ADD MEMBERS TO GROUP ADMINISTRATORS SET
MPRs TO ENABLE
MODIFY ALL NON-ADMINISTRATORS SET We are modifying this Set because this Set because it is a "Specific Set of Requestors" for the following two Management Policy Rules (MPRs). Group management workflow: Validate requestor on add member to open group Group management workflow: Validate requestor on remove member if this Set is not modified to include Group Administrators, then it is very possible that you will receive an "Access Denied" when submitting the request.
