System Center 2012 Integration Guide
This guide is part of the System Center Authoring Hub  .
The System Center 2012 Integration Guide provides an overview of each System Center component in its role as a programmable platform to be leveraged for the Microsoft Private Cloud.  It is intended to provide an abstraction layer that guides partners and customers on their decision process for methods to build automated solutions across System Center components.
This guide is a community project to analyze the different options for integration with the components of System Center 2012.  Please feel free to edit each section to improve its quality.  You may add additional content, clarify existing content, or provide links to related information.  Microsoft resources will continuously monitor the guide to ensure that it is accurate and reflects the latest information.
Component Guides
Each of the following sections provides an overview of each System Center component, its different options for automating processes, and the methods for integrating with it from other application and other System Center components.  You can link to each of these sections below.
The following diagram shows the integration of the System Center 2012 cloud components with each other and with other software and hardware.  Click on the diagram to view it full size.
Technical Scenarios
Technical scenarios provide guidance for challenges that are either solved by using multiple System Center components or by using special configuration or customization.  Several scenarios have been documented here in the TechNet Wiki, and this list will continuously grow.
Comments
  • Thanks for the great info, Brian. I'm curious though, why is there not a section for Configuration Manager?
  • Focused on server side components for the moment.  I'm talking to the client management people about expanding the scope to those components.
  • I think he is asking about the server side component Configuration Manager not its client side parts. If he is not, then I am asking where is the Configuration Manager Component integration guide for the server side System Center 2012?
  • Looking for Configuration Manager integration as well.  Thanks
Page 1 of 1 (5 items)
