVERS\pci.sys
    Loaded driver \SystemRoot\system32\DRIVERS\vdrvroot.sys
    Loaded driver \SystemRoot\System32\drivers\partmgr.sys
    Loaded driver \SystemRoot\system32\DRIVERS\compbatt.sys
    Loaded driver \SystemRoot\system32\DRIVERS\BATTC.SYS
    Loaded driver \SystemRoot\system32\DRIVERS\volmgr.sys
    Loaded driver \SystemRoot\System32\drivers\volmgrx.sys
    Loaded driver \SystemRoot\system32\DRIVERS\intelide.sys
    Loaded driver \SystemRoot\system32\DRIVERS\PCIIDEX.SYS
    Loaded driver \SystemRoot\System32\drivers\mountmgr.sys
    Loaded driver \SystemRoot\system32\DRIVERS\atapi.sys
    Loaded driver \SystemRoot\system32\DRIVERS\ataport.SYS
    Loaded driver \SystemRoot\system32\DRIVERS\pvscsi.sys
    Loaded driver \SystemRoot\system32\DRIVERS\storport.sys
    Loaded driver \SystemRoot\system32\DRIVERS\amdxata.sys
    Loaded driver \SystemRoot\system32\drivers\fltmgr.sys
    Loaded driver \SystemRoot\System32\Drivers\Ntfs.sys
    Loaded driver \SystemRoot\System32\Drivers\ksecdd.sys
    Loaded driver \SystemRoot\System32\Drivers\cng.sys
    Loaded driver \SystemRoot\System32\drivers\pcw.sys
    Loaded driver \SystemRoot\System32\Drivers\Fs_Rec.sys
    Loaded driver \SystemRoot\System32\Drivers\ksecpkg.sys
    Loaded driver \SystemRoot\System32\drivers\tcpip.sys
    Loaded driver \SystemRoot\System32\drivers\fwpkclnt.sys
    Loaded driver \SystemRoot\system32\DRIVERS\vmstorfl.sys
    Loaded driver \SystemRoot\system32\DRIVERS\volsnap.sys
    Loaded driver \SystemRoot\System32\Drivers\spldr.sys
    Loaded driver \SystemRoot\System32\Drivers\mup.sys
    Loaded driver \SystemRoot\System32\drivers\hwpolicy.sys
    Loaded driver \SystemRoot\system32\DRIVERS\disk.sys
    Loaded driver \SystemRoot\system32\DRIVERS\CLASSPNP.SYS
    Loaded driver \SystemRoot\system32\DRIVERS\cdrom.sys
    Loaded driver \SystemRoot\System32\Drivers\Null.SYS
    Loaded driver \??\C:\Program Files\VMware\VMware Tools\vmrawdsk.sys
    Loaded driver \SystemRoot\System32\drivers\vga.sys
    Loaded driver \SystemRoot\System32\DRIVERS\RDPCDD.sys
    Loaded driver \SystemRoot\system32\drivers\rdpencdd.sys
    Loaded driver \SystemRoot\system32\drivers\rdprefmp.sys
    Loaded driver \SystemRoot\System32\Drivers\Msfs.SYS
    Loaded driver \SystemRoot\System32\Drivers\Npfs.SYS
    Loaded driver \SystemRoot\system32\DRIVERS\tdx.sys
    Loaded driver \SystemRoot\system32\drivers\afd.sys
    Loaded driver \SystemRoot\System32\DRIVERS\netbt.sys
    Loaded driver \SystemRoot\system32\drivers\ws2ifsl.sys
    Loaded driver \SystemRoot\system32\DRIVERS\wfplwf.sys
    Loaded driver \SystemRoot\system32\DRIVERS\pacer.sys
    Loaded driver \SystemRoot\system32\DRIVERS\netbios.sys
    Loaded driver \SystemRoot\system32\DRIVERS\serial.sys
    Loaded driver \SystemRoot\system32\DRIVERS\wanarp.sys
    Loaded driver \SystemRoot\system32\DRIVERS\termdd.sys
    Loaded driver \SystemRoot\system32\DRIVERS\rdbss.sys
    Loaded driver \SystemRoot\system32\drivers\nsiproxy.sys
    Loaded driver \SystemRoot\system32\DRIVERS\mssmbios.sys
    Loaded driver \SystemRoot\System32\drivers\discache.sys
    Loaded driver \SystemRoot\System32\Drivers\dfsc.sys
    Loaded driver \SystemRoot\system32\DRIVERS\blbdrive.sys
    Loaded driver \SystemRoot\system32\DRIVERS\tunnel.sys
    Loaded driver \SystemRoot\system32\DRIVERS\i8042prt.sys
    Loaded driver \SystemRoot\system32\DRIVERS\kbdclass.sys
    Loaded driver \SystemRoot\system32\DRIVERS\vmmouse.sys
    Loaded driver \SystemRoot\system32\DRIVERS\mouclass.sys
    Loaded driver \SystemRoot\system32\DRIVERS\parport.sys
    Loaded driver \SystemRoot\system32\DRIVERS\serenum.sys
    Loaded driver \SystemRoot\system32\DRIVERS\fdc.sys
    Loaded driver \SystemRoot\system32\DRIVERS\vmci.sys
    Loaded driver \SystemRoot\system32\DRIVERS\vgapnp.sys
    Loaded driver \SystemRoot\system32\DRIVERS\vmxnet3n61x64.sys
    Loaded driver \SystemRoot\system32\DRIVERS\CmBatt.sys
    Loaded driver \SystemRoot\system32\DRIVERS\intelppm.sys
    Loaded driver \SystemRoot\system32\DRIVERS\CompositeBus.sys
    Loaded driver \SystemRoot\system32\DRIVERS\AgileVpn.sys
    Loaded driver \SystemRoot\system32\DRIVERS\rasl2tp.sys
    Loaded driver \SystemRoot\system32\DRIVERS\ndistapi.sys
    Loaded driver \SystemRoot\system32\DRIVERS\ndiswan.sys
    Loaded driver \SystemRoot\system32\DRIVERS\raspppoe.sys
    Loaded driver \SystemRoot\system32\DRIVERS\raspptp.sys
    Loaded driver \SystemRoot\system32\DRIVERS\rassstp.sys
    Loaded driver \SystemRoot\system32\DRIVERS\rdpbus.sys
    Loaded driver \SystemRoot\system32\DRIVERS\swenum.sys
    Loaded driver \SystemRoot\system32\DRIVERS\umbus.sys
    Loaded driver \SystemRoot\system32\DRIVERS\flpydisk.sys
    Loaded driver \SystemRoot\System32\Drivers\NDProxy.SYS
    Did not load driver \SystemRoot\System32\Drivers\NDProxy.SYS
    Loaded driver \SystemRoot\system32\DRIVERS\udfs.sys
    Loaded driver \SystemRoot\system32\DRIVERS\monitor.sys
    Loaded driver \SystemRoot\system32\drivers\luafv.sys
    Loaded driver \SystemRoot\system32\DRIVERS\lltdio.sys
    Loaded driver \SystemRoot\system32\DRIVERS\rspndr.sys
    Loaded driver \SystemRoot\system32\DRIVERS\bowser.sys
    Loaded driver \SystemRoot\System32\drivers\mpsdrv.sys
    Loaded driver \SystemRoot\system32\DRIVERS\mrxsmb.sys
    Loaded driver \SystemRoot\system32\DRIVERS\mrxsmb10.sys
    Loaded driver \SystemRoot\system32\DRIVERS\mrxsmb20.sys
    Loaded driver \SystemRoot\system32\drivers\HTTP.sys
    Loaded driver \??\C:\Program Files\VMware\VMware Tools\Drivers\memctl\vmmemctl.sys
    Loaded driver \SystemRoot\system32\drivers\npf.sys
    Loaded driver \SystemRoot\system32\drivers\peauth.sys
    Loaded driver \SystemRoot\System32\Drivers\secdrv.SYS
    Loaded driver \SystemRoot\System32\DRIVERS\srvnet.sys
    Loaded driver \SystemRoot\System32\drivers\tcpipreg.sys
    Loaded driver \SystemRoot\System32\DRIVERS\srv2.sys
    Loaded driver \SystemRoot\System32\DRIVERS\srv.sys
    Did not load driver \SystemRoot\System32\DRIVERS\srv.sys
    Loaded driver \SystemRoot\System32\Drivers\fastfat.SYS
    Loaded driver \SystemRoot\System32\drivers\rdpdr.sys
    Loaded driver \SystemRoot\system32\drivers\tdtcp.sys
    Loaded driver \SystemRoot\System32\DRIVERS\tssecsrv.sys
    Loaded driver \SystemRoot\System32\Drivers\RDPWD.SYS
    18/شعبان/1432 02:08 م
  • Is there a file named MEMORY.DMP under c:\windows\? If yes, upload it. Are you sure that there is no files under c:\windows\minidumps?
    18/شعبان/1432 02:38 م
  • As I wrote earlier, none of dumping options worked, ergo there is no memory.dmp in c:\windows\.
    • تم التحرير بواسطة dimongoo 18/شعبان/1432 02:48 م
    18/شعبان/1432 02:44 م
  • Then try all resolutions mentioned in the article I gave. Also, disable all security softwares and update all possible drivers. If this does not help, it is possible that you have a hardware problem (especially with your processor). In this case, it will be better to contact Microsoft CSS.
    Also, don't forget to uninstall all programs that you don't need.
