get-module not listing out failoverclusters module when CreateProcess() or system() called
    I need to use FailoverClsuters module realted cmdlet, so I installed FailoverCluster feature(I logged in through domain\admin account) on my machine and then verified get-module -list the module and import-module FailoverClusters also success through PoweShell window.
    >get-module
    ModuleType Name                      ExportedCommands
    Manifest   ADRMS                     {}
    Manifest   AppLocker                 {}
    Manifest   BestPractices             {}
    Manifest   BitsTransfer               {}
    Manifest   FailoverClusters         {}
    Manifest   PSDiagnostics            {Enable-PSTrace,...}
    Manifest   ServerManager          {}
    Manifest   TroubleshootingPack   {}
    Strangely, when I tried calling the same thing in system() /CreateProcess () it list only the below modules(FailoverClusters module is missing):
    // system("powershell.exe get-module")
    Manifest   PSDiagnostics             {}
    I'm having the following execution policy set on my machine:
               Scope                                             ExecutionPolicy
       MachinePolicy                                                   Undefined
          UserPolicy                                                   Undefined
             Process                                                   Undefined
         CurrentUser                                                   Undefined
        LocalMachine                                                RemoteSigned
    Any reasons why I'm not able to get/load the FailoverClusters module?
    Thanks in advance,
    Arjun.R
    Before software can be reusable; it first has to be usable.
    • Edited by Arjun R Thursday, August 13, 2009 4:52 AM
    Thursday, August 13, 2009 4:16 AM
  • I am not sure if this has been answered. But still i would share my thoughts for others.
    First, to answer your question
    Your application is an X86 application and in that case when you launch powershell.exe it launches x86 version of powershell. FailoverClusters module is not availabel for x86 arc and thats the reason you do not see the FailoverClusters module. If you convert you application to buid for x64 it will work.
    Well I am not sure what you want to do , but i do want to point out that imported modules are available per session and for every commandlet that you want to call, you will have to first import the module and then run the cmdlet. I would suggest writing you application in managed language where you can actually write a powershell hosting application using PowerShell SDK.
    Tuesday, June 08, 2010 6:26 PM
  • These are features available with R2, so you should really post this here:
    http://social.technet.microsoft.com/Forums/en-US/windowsserver2008r2management/threads
    This is interesting, can you provide more sample code?  If not, I can manage on my own, but it will take me a few days (likely next week) before I can get to it.
    Thursday, August 13, 2009 11:38 AM
    Here is the code what I used:
    int _tmain(int argc, _TCHAR* argv[]) { STARTUPINFO si; PROCESS_INFORMATION pi; LPTSTR szCmdline=_tcsdup(TEXT("powershell.exe get-module -listavailable")); int iRet = 0; ZeroMemory( &si, sizeof(si) ); si.cb = sizeof(si); ZeroMemory( &pi, sizeof(pi) ); // Start the child process. if( !CreateProcess( NULL, // No module name (use command line) szCmdline, // Command line NULL, // Process handle not inheritable NULL, // Thread handle not inheritable FALSE, // Set handle inheritance to FALSE 0, // No creation flags NULL, // Use parent's environment block NULL, // Use parent's starting directory &si, // Pointer to STARTUPINFO structure &pi ) // Pointer to PROCESS_INFORMATION structure ) { printf( "CreateProcess failed (%d).\n", GetLastError() ); return 0; } // Wait until child process exits. WaitForSingleObject( pi.hProcess, INFINITE ); // Close process and thread handles. CloseHandle( pi.hProcess ); CloseHandle( pi.hThread ); return 0; }
    Thanks,
    Arjun.R
    Monday, August 17, 2009 3:54 AM
    I suggest that you initial a new post in the MSDN form to get further support there. They are the best resource for development related problems.
    For your convenience, I have list the link as followed.
    MSDN Forum
    http://forums.microsoft.com/MSDN/default.aspx?SiteID=1
    Thanks.
    Monday, August 17, 2009 10:02 AM
  • I don't have any skills at all in C...  Do you get an error returned if you try to manually load one of the modules that isn't listed?
    I'll try this from C# tomorrow to compare.
    Tuesday, August 18, 2009 1:38 AM
  • I got below error when: system("powershell.exe import-module failoverclusters") is called:
    Import-Module : The specified module 'failoverclusters' was not loaded because
    no valid module file was found in any module directory.
    At line:1 char:14
    + import-module <<<<  failoverclusters
        + CategoryInfo          : ResourceUnavailable: (failoverclusters:String) [
       Import-Module], FileNotFoundException
        + FullyQualifiedErrorId : Modules_ModuleNotFound,Microsoft.PowerShell.Comm
       ands.ImportModuleCommand
    Tuesday, August 18, 2009 6:20 AM
    >get-module
    Manifest   ADRMS                     {}
             Process                                                   Undefined
    Thanks in advance,
    Arjun.R
    Was that just a typo above where you mention you tried "//system ("powershell get-module")"?  You realize there you are missing "-list"...
    Tuesday, August 18, 2009 1:12 PM
  • No! I used all ways it was(powershell.exe get-module / powershell.exe get-module -list ) not listing/loading all modules.
    Monday, August 24, 2009 6:24 AM
