http://social.technet.microsoft.com/wiki/contents/articles/10123.troubleshooting-slow-operating-system-boot-times-and-slow-user-logons.aspx
http://social.technet.microsoft.com/wiki/contents/articles/10130.root-causes-for-slow-boots-and-logons.aspx http://social.technet.microsoft.com/wiki/contents/articles/11341.the-windows-7-boot-process-sbsl.aspx
The goal of this content is to create awareness among IT administrators, support professionals, and consultants, about the tools, cause, and resolutions for boot and user logon delays.
Written by: A. Conner, David Everett, and Joey Seifert
Edited by: Justin Hall
Table of Contents Tools Overview Installing XPERF to capture a slow boot or logon trace Using XBOOTMGR to capture slow boots, or slow logons caused by slow boots Using XPERF to capture slow logons Installing and using the SBSL SDP Manifest to capture data Configuring XPERF to view slow boot and logon traces captured with XPERF or the SBSL SDP manifest Analyzing an ETL trace with XPERFVIEW Appendix
Microsoft support had been using a collection of tools and logs including NETLOGON, USERENV and GPSVC logs, Process Monitor, NETMON traces, ETL traces (like profile and Winlogon) and memory dumps to troubleshoot slow user logons on domain-joined computers for years. In 2011, Commercial Technical Support (CTS) adopted XPERF as the primary tool in diagnosing boot and logon delays.
XPERF, also known as Windows Performance Analyzer, ships as part of the Windows Performance Tools (WPT) kit. The latest WPT ships as part of the Windows SDK for Windows 7 and .NET Framework. The WPT consists of:
XPERF provides:
The use of XPERF may lead to a more structured troubleshooting approach for slow boot and logon issues on Windows Vista and later operating systems. Once root cause is understood, XPERF typically makes the resolution of repeat issues a slam dunk. More recently, Microsoft has developed a Slow Boot Slow Logon SDP manifest which:
The SBSL SDP manifest supports Windows Vista, Windows 7, Windows Server 2008 and Windows Server 2008 R2 computers. Its primary focus is the fast and efficient collection of ETL trace data and the execution of diagnostic rules. Real-time and post-mortem diagnostic rule checks quickly expose probable and known root causes for slow boots or logons. Additional real-time and post-mortem diagnostic rules will be added to check for known root causes for slow boot and slow logon issues over time. Regardless of whether ETL trace data is captured by XPERF or the SBSL SDP, all ETL trace data is still viewed with XPERFVIEW, and the SBSL SDP wizard has an option that allows administrators to save trace data on the SBSL computer for their own review. Currently, the SBSL SDP is only available to administrators and support professionals that open a support case with Microsoft CTS. The following table compares XPERF with the SBSL SDP and with troubleshooting using logs.
Legacy logs
WPT
SBSL SDP
Capture tracing on single component
√ m
Graphical View of SBSL
√x
Rich zoom on delays| key operations
Delays aggregated across trace (CPU | Memory | Disk)
Capture NETLOGON.LOG
Capture GPSVC.LOG
Capture Event logs
Capture GPRESUT /H
Capture PROFILE.ETL
Check for known SBSL root causes
Administrators can view collected data
Automated tracing
Avoids the need to send & install XPERF to collect data
Note: “m” = manual enabled configuration change. “x” functionality provided by XPERF. The exception to using ETL trace data from XPEF or the SBSL SDP is when the logon duration is long enough that the resulting ETL trace file will be too large to read. Lead with memory dumps and, if appropriate for the scenario, network traces.
Install XPERF from the Windows SDK for Windows 7 and .NET Framework on the slow boot or logon computer. Hint 1: It is possible to install only the Windows Performance Toolkit from the Windows SDK. Hint 2: We suggest installing the WPT in an X:\XPERF directory rather than the default directory recommended by setup. It's easier to access and copy files in and out of, and change paths, to the short-labeled directory. Hint 3: Once installed on a computer, the XPERF installation directory can be copied to other computers that you want to capture ETL traces from or view ETL traces on. There are no external files, DLL registration or registry changes required to make or view a capture. Make a copy of the X:\XPERF directory and copy at will. If taking a network trace on a 64-bit computer, enable the following registry key and reboot before capturing ETL data. This prevents kernel mode data from being paged out of memory.
Registry Path
HKLM\System\CurrentControlSet\Control\Session Manager\Memory Management
Setting
DisablePagingExecutive
Data Type:
REG_DWORD
Value:
1
xperf -stop -stop UserTrace -d merged.etl
Close the slow logon user session and the admin logon session opened in step 2 as required. IMPORTANT: The double “-stop” call in step 5 is not a typo but is required. The first "-stop" terminates kernel tracing. The second "-stop" terminates user mode tracing. Trust us. Note: You can also stop the trace by using Switch User to return to the admin user logon established in step #2 and running the same XPERF stop command in the elevated command prompt used to start the trace. This results in a larger, longer trace and requires that you discern the different logons encapsulated in the trace.
Optional: Follow KB 315231 to enable automatic logon.
Regardless of whether you used the SBSL SDP, XBOOTMGR or XPERF, the resulting ETL trace file is viewed with XPERF or XPERFVIEW. Since there is configuration work associated with viewing XPERF traces, you’ll probably want to install XPEF on a dedicated tools machine that will stay around for a while. Also, XPERF uses memory mapped files so the computer that you use to view XPERF traces needs to have free memory equal to the file size of the ETL files being viewed.
setx
_NT_SYMBOL_PATH
srv*c:\SymcachePublic*http://msdl.microsoft.com/download/symbols;srv*c:\SymcachePublic*http://ctxsym.citrix.com/symbols
setx _NT_SYMCACHE_PATH c:\xperfSymcachePublic
Much like viewing a network monitor or a stack dump, viewing an XPERF is one part detective work, one part Windows internals knowledge. Here’s a generic workflow that the CTS SBSL team uses to view an XPERF trace.
XPERF Pane
What to look for
CPU
Disk
Network
TCP/IP Throughput
Services
Readyboot
Winlogon
Generic events
CPU Scheduling with Ready Thread Summary Table
Delays are typically exposed by:
<start copy here> Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows Performance Analyzer\v4\XPerfView]
[HKEY_CURRENT_USER\Software\Microsoft\Windows Performance Analyzer\v4\XPerfView\Graphs] "Stack Counts by Type"=dword:00000001 "CPU Sampling by Process"=dword:00000001 "CPU Sampling by Thread"=dword:00000001 "CPU Usage by CPU"=dword:00000001 "CPU Usage by Process"=dword:00000001 "CPU Usage by Thread"=dword:00000001 "CPU Scheduling"=dword:00000001 "File I/O"=dword:00000001 "Disk Utilization by Process"=dword:00000001 "DPC CPU Usage"=dword:00000000 "Interrupt CPU Usage"=dword:00000000 "Hard Faults"=dword:00000000 "Boot Phases"=dword:00000001 "Marks"=dword:00000000
[HKEY_CURRENT_USER\Software\Microsoft\Windows Performance Analyzer\v4\XPerfView\Settings] "Flags"=dword:00000000
[HKEY_CURRENT_USER\Software\Microsoft\Windows Performance Analyzer\v4\XPerfView\Tables]
[HKEY_CURRENT_USER\Software\Microsoft\Windows Performance Analyzer\v4\XPerfView\Tables\CPU Scheduling with Ready Thread Summary Table] "<Current>"=hex:40,29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,0c,\ 00,00,00,b4,00,00,00,00,00,00,00,4e,00,65,00,77,00,50,00,72,00,6f,00,63,00,\ 65,00,73,00,73,00,20,00,4e,00,61,00,6d,00,65,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,0d,00,00,00,66,00,00,00,01,00,00,00,4e,00,65,00,\ 77,00,50,00,72,00,6f,00,63,00,65,00,73,00,73,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,90,\ 29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,01,00,00,00,02,00,00,00,3b,00,\ 00,00,01,00,00,00,4e,00,65,00,77,00,54,00,68,00,72,00,65,00,61,00,64,00,49,\ 00,64,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,0e,00,00,00,ff,01,00,00,01,00,00,00,4e,00,65,00,77,00,54,00,68,\ 00,72,00,65,00,61,00,64,00,53,00,74,00,61,00,63,00,6b,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,10,00,00,00,b4,00,00,00,00,00,00,\ 00,52,00,65,00,61,00,64,00,79,00,69,00,6e,00,67,00,50,00,72,00,6f,00,63,00,\ 65,00,73,00,73,00,20,00,4e,00,61,00,6d,00,65,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,80,2a,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,17,\ 00,00,00,49,00,00,00,01,00,00,00,53,00,77,00,69,00,74,00,63,00,68,00,49,00,\ 6e,00,54,00,69,00,6d,00,65,00,20,00,28,00,73,00,29,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,11,00,00,00,4c,00,00,00,01,00,00,00,52,00,65,00,\ 61,00,64,00,79,00,69,00,6e,00,67,00,50,00,72,00,6f,00,63,00,65,00,73,00,73,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,a0,\ 29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,12,00,00,00,53,00,\ 00,00,01,00,00,00,52,00,65,00,61,00,64,00,79,00,69,00,6e,00,67,00,54,00,68,\ 00,72,00,65,00,61,00,64,00,49,00,64,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,0f,00,00,00,55,00,00,00,01,00,00,00,52,00,65,00,61,00,64,00,79,\ 00,54,00,68,00,72,00,65,00,61,00,64,00,53,00,74,00,61,00,63,00,6b,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,80,2a,1e,70,00,00,\ 00,00,01,00,00,00,00,00,00,00,00,00,00,00,14,00,00,00,78,00,00,00,00,00,00,\ 00,52,00,65,00,61,00,64,00,79,00,54,00,69,00,6d,00,65,00,20,00,28,00,73,00,\ 29,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,10,29,1e,70,00,00,00,00,01,00,00,00,03,00,00,00,00,00,00,00,15,\ 00,00,00,29,00,00,00,01,00,00,00,43,00,6f,00,75,00,6e,00,74,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,20,2a,1e,70,00,00,00,00,01,00,00,\ 00,02,00,00,00,02,00,00,00,03,00,00,00,78,00,00,00,00,00,00,00,53,00,75,00,\ 6d,00,3a,00,54,00,69,00,6d,00,65,00,53,00,69,00,6e,00,63,00,65,00,4c,00,61,\ 00,73,00,74,00,20,00,28,00,75,00,73,00,29,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,20,\ 2a,1e,70,00,00,00,00,01,00,00,00,05,00,00,00,02,00,00,00,04,00,00,00,78,00,\ 00,00,00,00,00,00,4d,00,61,00,78,00,3a,00,54,00,69,00,6d,00,65,00,53,00,69,\ 00,6e,00,63,00,65,00,4c,00,61,00,73,00,74,00,20,00,28,00,75,00,73,00,29,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,20,2a,1e,70,00,00,00,00,01,00,00,00,02,00,00,00,\ 02,00,00,00,00,00,00,00,6a,00,00,00,01,00,00,00,53,00,75,00,6d,00,3a,00,57,\ 00,61,00,69,00,74,00,73,00,20,00,28,00,75,00,73,00,29,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,20,2a,1e,70,00,00,\ 00,00,01,00,00,00,05,00,00,00,02,00,00,00,06,00,00,00,64,00,00,00,01,00,00,\ 00,4d,00,61,00,78,00,3a,00,57,00,61,00,69,00,74,00,73,00,20,00,28,00,75,00,\ 73,00,29,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,20,2a,1e,70,00,00,00,00,01,00,00,00,02,00,00,00,02,00,00,00,01,\ 00,00,00,6a,00,00,00,01,00,00,00,53,00,75,00,6d,00,3a,00,52,00,65,00,61,00,\ 64,00,79,00,20,00,28,00,75,00,73,00,29,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,20,2a,1e,70,00,00,00,00,01,00,00,\ 00,05,00,00,00,02,00,00,00,05,00,00,00,64,00,00,00,01,00,00,00,4d,00,61,00,\ 78,00,3a,00,52,00,65,00,61,00,64,00,79,00,20,00,28,00,75,00,73,00,29,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,f0,\ 29,1e,70,00,00,00,00,01,00,00,00,02,00,00,00,02,00,00,00,07,00,00,00,46,00,\ 00,00,01,00,00,00,43,00,6f,00,75,00,6e,00,74,00,3a,00,57,00,61,00,69,00,74,\ 00,73,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,20,2a,1e,70,00,00,00,00,01,00,00,00,02,00,00,00,\ 00,00,00,00,16,00,00,00,64,00,00,00,01,00,00,00,4e,00,65,00,77,00,49,00,6e,\ 00,53,00,77,00,69,00,74,00,63,00,68,00,54,00,69,00,6d,00,65,00,20,00,28,00,\ 75,00,73,00,29,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,80,2a,1e,70,00,00,\ 00,00,01,00,00,00,00,00,00,00,00,00,00,00,18,00,00,00,78,00,00,00,00,00,00,\ 00,4c,00,61,00,73,00,74,00,53,00,77,00,69,00,74,00,63,00,68,00,4f,00,75,00,\ 74,00,54,00,69,00,6d,00,65,00,20,00,28,00,73,00,29,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,f0,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,19,\ 00,00,00,46,00,00,00,00,00,00,00,4e,00,65,00,77,00,50,00,72,00,65,00,76,00,\ 4f,00,75,00,74,00,50,00,72,00,69,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,f0,29,1e,70,00,00,00,00,01,00,00,\ 00,00,00,00,00,00,00,00,00,1a,00,00,00,46,00,00,00,01,00,00,00,4e,00,65,00,\ 77,00,49,00,6e,00,50,00,72,00,69,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,f0,\ 29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,1b,00,00,00,46,00,\ 00,00,00,00,00,00,4e,00,65,00,77,00,4f,00,75,00,74,00,50,00,72,00,69,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,d0,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,\ 00,00,00,00,1c,00,00,00,3c,00,00,00,00,00,00,00,4e,00,65,00,77,00,51,00,6e,\ 00,74,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,\ 00,00,01,00,00,00,00,00,00,00,00,00,00,00,1d,00,00,00,64,00,00,00,00,00,00,\ 00,4e,00,65,00,77,00,50,00,72,00,65,00,76,00,53,00,74,00,61,00,74,00,65,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,1e,\ 00,00,00,64,00,00,00,00,00,00,00,4e,00,65,00,77,00,50,00,72,00,65,00,76,00,\ 57,00,61,00,69,00,74,00,52,00,65,00,61,00,73,00,6f,00,6e,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,\ 00,00,00,00,00,00,00,00,00,1f,00,00,00,50,00,00,00,00,00,00,00,4e,00,65,00,\ 77,00,50,00,72,00,65,00,76,00,57,00,61,00,69,00,74,00,4d,00,6f,00,64,00,65,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,\ 29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,20,00,00,00,64,00,\ 00,00,00,00,00,00,4e,00,65,00,77,00,53,00,74,00,61,00,74,00,65,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,\ 00,00,00,00,21,00,00,00,64,00,00,00,00,00,00,00,4e,00,65,00,77,00,57,00,61,\ 00,69,00,74,00,52,00,65,00,61,00,73,00,6f,00,6e,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,\ 00,00,01,00,00,00,00,00,00,00,00,00,00,00,22,00,00,00,50,00,00,00,00,00,00,\ 00,4e,00,65,00,77,00,57,00,61,00,69,00,74,00,4d,00,6f,00,64,00,65,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,2a,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,23,\ 00,00,00,3c,00,00,00,00,00,00,00,4e,00,65,00,77,00,50,00,72,00,69,00,44,00,\ 65,00,63,00,72,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,\ 00,00,00,00,00,00,00,00,00,24,00,00,00,b4,00,00,00,00,00,00,00,4f,00,6c,00,\ 64,00,50,00,72,00,6f,00,63,00,65,00,73,00,73,00,20,00,4e,00,61,00,6d,00,65,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,\ 29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,25,00,00,00,c8,00,\ 00,00,01,00,00,00,4f,00,6c,00,64,00,50,00,72,00,6f,00,63,00,65,00,73,00,73,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,90,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,\ 01,00,00,00,08,00,00,00,50,00,00,00,01,00,00,00,4f,00,6c,00,64,00,54,00,68,\ 00,72,00,65,00,61,00,64,00,49,00,64,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,f0,29,1e,70,00,00,\ 00,00,01,00,00,00,00,00,00,00,00,00,00,00,26,00,00,00,46,00,00,00,01,00,00,\ 00,4f,00,6c,00,64,00,4f,00,75,00,74,00,50,00,72,00,69,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,d0,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,27,\ 00,00,00,3c,00,00,00,00,00,00,00,4f,00,6c,00,64,00,51,00,6e,00,74,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,20,2a,1e,70,00,00,00,00,01,00,00,\ 00,02,00,00,00,02,00,00,00,09,00,00,00,64,00,00,00,01,00,00,00,4f,00,6c,00,\ 64,00,49,00,6e,00,53,00,77,00,69,00,74,00,63,00,68,00,54,00,69,00,6d,00,65,\ 00,20,00,28,00,75,00,73,00,29,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,\ 29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,28,00,00,00,50,00,\ 00,00,01,00,00,00,4f,00,6c,00,64,00,53,00,74,00,61,00,74,00,65,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,\ 00,00,00,00,29,00,00,00,64,00,00,00,01,00,00,00,4f,00,6c,00,64,00,57,00,61,\ 00,69,00,74,00,52,00,65,00,61,00,73,00,6f,00,6e,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,\ 00,00,01,00,00,00,00,00,00,00,00,00,00,00,2a,00,00,00,50,00,00,00,01,00,00,\ 00,4f,00,6c,00,64,00,57,00,61,00,69,00,74,00,4d,00,6f,00,64,00,65,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,f0,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,01,00,00,00,0a,\ 00,00,00,32,00,00,00,01,00,00,00,43,00,70,00,75,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,f0,29,1e,70,00,00,00,00,01,00,00,\ 00,00,00,00,00,01,00,00,00,0b,00,00,00,3c,00,00,00,01,00,00,00,49,00,64,00,\ 65,00,61,00,6c,00,43,00,70,00,75,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 2a,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,2b,00,00,00,3c,00,\ 00,00,00,00,00,00,50,00,72,00,65,00,76,00,43,00,53,00,74,00,61,00,74,00,65,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00
[HKEY_CURRENT_USER\Software\Microsoft\Windows Performance Analyzer\v4\XPerfView\Tables\Disk Summary Table] "<Current>"=hex:40,29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,01,\ 00,00,00,78,00,00,00,00,00,00,00,50,00,72,00,6f,00,63,00,65,00,73,00,73,00,\ 20,00,4e,00,61,00,6d,00,65,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,02,00,00,00,8c,00,00,00,01,00,00,00,50,00,72,00,\ 6f,00,63,00,65,00,73,00,73,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,f0,\ 28,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,03,00,00,00,c8,00,\ 00,00,00,00,00,00,50,00,61,00,74,00,68,00,20,00,54,00,72,00,65,00,65,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,04,00,00,00,c8,00,00,00,01,00,00,00,50,00,61,00,74,00,68,00,20,\ 00,4e,00,61,00,6d,00,65,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,\ 00,00,01,00,00,00,00,00,00,00,00,00,00,00,06,00,00,00,3c,00,00,00,00,00,00,\ 00,50,00,61,00,74,00,68,00,20,00,45,00,78,00,74,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,20,2a,1e,70,00,00,00,00,01,00,00,00,02,00,00,00,02,00,00,00,00,\ 00,00,00,8c,00,00,00,01,00,00,00,53,00,65,00,72,00,76,00,69,00,63,00,65,00,\ 20,00,54,00,69,00,6d,00,65,00,20,00,28,00,75,00,73,00,29,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,60,29,1e,70,00,00,00,00,01,00,00,\ 00,02,00,00,00,00,00,00,00,07,00,00,00,50,00,00,00,01,00,00,00,53,00,69,00,\ 7a,00,65,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,e0,\ 29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,08,00,00,00,28,00,\ 00,00,01,00,00,00,50,00,72,00,69,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,60,29,1e,70,00,00,00,00,01,00,00,00,02,00,00,00,\ 00,00,00,00,09,00,00,00,50,00,00,00,01,00,00,00,52,00,65,00,61,00,64,00,20,\ 00,43,00,6f,00,75,00,6e,00,74,00,73,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,20,2a,1e,70,00,00,\ 00,00,01,00,00,00,02,00,00,00,00,00,00,00,0a,00,00,00,8c,00,00,00,01,00,00,\ 00,52,00,65,00,61,00,64,00,20,00,53,00,65,00,72,00,76,00,69,00,63,00,65,00,\ 20,00,54,00,69,00,6d,00,65,00,20,00,28,00,75,00,73,00,29,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,60,29,1e,70,00,00,00,00,01,00,00,00,02,00,00,00,00,00,00,00,0b,\ 00,00,00,50,00,00,00,01,00,00,00,52,00,65,00,61,00,64,00,20,00,53,00,69,00,\ 7a,00,65,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,60,29,1e,70,00,00,00,00,01,00,00,\ 00,02,00,00,00,00,00,00,00,0c,00,00,00,50,00,00,00,01,00,00,00,57,00,72,00,\ 69,00,74,00,65,00,20,00,43,00,6f,00,75,00,6e,00,74,00,73,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,20,\ 2a,1e,70,00,00,00,00,01,00,00,00,02,00,00,00,00,00,00,00,0d,00,00,00,8c,00,\ 00,00,01,00,00,00,57,00,72,00,69,00,74,00,65,00,20,00,53,00,65,00,72,00,76,\ 00,69,00,63,00,65,00,20,00,54,00,69,00,6d,00,65,00,28,00,75,00,73,00,29,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,60,29,1e,70,00,00,00,00,01,00,00,00,02,00,00,00,\ 00,00,00,00,0e,00,00,00,50,00,00,00,01,00,00,00,57,00,72,00,69,00,74,00,65,\ 00,20,00,53,00,69,00,7a,00,65,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,60,29,1e,70,00,00,\ 00,00,01,00,00,00,02,00,00,00,00,00,00,00,0f,00,00,00,50,00,00,00,01,00,00,\ 00,46,00,6c,00,75,00,73,00,68,00,20,00,43,00,6f,00,75,00,6e,00,74,00,73,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,20,2a,1e,70,00,00,00,00,01,00,00,00,02,00,00,00,00,00,00,00,10,\ 00,00,00,8c,00,00,00,01,00,00,00,46,00,6c,00,75,00,73,00,68,00,20,00,53,00,\ 65,00,72,00,76,00,69,00,63,00,65,00,20,00,54,00,69,00,6d,00,65,00,28,00,75,\ 00,73,00,29,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,60,29,1e,70,00,00,00,00,01,00,00,\ 00,01,00,00,00,00,00,00,00,11,00,00,00,50,00,00,00,01,00,00,00,41,00,76,00,\ 67,00,2e,00,20,00,53,00,69,00,7a,00,65,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,60,\ 29,1e,70,00,00,00,00,01,00,00,00,01,00,00,00,00,00,00,00,12,00,00,00,64,00,\ 00,00,01,00,00,00,41,00,76,00,67,00,2e,00,20,00,52,00,65,00,61,00,64,00,20,\ 00,53,00,69,00,7a,00,65,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,60,29,1e,70,00,00,00,00,01,00,00,00,01,00,00,00,\ 00,00,00,00,13,00,00,00,64,00,00,00,01,00,00,00,41,00,76,00,67,00,2e,00,20,\ 00,57,00,72,00,69,00,74,00,65,00,20,00,53,00,69,00,7a,00,65,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,50,29,1e,70,00,00,\ 00,00,01,00,00,00,04,00,00,00,00,00,00,00,14,00,00,00,8c,00,00,00,01,00,00,\ 00,4d,00,69,00,6e,00,20,00,4f,00,66,00,66,00,73,00,65,00,74,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,50,29,1e,70,00,00,00,00,01,00,00,00,05,00,00,00,00,00,00,00,15,\ 00,00,00,8c,00,00,00,01,00,00,00,4d,00,61,00,78,00,20,00,4f,00,66,00,66,00,\ 73,00,65,00,74,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00
[HKEY_CURRENT_USER\Software\Microsoft\Windows Performance Analyzer\v4\XPerfView\Tables\Generic Events Simple Summary Table] "<Current>"=hex:40,29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,03,\ 00,00,00,c8,00,00,00,00,00,00,00,50,00,72,00,6f,00,63,00,65,00,73,00,73,00,\ 20,00,4e,00,61,00,6d,00,65,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,06,00,00,00,b4,00,00,00,01,00,00,00,50,00,72,00,\ 6f,00,76,00,69,00,64,00,65,00,72,00,20,00,4e,00,61,00,6d,00,65,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,\ 29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,04,00,00,00,6c,00,\ 00,00,01,00,00,00,50,00,72,00,6f,00,63,00,65,00,73,00,73,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,a0,29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,05,00,00,00,2a,00,00,00,01,00,00,00,54,00,68,00,72,00,65,00,61,\ 00,64,00,20,00,49,00,44,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,29,1e,70,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,07,00,00,00,c8,00,00,00,00,00,00,\ 00,53,00,74,00,61,00,63,00,6b,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,40,29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,08,\ 00,00,00,1d,01,00,00,00,00,00,00,45,00,76,00,65,00,6e,00,74,00,20,00,4e,00,\ 61,00,6d,00,65,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,b0,29,1e,70,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,09,00,00,00,46,00,00,00,00,00,00,00,49,00,64,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,80,\ 2a,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,01,00,00,00,00,00,00,00,5a,00,\ 00,00,01,00,00,00,54,00,69,00,6d,00,65,00,20,00,28,00,73,00,29,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,10,29,1e,70,00,00,00,00,01,00,00,00,03,00,00,00,\ 02,00,00,00,02,00,00,00,50,00,00,00,01,00,00,00,43,00,6f,00,75,00,6e,00,74,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,e0,29,1e,70,00,00,\ 00,00,01,00,00,00,00,00,00,00,00,00,00,00,0b,00,00,00,2f,00,00,00,01,00,00,\ 00,56,00,65,00,72,00,73,00,69,00,6f,00,6e,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,b0,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,02,00,00,00,01,\ 00,00,00,35,00,00,00,01,00,00,00,54,00,61,00,73,00,6b,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,f0,29,1e,70,00,00,00,00,01,00,00,\ 00,00,00,00,00,00,00,00,00,0d,00,00,00,28,00,00,00,00,00,00,00,43,00,50,00,\ 55,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,e0,\ 29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,0a,00,00,00,32,00,\ 00,00,01,00,00,00,4f,00,70,00,63,00,6f,00,64,00,65,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,e0,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,\ 00,00,00,00,0e,00,00,00,3c,00,00,00,01,00,00,00,43,00,68,00,61,00,6e,00,6e,\ 00,65,00,6c,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,e0,29,1e,70,00,00,\ 00,00,01,00,00,00,00,00,00,00,00,00,00,00,0f,00,00,00,32,00,00,00,01,00,00,\ 00,4c,00,65,00,76,00,65,00,6c,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,50,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,10,\ 00,00,00,8c,00,00,00,01,00,00,00,4b,00,65,00,79,00,77,00,6f,00,72,00,64,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,\ 00,00,00,00,00,00,00,00,00,11,00,00,00,1d,01,00,00,00,00,00,00,50,00,72,00,\ 6f,00,76,00,69,00,64,00,65,00,72,00,49,00,64,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,\ 29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,12,00,00,00,32,00,\ 00,00,00,00,00,00,50,00,72,00,6f,00,76,00,69,00,64,00,65,00,72,00,54,00,79,\ 00,70,00,65,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00
[HKEY_CURRENT_USER\Software\Microsoft\Windows Performance Analyzer\v4\XPerfView\Tables\Generic Events Summary Table] "<Current>"=hex:40,29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,03,\ 00,00,00,1d,01,00,00,00,00,00,00,65,00,74,00,77,00,3a,00,41,00,63,00,74,00,\ 69,00,76,00,69,00,74,00,79,00,49,00,64,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,04,00,00,00,1d,01,00,00,00,00,00,00,65,00,74,00,\ 77,00,3a,00,52,00,65,00,6c,00,61,00,74,00,65,00,64,00,20,00,41,00,63,00,74,\ 00,69,00,76,00,69,00,74,00,79,00,49,00,64,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,\ 29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,05,00,00,00,c8,00,\ 00,00,00,00,00,00,65,00,74,00,77,00,3a,00,55,00,73,00,65,00,72,00,53,00,69,\ 00,64,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,06,00,00,00,28,00,00,00,00,00,00,00,65,00,74,00,77,00,3a,00,53,\ 00,65,00,73,00,73,00,69,00,6f,00,6e,00,49,00,64,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,07,00,00,00,c8,00,00,00,00,00,00,\ 00,50,00,72,00,6f,00,63,00,65,00,73,00,73,00,20,00,4e,00,61,00,6d,00,65,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,40,29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,09,\ 00,00,00,1d,01,00,00,01,00,00,00,50,00,72,00,6f,00,76,00,69,00,64,00,65,00,\ 72,00,20,00,4e,00,61,00,6d,00,65,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,00,00,00,\ 00,00,00,00,00,01,00,00,00,00,00,00,00,c8,00,00,00,01,00,00,00,50,00,72,00,\ 6f,00,63,00,65,00,73,00,73,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,a0,\ 29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,08,00,00,00,50,00,\ 00,00,01,00,00,00,54,00,68,00,72,00,65,00,61,00,64,00,20,00,49,00,44,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,0a,00,00,00,1d,01,00,00,00,00,00,00,45,00,76,00,65,00,6e,00,74,\ 00,20,00,4e,00,61,00,6d,00,65,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,80,2a,1e,70,00,00,\ 00,00,00,00,00,00,00,00,00,00,01,00,00,00,02,00,00,00,78,00,00,00,01,00,00,\ 00,54,00,69,00,6d,00,65,00,20,00,28,00,73,00,29,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,40,29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,0b,\ 00,00,00,1d,01,00,00,00,00,00,00,54,00,61,00,73,00,6b,00,20,00,4e,00,61,00,\ 6d,00,65,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,29,1e,70,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,0c,00,00,00,c8,00,00,00,00,00,00,00,53,00,74,00,\ 61,00,63,00,6b,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,b0,\ 29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,0d,00,00,00,46,00,\ 00,00,00,00,00,00,49,00,64,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,10,29,1e,70,00,00,00,00,01,00,00,00,03,00,00,00,\ 02,00,00,00,01,00,00,00,50,00,00,00,01,00,00,00,43,00,6f,00,75,00,6e,00,74,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,\ 00,00,01,00,00,00,00,00,00,00,00,00,00,00,0f,00,00,00,4f,00,00,00,01,00,00,\ 00,4f,00,70,00,63,00,6f,00,64,00,65,00,20,00,4e,00,61,00,6d,00,65,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,f0,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,10,\ 00,00,00,28,00,00,00,00,00,00,00,43,00,50,00,55,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,\ 00,00,00,00,00,00,00,00,00,11,00,00,00,85,01,00,00,01,00,00,00,46,00,69,00,\ 65,00,6c,00,64,00,20,00,31,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,\ 29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,12,00,00,00,3e,01,\ 00,00,01,00,00,00,46,00,69,00,65,00,6c,00,64,00,20,00,32,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,\ 00,00,00,00,13,00,00,00,3c,00,00,00,01,00,00,00,46,00,69,00,65,00,6c,00,64,\ 00,20,00,33,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,\ 00,00,01,00,00,00,00,00,00,00,00,00,00,00,14,00,00,00,3c,00,00,00,01,00,00,\ 00,46,00,69,00,65,00,6c,00,64,00,20,00,34,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,15,\ 00,00,00,3c,00,00,00,01,00,00,00,46,00,69,00,65,00,6c,00,64,00,20,00,35,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,\ 00,00,00,00,00,00,00,00,00,16,00,00,00,3c,00,00,00,01,00,00,00,46,00,69,00,\ 65,00,6c,00,64,00,20,00,36,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,\ 29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,17,00,00,00,3c,00,\ 00,00,01,00,00,00,46,00,69,00,65,00,6c,00,64,00,20,00,37,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,\ 00,00,00,00,18,00,00,00,3c,00,00,00,01,00,00,00,46,00,69,00,65,00,6c,00,64,\ 00,20,00,38,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,\ 00,00,01,00,00,00,00,00,00,00,00,00,00,00,19,00,00,00,3c,00,00,00,01,00,00,\ 00,46,00,69,00,65,00,6c,00,64,00,20,00,39,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,1a,\ 00,00,00,3c,00,00,00,01,00,00,00,46,00,69,00,65,00,6c,00,64,00,20,00,31,00,\ 30,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,\ 00,00,00,00,00,00,00,00,00,1b,00,00,00,3c,00,00,00,01,00,00,00,46,00,69,00,\ 65,00,6c,00,64,00,20,00,31,00,31,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,\ 29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,1c,00,00,00,3c,00,\ 00,00,01,00,00,00,46,00,69,00,65,00,6c,00,64,00,20,00,31,00,32,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,\ 00,00,00,00,1d,00,00,00,3c,00,00,00,01,00,00,00,46,00,69,00,65,00,6c,00,64,\ 00,20,00,31,00,33,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,c0,29,1e,70,00,00,\ 00,00,01,00,00,00,02,00,00,00,00,00,00,00,1e,00,00,00,64,00,00,00,01,00,00,\ 00,55,00,73,00,65,00,72,00,44,00,61,00,74,00,61,00,4c,00,65,00,6e,00,67,00,\ 74,00,68,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,b0,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,1f,\ 00,00,00,46,00,00,00,01,00,00,00,54,00,61,00,73,00,6b,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,e0,29,1e,70,00,00,00,00,01,00,00,\ 00,00,00,00,00,00,00,00,00,20,00,00,00,32,00,00,00,01,00,00,00,4f,00,70,00,\ 63,00,6f,00,64,00,65,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,e0,\ 29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,21,00,00,00,32,00,\ 00,00,01,00,00,00,56,00,65,00,72,00,73,00,69,00,6f,00,6e,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,e0,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,\ 00,00,00,00,22,00,00,00,3c,00,00,00,01,00,00,00,43,00,68,00,61,00,6e,00,6e,\ 00,65,00,6c,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,e0,29,1e,70,00,00,\ 00,00,01,00,00,00,00,00,00,00,00,00,00,00,23,00,00,00,32,00,00,00,01,00,00,\ 00,4c,00,65,00,76,00,65,00,6c,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,50,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,24,\ 00,00,00,8c,00,00,00,01,00,00,00,4b,00,65,00,79,00,77,00,6f,00,72,00,64,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,\ 00,00,00,00,00,00,00,00,00,25,00,00,00,1d,01,00,00,01,00,00,00,50,00,72,00,\ 6f,00,76,00,69,00,64,00,65,00,72,00,49,00,64,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,\ 29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,26,00,00,00,32,00,\ 00,00,01,00,00,00,50,00,72,00,6f,00,76,00,69,00,64,00,65,00,72,00,54,00,79,\ 00,70,00,65,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00
[HKEY_CURRENT_USER\Software\Microsoft\Windows Performance Analyzer\v4\XPerfView\Tables\Images Summary Table] "<Current>"=hex:40,29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,01,00,00,00,01,\ 00,00,00,c8,00,00,00,00,00,00,00,50,00,72,00,6f,00,63,00,65,00,73,00,73,00,\ 20,00,4e,00,61,00,6d,00,65,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,00,00,00,\ 00,00,00,00,00,01,00,00,00,08,00,00,00,c8,00,00,00,01,00,00,00,49,00,6d,00,\ 61,00,67,00,65,00,20,00,4e,00,61,00,6d,00,65,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,\ 29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,01,00,00,00,02,00,00,00,c8,00,\ 00,00,01,00,00,00,50,00,72,00,6f,00,63,00,65,00,73,00,73,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,a0,29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,\ 01,00,00,00,03,00,00,00,50,00,00,00,00,00,00,00,50,00,72,00,6f,00,63,00,65,\ 00,73,00,73,00,20,00,49,00,44,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,a0,29,1e,70,00,00,\ 00,00,00,00,00,00,00,00,00,00,01,00,00,00,05,00,00,00,50,00,00,00,01,00,00,\ 00,50,00,61,00,72,00,65,00,6e,00,74,00,20,00,50,00,72,00,6f,00,63,00,65,00,\ 73,00,73,00,20,00,49,00,44,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,a0,29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,01,00,00,00,04,\ 00,00,00,3c,00,00,00,00,00,00,00,53,00,65,00,73,00,73,00,69,00,6f,00,6e,00,\ 20,00,49,00,44,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,29,1e,70,00,00,00,00,00,00,00,\ 00,00,00,00,00,01,00,00,00,06,00,00,00,c8,00,00,00,00,00,00,00,4c,00,6f,00,\ 61,00,64,00,20,00,53,00,74,00,61,00,63,00,6b,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,01,00,00,00,07,00,00,00,c8,00,\ 00,00,00,00,00,00,55,00,6e,00,6c,00,6f,00,61,00,64,00,20,00,53,00,74,00,61,\ 00,63,00,6b,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,\ 01,00,00,00,09,00,00,00,2c,01,00,00,00,00,00,00,49,00,6d,00,61,00,67,00,65,\ 00,20,00,50,00,61,00,74,00,68,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,10,29,1e,70,00,00,\ 00,00,01,00,00,00,03,00,00,00,02,00,00,00,00,00,00,00,3c,00,00,00,01,00,00,\ 00,43,00,6f,00,75,00,6e,00,74,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,80,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,0b,\ 00,00,00,50,00,00,00,01,00,00,00,49,00,6d,00,61,00,67,00,65,00,53,00,69,00,\ 7a,00,65,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,f0,29,1e,70,00,00,00,00,01,00,00,\ 00,02,00,00,00,00,00,00,00,0c,00,00,00,50,00,00,00,00,00,00,00,50,00,65,00,\ 72,00,6d,00,61,00,6e,00,65,00,6e,00,74,00,20,00,43,00,6f,00,75,00,6e,00,74,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,\ 2a,1e,70,00,00,00,00,01,00,00,00,02,00,00,00,02,00,00,00,0d,00,00,00,78,00,\ 00,00,00,00,00,00,44,00,75,00,72,00,61,00,74,00,69,00,6f,00,6e,00,20,00,28,\ 00,73,00,29,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,40,2a,1e,70,00,00,00,00,01,00,00,00,01,00,00,00,\ 02,00,00,00,0e,00,00,00,78,00,00,00,00,00,00,00,41,00,76,00,67,00,20,00,44,\ 00,75,00,72,00,61,00,74,00,69,00,6f,00,6e,00,20,00,28,00,73,00,29,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,2a,1e,70,00,00,\ 00,00,01,00,00,00,04,00,00,00,01,00,00,00,0f,00,00,00,78,00,00,00,00,00,00,\ 00,4d,00,69,00,6e,00,20,00,44,00,75,00,72,00,61,00,74,00,69,00,6f,00,6e,00,\ 20,00,28,00,73,00,29,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,40,2a,1e,70,00,00,00,00,01,00,00,00,05,00,00,00,02,00,00,00,10,\ 00,00,00,78,00,00,00,00,00,00,00,4d,00,61,00,78,00,20,00,44,00,75,00,72,00,\ 61,00,74,00,69,00,6f,00,6e,00,20,00,28,00,73,00,29,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,80,2a,1e,70,00,00,00,00,01,00,00,\ 00,04,00,00,00,01,00,00,00,11,00,00,00,78,00,00,00,01,00,00,00,53,00,74,00,\ 61,00,72,00,74,00,20,00,54,00,69,00,6d,00,65,00,20,00,28,00,73,00,29,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,80,\ 2a,1e,70,00,00,00,00,01,00,00,00,05,00,00,00,01,00,00,00,12,00,00,00,78,00,\ 00,00,01,00,00,00,45,00,6e,00,64,00,20,00,54,00,69,00,6d,00,65,00,20,00,28,\ 00,73,00,29,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,50,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,\ 01,00,00,00,13,00,00,00,8c,00,00,00,00,00,00,00,44,00,65,00,66,00,61,00,75,\ 00,6c,00,74,00,20,00,53,00,74,00,61,00,72,00,74,00,20,00,41,00,64,00,64,00,\ 72,00,65,00,73,00,73,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,50,29,1e,70,00,00,\ 00,00,01,00,00,00,04,00,00,00,01,00,00,00,14,00,00,00,8c,00,00,00,01,00,00,\ 00,53,00,74,00,61,00,72,00,74,00,20,00,41,00,64,00,64,00,72,00,65,00,73,00,\ 73,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,50,29,1e,70,00,00,00,00,01,00,00,00,05,00,00,00,01,00,00,00,15,\ 00,00,00,8c,00,00,00,01,00,00,00,45,00,6e,00,64,00,20,00,41,00,64,00,64,00,\ 72,00,65,00,73,00,73,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,f0,29,1e,70,00,00,00,00,01,00,00,\ 00,02,00,00,00,02,00,00,00,16,00,00,00,50,00,00,00,00,00,00,00,52,00,65,00,\ 6c,00,6f,00,63,00,61,00,74,00,65,00,64,00,20,00,43,00,6f,00,75,00,6e,00,74,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,80,\ 29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,17,00,00,00,50,00,\ 00,00,01,00,00,00,43,00,68,00,65,00,63,00,6b,00,73,00,75,00,6d,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,80,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,\ 00,00,00,00,18,00,00,00,50,00,00,00,01,00,00,00,54,00,69,00,6d,00,65,00,44,\ 00,61,00,74,00,65,00,53,00,74,00,61,00,6d,00,70,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,\ 00,00,01,00,00,00,00,00,00,00,00,00,00,00,19,00,00,00,e7,03,00,00,00,00,00,\ 00,50,00,72,00,6f,00,63,00,65,00,73,00,73,00,20,00,43,00,6f,00,6d,00,6d,00,\ 61,00,6e,00,64,00,20,00,4c,00,69,00,6e,00,65,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,1a,\ 00,00,00,c8,00,00,00,00,00,00,00,4f,00,72,00,69,00,67,00,69,00,6e,00,61,00,\ 6c,00,20,00,46,00,69,00,6c,00,65,00,20,00,4e,00,61,00,6d,00,65,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,\ 00,00,00,00,00,00,00,00,00,1b,00,00,00,2c,01,00,00,00,00,00,00,46,00,69,00,\ 6c,00,65,00,20,00,44,00,65,00,73,00,63,00,72,00,69,00,70,00,74,00,69,00,6f,\ 00,6e,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,\ 29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,1c,00,00,00,2c,01,\ 00,00,01,00,00,00,46,00,69,00,6c,00,65,00,20,00,56,00,65,00,72,00,73,00,69,\ 00,6f,00,6e,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,\ 00,00,00,00,1d,00,00,00,78,00,00,00,00,00,00,00,42,00,69,00,6e,00,61,00,72,\ 00,79,00,20,00,46,00,69,00,6c,00,65,00,20,00,56,00,65,00,72,00,73,00,69,00,\ 6f,00,6e,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,\ 00,00,01,00,00,00,00,00,00,00,00,00,00,00,1e,00,00,00,78,00,00,00,00,00,00,\ 00,56,00,65,00,72,00,73,00,69,00,6f,00,6e,00,20,00,4c,00,61,00,6e,00,67,00,\ 75,00,61,00,67,00,65,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,1f,\ 00,00,00,fa,00,00,00,00,00,00,00,50,00,72,00,6f,00,64,00,75,00,63,00,74,00,\ 20,00,4e,00,61,00,6d,00,65,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,\ 00,00,00,00,00,00,00,00,00,20,00,00,00,c8,00,00,00,00,00,00,00,43,00,6f,00,\ 6d,00,70,00,61,00,6e,00,79,00,20,00,4e,00,61,00,6d,00,65,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,\ 29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,21,00,00,00,78,00,\ 00,00,00,00,00,00,50,00,72,00,6f,00,64,00,75,00,63,00,74,00,20,00,56,00,65,\ 00,72,00,73,00,69,00,6f,00,6e,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,\ 00,00,00,00,22,00,00,00,2c,01,00,00,00,00,00,00,46,00,69,00,6c,00,65,00,49,\ 00,64,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,29,1e,70,00,00,\ 00,00,01,00,00,00,00,00,00,00,00,00,00,00,23,00,00,00,2c,01,00,00,00,00,00,\ 00,50,00,72,00,6f,00,67,00,72,00,61,00,6d,00,49,00,64,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00
[HKEY_CURRENT_USER\Software\Microsoft\Windows Performance Analyzer\v4\XPerfView\Tables\Winlogon Notifications Summary Table] "<Current>"=hex:40,29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,02,00,00,00,00,\ 00,00,00,c8,00,00,00,01,00,00,00,4e,00,6f,00,74,00,69,00,66,00,69,00,63,00,\ 61,00,74,00,69,00,6f,00,6e,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,90,29,1e,70,00,00,00,00,00,00,00,\ 00,00,00,00,00,01,00,00,00,01,00,00,00,32,00,00,00,01,00,00,00,53,00,65,00,\ 73,00,73,00,69,00,6f,00,6e,00,49,00,44,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,\ 29,1e,70,00,00,00,00,00,00,00,00,00,00,00,00,01,00,00,00,02,00,00,00,c8,00,\ 00,00,01,00,00,00,53,00,75,00,62,00,73,00,63,00,72,00,69,00,62,00,65,00,72,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,40,2a,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,\ 01,00,00,00,04,00,00,00,8c,00,00,00,01,00,00,00,54,00,6f,00,74,00,61,00,6c,\ 00,20,00,4e,00,6f,00,74,00,69,00,66,00,69,00,63,00,61,00,74,00,69,00,6f,00,\ 6e,00,20,00,54,00,69,00,6d,00,65,00,20,00,28,00,64,00,73,00,29,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,2a,1e,70,00,00,\ 00,00,01,00,00,00,00,00,00,00,01,00,00,00,05,00,00,00,8c,00,00,00,01,00,00,\ 00,53,00,75,00,62,00,73,00,63,00,72,00,69,00,62,00,65,00,72,00,20,00,54,00,\ 69,00,6d,00,65,00,20,00,28,00,64,00,73,00,29,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,80,2a,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,01,00,00,00,06,\ 00,00,00,78,00,00,00,01,00,00,00,4e,00,6f,00,74,00,66,00,2e,00,20,00,53,00,\ 74,00,61,00,72,00,74,00,65,00,64,00,20,00,41,00,74,00,20,00,28,00,73,00,29,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,80,2a,1e,70,00,00,00,00,01,00,00,\ 00,00,00,00,00,01,00,00,00,07,00,00,00,78,00,00,00,01,00,00,00,4e,00,6f,00,\ 74,00,66,00,2e,00,20,00,45,00,6e,00,64,00,65,00,64,00,20,00,41,00,74,00,20,\ 00,28,00,73,00,29,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,80,\ 2a,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,01,00,00,00,08,00,00,00,78,00,\ 00,00,01,00,00,00,53,00,75,00,62,00,73,00,2e,00,20,00,53,00,74,00,61,00,72,\ 00,74,00,65,00,64,00,20,00,41,00,74,00,20,00,28,00,73,00,29,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,80,2a,1e,70,00,00,00,00,01,00,00,00,00,00,00,00,\ 01,00,00,00,09,00,00,00,78,00,00,00,01,00,00,00,53,00,75,00,62,00,73,00,2e,\ 00,20,00,45,00,6e,00,64,00,65,00,64,00,20,00,41,00,74,00,20,00,28,00,73,00,\ 29,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\ 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00 <end copy here>
Windows On/Off Transition Performance Analysis
msdn.microsoft.com/.../gg463386
Huge hex code...
This article has been highlighted in this week's "Top Contributors" TechNet Wiki Ninjas blog : blogs.technet.com/.../top-contributors-windows-trust-migration-agudlp-admt-slow-boots-and-slow-logons-sbsl-windows-server-2012.aspx
