Errors in EVENT Application adn System!! How to fix and what are those errors?
  • Im getting those errors on my Windows Server 2003 R2 Enterprise Edition
    Application errors while tryin to run Gropu policy management management i get also these errors
    Windows cannot query DllName registry entry for {7B849a69-220F-451E-B3FE-2CB811AF94AE} and it will not be loaded. This is most likely caused by a faulty registration.
    Windows cannot query DllName registry entry for {CF7639F3-ABA2-41DB-97F2-81E2C5DBFC5D} and it will not be loaded. This is most likely caused by a faulty registration.
    For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
    SYSTEM:
    The WinHTTP Web Proxy Auto-Discovery Service service depends on the DHCP Client service which failed to start because of the following error:
    The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.
    For more information, see Help and Support Center at \
    MR
    samedi 9 juin 2012 14:19
Réponses
Toutes les réponses
