This Test Lab Guide Mini-Module describes how to install an additional SharePoint Server 2013 farm on the Corpnet subnet, in addition to the three-tier farm configured in the Test Lab Guide: Configure SharePoint Server 2013 in a Three-Tier Farm. You add a new computer named APP2, make it a member of the corp.contoso.com domain, and then install SharePoint Server 2013 as a separate single-server farm. Both the 3-tier farm and the new farm share SQL1 as their database server. The following figure shows the lab configuration (click on it to see a larger version):
The result is a test lab environment to demonstrate SharePoint Server 2013 cross-farm scenarios and solutions. First, you create the SharePoint Server 2013 three-tier farm as described in the Test Lab Guide: Configure SharePoint Server 2013 in a Three-Tier Farm.
Next, you install Windows Server 2008 R2 Enterprise Edition as a standalone server on a new computer.
Next, you configure the TCP/IP protocol with a static IP address of 10.0.0.10 and the subnet mask of 255.255.255.0.
Next, you join APP2 to the corp.contoso.com domain.
Next, you install the prerequisite software components for SharePoint Server 2013 on APP2.
Next, you create a new SharePoint farm admin account and grant it rights to create databases on SQL1.
Next, you install SharePoint Server 2013 on APP2.
Finally, you verify access to the default team site on APP2.
If you are running this test lab in a virtual environment, you can create snapshots of the virtual machines (VMs) for all of the test lab computers to save this configuration.
For a list of TLGs related to this test lab or extensions to demonstrate additional functionality, see SharePoint Server 2013 Test Lab.
For additional test lab guide resources, see Test Lab Guides.
For the latest news in the TLG initiative, see the Test Lab Guides blog.
Nice Article I will try to setup one using virtual environment.
good work
