Odd error with foreach loop - Missing statement body in foreach loop.
  • I have an array
    $array_ServerManager_WebOptions = @(
    	<#"Web-Server",							#[ ] Web Server (IIS)
    	"Web-WebServer",					#  [ ] Web Server
    	"Web-Common-Http",				#    [ ] Common HTTP Features
    	"Web-Static-Content",			#      [ ] Static Content
    	"Web-Default-Doc",				#      [ ] Default Document
    	"Web-Dir-Browsing",				#      [ ] Directory Browsing
    	"Web-Http-Errors",				#	      [ ] HTTP Errors
    	"Web-Http-Redirect",			#      [ ] HTTP Redirection
    	"Web-DAV-Publishing",			#      [ ] WebDAV Publishing
    	"Web-App-Dev",						#    [ ] Application Development
    	"Web-Asp-Net",						#      [ ] ASP.NET
    	"Web-Net-Ext",						#      [ ] .NET Extensibility
    	"Web-ASP",								#      [ ] ASP
    	"Web-CGI",								#      [ ] CGI
    	"Web-ISAPI-Ext",					#      [ ] ISAPI Extensions
    	"Web-ISAPI-Filter",				#      [ ] ISAPI Filters
    	"Web-Includes",						#      [ ] Server Side Includes
    	"Web-Health",							#    [ ] Health and Diagnostics
    	"Web-Http-Logging",				#      [ ] HTTP Logging
    	"Web-Log-Libraries",			#      [ ] Logging Tools
    	"Web-Request-Monitor",		#      [ ] Request Monitor
    	"Web-Http-Tracing",				#      [ ] Tracing
    	"Web-Custom-Logging",			#      [ ] Custom Logging
    	"Web-ODBC-Logging",				#      [ ] ODBC Logging
    	"Web-Security",						#    [ ] Security
    	"Web-Basic-Auth",					#      [ ] Basic Authentication
    	"Web-Windows-Auth",				#      [ ] Windows Authentication
    	"Web-Digest-Auth",				#      [ ] Digest Authentication
    	"Web-Client-Auth",				#      [ ] Client Certificate Mapping Authentic...
    	"Web-Cert-Auth",					#      [ ] IIS Client Certificate Mapping Authe...
    	"Web-Url-Auth",						#      [ ] URL Authorization
    	"Web-Filtering",					#      [ ] Request Filtering
    	"Web-IP-Security",				#      [ ] IP and Domain Restrictions
    	"Web-Performance",				#    [ ] Performance
    	"Web-Stat-Compression",		#      [ ] Static Content Compression
    	"Web-Dyn-Compression",		#      [ ] Dynamic Content Compression
    	"Web-Mgmt-Tools",					#  [ ] Management Tools
    	"Web-Mgmt-Console",				#    [ ] IIS Management Console
    	"Web-Scripting-Tools",		#    [ ] IIS Management Scripts and Tools
    	"Web-Mgmt-Service",				#    [ ] Management Service
    	"Web-Mgmt-Compat",				#    [ ] IIS 6 Management Compatibility
    	"Web-Metabase",						#      [ ] IIS 6 Metabase Compatibility
    	"Web-WMI",								#      [ ] IIS 6 WMI Compatibility
    	"Web-Lgcy-Scripting",			#      [ ] IIS 6 Scripting Tools
    	"Web-Lgcy-Mgmt-Console",	#      [ ] IIS 6 Management Console
    	"Web-Ftp-Server",					#  [ ] FTP Server
    	"Web-Ftp-Service",				#    [ ] FTP Service
    	"Web-Ftp-Ext",						#    [ ] FTP Extensibility
    	"Web-WHC",							#  [ ] IIS Hostable Web Core
    	$null											# $null to terminate array but leave comma pattern
    that I enumerate to log (u.wl is just an alias):
    # Log $array_ServerManager_WebOptions
    foreach($option in $array_ServerManager_WebOption)
    	"`$array_ServerManager_WebOptions: $option" | u.wl -Path C:\test\test.txt;
    " " | u.wl -Path C:\test\test.txt;
    When I execute I get this in the $Error object:
    Missing closing ')' in subexpression.
    I know that my logging function is clean.  When I run it by itself ("test" | u.wl -Path C:\test\test.txt) the $Error object remains empty.  Why would a foreach loop generate this error but a regular statement does not?  I get the same thing when I iterate through hash tables.
    Friday, July 29, 2011 5:00 AM
  • That leading < in the first array element in your example is causing the array to be null
    [string](0..33|%{[char][int](46+("686552495351636652556262185355647068516270555358646562655775 0645570").substring(($_*2),2))})-replace " "
    • Marked as answer by Will Steele Friday, July 29, 2011 7:16 PM
    Friday, July 29, 2011 1:04 PM
  • Hi Will,
    I think it will do what you want if you remove the comment from the array elements and add an "s" in front of the ")" :)
    Cheers
      Klaus
    Friday, July 29, 2011 9:02 AM
  • Yeah, I was trying to neutralize the array for testing purposes.  Didn't think it would have quite that effect.
    Friday, July 29, 2011 7:17 PM
