Not able to assign Drive Letter for System Reserved Partition in WS 2008 R2
  • Hello,
    I need to assign Drive Letter for  System Reserved Partition in WS 2008 R2. However, I am not able to do that. The options are greyed out.
    Our organisation policy says, we need to assign the Drive Letter to system reserved partitions. On other WS 2008 R2 servers, I am able to assign the drive letter but not this one.
    How do I fix this issue ?
    ~ Knowledge Seeker
    Thursday, February 09, 2012 10:19 PM
  • Well, you can assign the drive letter to Locked System Reserved Partition using DISKPART.
    Follow the instructions below
    from elevated cmd, run DISKPART
    from disk part run following commands
    DISKPART> select disk 0
    You should see the message " Disk 0 is now the selected disk."
    DISKPART> list volume
    You should see the volume listed like below
      Volume ###  Ltr  Label        Fs     Type        Size     Status     Info
      Volume 0     D                 DVD-ROM            0 B      No Media
      Volume 1     C   LocalDisk  NTFS   Partition     67 GB   Healthy    Boot
      Volume 2     E   LocalDisk  NTFS   Partition     67 GB   Healthy    Pagefile
    Volume 3                       FAT32  Partition    200 MB  Healthy    System
    Say, Volume 3 is the system partiton, you can identify that very easily as that will not haveName assigned to drives such as LocalDisk
    Now,
    DISKPART> select volume 3
    You should see the message "Volume 3 is the selected volume."
    then
    DISKPART> assign letter=Z  ( Assign any Drive letter of your choice )
    You should see the message "DiskPart successfully assigned the drive letter or mount point."
    Thats it !!!
    I tried this on my Test Server and it works. Hope that will help.
    Vote As Helpful, if you find my information useful ! This posting is provided "AS IS" with no warranties or guarantees and confers no rights.
    • Marked as answer by Jayawardhane Thursday, February 09, 2012 11:59 PM
    Thursday, February 09, 2012 11:39 PM
  • Hello,
    that system partition is required for BitLocker drive encryption and you cannot change it or add a drive letter AFAIK. If you don't like to have it you must do it during the installation and install the server without this partition.
    Best regards
    Meinolf Weber
    MVP, MCP, MCTS
    Microsoft MVP - Directory Services
    My Blog: http://msmvps.com/blogs/mweber/
    Disclaimer: This posting is provided "AS IS" with no warranties or guarantees , and confers no rights.
    Thursday, February 09, 2012 10:59 PM
  • Hello Meinolf,
    Thanks for the reply.
    In fact, System Reserved partition is needed and I would like to assign a drive letter.
    As I mentioned in my post, I have assigned drive letter to this partition on numerous other 2008 R2 servers but only on this server in question, all the options are locked out.
    For E.g.
    ~ Knowledge Seeker
    Thursday, February 09, 2012 11:09 PM
  • Hello,
    thanks for the update, nice to know this. :-)
    Any chance that there is another OS like MAC in dual boot installed? Read somewhere that could be blocking the change.
    Best regards
    Meinolf Weber
    MVP, MCP, MCTS
    Thursday, February 09, 2012 11:33 PM
    Now,
    then
    Thats it !!!
  • Hello,
    Best regards
    Meinolf Weber
    MVP, MCP, MCTS
    Answer is No. WS 2008 R2 is installed on a physical server.
    ~ Knowledge Seeker
    Thursday, February 09, 2012 11:50 PM
    Now,
    then
    Thats it !!!
    Absolutely Amazing !!! You saved my life !
    I ran the diskpart commands as suggsted and that worked for me.
    One observation though, I still can't see drive letter assigned for system Reserved Partition from Disk Management Console however, a Drive appaeared as I wanted in Computer :))
    ~ Knowledge Seeker
    • Proposed as answer by M.Bahloul Tuesday, June 18, 2013 10:50 AM
    Thursday, February 09, 2012 11:58 PM
  • Glad to know that, it worked for you.
    Friday, February 10, 2012 12:02 AM
