SQL Azure provides a large-scale multi-tenant database service on shared resources. In order to provide a good experience to all SQL Azure customers, your connection to the service may be closed due to several reasons, like throttling. This article introduces SQL Azure and its network topology. Then, it lists the reasons for connection losses and provides guidelines and best coding practices on how to manage the connection life cycle in SQL Azure.
Last Reviewed: 8/19/2011
Note: If you are already familiar with this information and are looking for example code for connection retry, please see Retry Logic for Transient Failures in SQL Azure.
Microsoft SQL Azure Database is a cloud-based relational database service that is built on SQL Server technologies and runs in Microsoft data centers on hardware that is owned, hosted, and maintained by Microsoft.
SQL Azure is built on a scalable platform involving numerous physical servers, and manages all the connections routing between your application and the physical servers where your data resides. Each SQL Azure server can be associated with one or more databases. A SQL Azure server is a logical group of databases.
SQL Azure provides a large-scale multi-tenant database service on shared resources. To enable load balancing and high availability, databases associated with your SQL Azure server may reside on separate physical computers in a Microsoft data center. Each physical computer can service many databases. When there is enough capacity, all the sessions can take full advantage of the available resources in SQL Azure. However, if resources run low at peak times, SQL Azure terminates the sessions using excessive resources to provide a stable system and prevents sessions from monopolizing all the resources till resources become available.
In addition to this, SQL Azure employs a built-in load-balancing technology to ensure the optimal usage of the physical servers and services in the data centers. Load balancing in SQL Azure is achieved by moving the databases within the physical machines and services based on periodic audit of system usage.
The following diagram illustrates the overall SQL Azure network topology.
As seen in the diagram, SQL Azure provides the same tabular data stream (TDS) interface as SQL Server. Therefore, you can use familiar tools and libraries to build client applications for data that is in the cloud.
The load balancers ensure the optimal usage of the physical servers and services in the data centers.
The TDS Gateway functions as a gateway between your application and the underlying platform, where your data resides. It performs the functions of data center isolation, provisioning, billing and metering, and connection routing.
The underlying platform consists of many instances of SQL Server, each of which is managed by the SQL Azure fabric. The SQL Azure fabric is a distributed computing system composed of tightly integrated networks, servers, and storage. It enables automatic failover, load balancing, and automatic replication between physical servers.
Throttling is a mechanism used by SQL Azure to prevent machines from becoming overloaded and unresponsive. Throttling works by monitoring resource consumption metrics for each machine in a cluster. When a metric exceeds a threshold, work is slowed down or aborted until the metric falls back below the threshold.
Soft throttling is the first stage of throttling. It is only applied to the database consuming the most resources on the box. Soft throttling happens when a physical machine seems to be on the way to being overloaded, unless its workload is reduced. If soft throttling is successful, no other action is required to maintain the health of the cluster.
Hard throttling is the second and final stage of throttling. It affects every database on the hosting machine. Hard throttling happens when a machine is critically impacted due to overload. It terminates existing operations and prevents new ones until the metric returns below expected threshold.
Connection-loss is not uncommon when databases encounter resource shortages. A unique feature of SQL Azure is its ability to monitor and rebalance active and online user databases in the Microsoft data centers automatically. To achieve this, SQL Azure continuously gathers and analyzes database usage statistics and will terminate connections when necessary. The following list describes the reasons and thresholds that trigger connection-loss. All connection terminations happen asynchronously from the event causing it.
Worker Threads Current mechanism When soft throttling limit for worker threads on a machine is exceeded, the database with the highest requests per second is throttled. Existing connections to that database are terminated and new connections to the database are denied, until number of workers drops below soft limit. Error returned 40501 : The service is currently busy. Retry the request after 10 seconds. Incident ID: <ID>. Code: <code>. Limits Soft throttling : 305 worker threads Type of requests throttled DDL (Create, Drop, …) DML (Insert, Update, Delete, Merge, Select) Database Size Current mechanism When the database space allotted to user db is full, the user gets a db full error. Non-Select DML (Insert, Update, Merge that inserts or updates) are denied. Error returned 40544 : The database has reached its size quota. Partition or delete data, drop indexes, or consult the documentation for possible resolutions. Incident ID: <ID>. Code: <code>. Limit 150 GB (or less for DBs with smaller quotas) Type of requests throttled Inserts, Updates …
Physical Database Space Current mechanism When total database size on a machine exceeds 90% of total space available on machine, all databases become read-only. Load balancer ensures the situation is resolved by balancing databases across machines. Error returned 40545: The service is experiencing a problem that is currently under investigation. Incident ID: <ID>. Code: <code>. Limit 90% of available space on machine Type of requests throttled Inserts, Updates (Merge)
Log Bytes Used Current mechanism SQL Azure supports transactions generating log of up to 2 GB in size. Example operations that can consume log space in this volume: insert, update, delete, merge, create index Error returned 40552 : The session has been terminated because of excessive transaction log space usage. Try modifying fewer rows in a single transaction. Limit Logspace per transaction : 2 GB Type of requests throttled DDL (Create, Drop, …) DML (Insert, Update, Delete, Merge, Select) Recommendations To avoid getting throttled for row operations, reduce the size of data in your transaction, for example by reducing the number of rows or splitting the operation into multiple transactions. To avoid getting throttled for table/index operations that require a single transaction, ensure that the following formula is adhered to:
number of rows affected in table * (avg size of field being updated in bytes + 80) < 2 GB
(In case of index rebuild, avg size of field being updated should be substituted by avg index size) Transaction Log Length Current mechanism Uncommitted transactions can block the truncation of log files. To prevent this, the distance from the oldest active transaction log sequence number (LSN) to the tail of the log (current LSN) cannot exceed 20% of the size of the log file. When violated, the offending transaction is terminated and rolled back so that the log can be truncated. Error returned 40552 : The session has been terminated because of excessive transaction log space usage. Try modifying fewer rows in a single transaction. Limit Transaction span limit : 20% of total log space ( = 100 GB) Type of requests throttled DDL (Create, Drop, …) DML (Insert, Update, Delete, Merge, Select)
Transaction Lock Count Current mechanism Sessions consuming greater than one million locks are terminated. Error returned 40550 : The session has been terminated because it has acquired too many locks. Try reading or modifying fewer rows in a single transaction. Limit 1 million locks Recommendations Following DMVs can be used to monitor transactions : sys.dm_tran_active_transactions sys.dm_tran_database_transactions sys.dm_tran_locks sys.dm_tran_session_transactions
Blocking System Tasks Current mechanism Transactions request locks on resources like rows, pages, or tables, on which the transaction is dependent and then free the locks when they no longer have a dependency on the locked resources. Due to these locks, some transactions might block resources required by system sessions. If a transaction locks a resource required by an underlying system operation for more than 20 seconds, it is terminated. In addition, any transaction that runs for more than 24 hours is terminated. Error returned 40549 : Session is terminated because you have a long-running transaction. Try shortening your transaction. Limit 20 seconds when holding a lock required by system operation 24 hours in general
Temp Db Usage Current mechanism When a session uses more than 5 GB of tempdb space, the session is terminated. Error returned 40551 : The session has been terminated because of excessive TEMPDB usage. Try modifying your query to reduce the temporary table space usage. Limit 5 GB of tempDB space (which is equivalent to 655360 pages) Recommendations Modify queries to reduce the temporary table space usage, drop temporary objects after they are no longer needed, truncate tables or remove unused tables.
MemoryUse Current mechanism When there are sessions waiting on memory for 20 seconds or more, sessions consuming greater than 16 MB for more than 20 seconds are terminated in the descending order of time the resource has been held, so that the oldest session is terminated first. Termination of sessions stops as soon as the required memory becomes available. Error returned 40553 : The session has been terminated because of excessive memory usage. Try modifying your query to process fewer rows. Limit More than 16 MB for more than 20 seconds
Too Many Requests Current mechanism If number of concurrent requests made to a database exceed 400, all transactions that have been running for 1 minute or more are terminated. Error returned 40549 : Session is terminated because you have a long-running transaction. Try shortening your transaction. Limit 400 concurrent requests per partition
Idle connections Current mechanism Connections to SQL Azure database that are idle for 30 minutes or longer will be terminated. Error returned Since there is no active request, SQL Azure does not return any error. Limit 30 minutes
Denial of Service Current mechanism When there are a high number of login failures from a particular source internet protocol (IP) address, SQL Azure will block the connections from that IP address for a period of time. The connection is terminated and no error is returned. Error returned None Recommendations You can configure SQL Azure Firewall to protect against DoS attacks by allowing access to only the client IP addresses that are defined by the firewall rules.
Network Issues Current mechanism Connections might be disconnected due to various network problems. Hosting application code in Windows Azure is beneficial to the performance of application because it minimizes the network latency associated with application's data requests to SQL Azure. For example, if you create a Web-based user interface in Windows Azure for your database application that is hosted in SQL Azure, the client code and data is hosted in the same physical data center, so network latency is minimal between the corresponding servers. Network traffic between the client code and data is much faster. Error returned If a network problem causes connection-loss, SQL Azure cannot return an error message because the session has already been terminated. However, if the same connection is reused, like with connection pooling, the following error message is returned:
10053: A transport-level error has occurred when receiving results from the server. (Provider: TCP Provider, Error: 0 - An established connection was aborted by the software in your host machine).
Failover Issues Current mechanism SQL Azure is flexible to cope with any variations in usage and load. The service replicates multiple redundant copies of data to multiple physical servers to maintain data availability and business continuity. In case of a hardware failure, SQL Azure provides automatic failover to optimize availability for your application. Currently, some failover actions may result in an abrupt termination of a session. Error returned Client application receives generic errors, such as: 10053: A transport-level error has occurred when receiving results from the server. (Provider: TCP Provider, error: 0 - An established connection was aborted by the software in your host machine) or 40197: The service has encountered an error processing your request. Please try again. Error code <code>. Recommendations When an abrupt termination due to failover occurs, reconnecting to your SQL Azure server automatically connects you to a healthy copy of your database.
Resource
Max. value per transaction/session
Max. value per machine
Soft throttling limit
Hard throttling limit
Worker Threads
NA
512
305
410
Database Size
150 GB per partition
None
100% (150 GB or upper limit for customer)
Total space on machine
90%
Log Bytes Used
2 GB per transaction
500 GB
20% of total log space (= 100 GB)
Lock Count
1 milllion per transaction
20 seconds
Temp DB Space
5 GB
Memory
16 MB for 20 seconds
Too Many Requests
The following table lists the SQL Azure-specific transient errors that might occur when your connection to the service is closed.
Error
Description (message text)
40197
The service has encountered an error processing your request. Please try again. Error code %d.
Note: You will receive this error, when the service is down due to software or hardware upgrades, hardware failures, or any other failover problems. Reconnecting to your SQL Azure server will automatically connect you to a healthy copy of your database.
Note: You may see error codes 40143 and 40166 embedded within the message of error 40197. The error codes 40143 and 40166 provide additional information about the kind of failover that occurred. Do not modify your application to catch error codes 40143 and 40166. Your application should catch 40197 and try reconnecting to SQL Azure until the resources are available and your connection is established again.
40501
The service is currently busy. Retry the request after 10 seconds. Code: %d. For more information on how to decode the returned codes, see SQL Azure Throttling and Reason Codes.
Note: When error code 40501 is returned, retry to connect to SQL Azure in intervals of 10 seconds until the resources are available and your connection is established again.
40544
40549
40550
40551
40552
40553
40613
Database '%.*ls' on server '%.*ls' is not currently available. Please retry the connection later. If the problem persists, contact customer support, and provide them the session tracing ID of '%.*ls'
In addition, the following table lists some additional transient errors that might occur when using SQL Azure:
20
The instance of SQL Server you attempted to connect to does not support encryption.
64
A connection was successfully established with the server, but then an error occurred during the login process. (provider: TCP Provider, error: 0 - The specified network name is no longer available.)
233
The client was unable to establish a connection because of an error during connection initialization process before login. Possible causes include the following: the client tried to connect to an unsupported version of SQL Server; the server was too busy to accept new connections; or there was a resource limitation (insufficient memory or maximum allowed connections) on the server. (provider: TCP Provider, error: 0 - An existing connection was forcibly closed by the remote host.)
10053
A transport-level error has occurred when receiving results from the server. An established connection was aborted by the software in your host machine.
10054
A transport-level error has occurred when sending the request to the server. (provider: TCP Provider, error: 0 - An existing connection was forcibly closed by the remote host.)
10060
A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: TCP Provider, error: 0 - A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
For a complete list of errors that can occur only when using Microsoft SQL Azure Database, see Error Messages (SQL Azure Database).
For additional troubleshooting articles, see:
To prevent the connection-losses, you must manage the application resources properly in your SQL Azure applications. The established connections are the connections that are returning data or the open connections in the connection pool, or the connections being cached in the client side variables. To provide a seamless user experience when a connection is closed, re-establish the connection and then re-execute the failed commands or the query.
The following list provides a list of recommended coding practices when connecting to SQL Azure. These recommended coding practices are not significantly different than the coding practices that apply to on-premise SQL Server.
-- Find top 5 queries SELECT TOP 5 query_stats.query_hash AS "Query Hash", SUM(query_stats.total_worker_time) / SUM(query_stats.execution_count) AS "Avg CPU Time", MIN(query_stats.statement_text) AS "Statement Text" FROM (SELECT QS.*, SUBSTRING(ST.text, (QS.statement_start_offset/2) + 1, ((CASE statement_end_offset WHEN -1 THEN DATALENGTH(st.text) ELSE QS.statement_end_offset END - QS.statement_start_offset)/2) + 1) AS statement_text FROM sys.dm_exec_query_stats AS QS CROSS APPLY sys.dm_exec_sql_text(QS.sql_handle) as ST) as query_stats GROUP BY query_stats.query_hash ORDER BY 2 DESC; GO
// if the length is not specified, a cache bloat happens. cmd.CommandText = "SELECT c1 FROM dbo.tbl WHERE c2 = @1"; cmd.Parameters.Add("@1", SqlDbType.NVarChar).Value = "1"; cmd.Parameters.Add("@1", SqlDbType.NVarChar).Value = "22"; (@1 nvarchar(1)) SELECT c1 FROM dbo.tbl WHERE c2 = @1 (@1 nvarchar(2)) SELECT c1 FROM dbo.tbl WHERE c2 = @1 // if the length is specified, there won’t be any cache bloat. cmd.CommandText = "SELECT c1 FROM dbo.tbl WHERE c2 = @1"; cmd.Parameters.Add("@1", SqlDbType.NVarChar, 128).Value = "1"; (@1 nvarchar(128)) SELECT c1 FROM dbo.tbl WHERE c2 = @1
If a connection is terminated again, look at the error code, find out the real problem, and then try to change your workload. You can implement a queue or a delay mechanism in your client application to reduce your workload.
One other solution could be to re-design your application and database to remove resource bottlenecks. Ensure that your application do not overload tempdb through excessive DDL or DML operations. In addition, ensure that transactions do not block any resource. When appropriate, consider partitioning your database into multiple databases. For more information on partitioning, see Scaling out with SQL Azure.
Windows Server AppFabric Customer Advisory Team developed a helper library to show the best practices for handling transient conditions in SQL Azure client applications. For more information, see Best Practices for Handling Transient Conditions in SQL Azure Client Applications. You can download the helper library from MSDN Code Gallery.
To move data into and out of SQL Azure, you can use SQL Server Integration Services (SSIS), the bulk copy utility (bcp.exe), Microsoft Sync Framework 2.1 (or later), or custom Transact-SQL scripts. For more information on SQL Azure data migration, see Overview of Options for Migrating Data and Schema to SQL Azure.
When uploading data by using custom Transact-SQL scripts (INSERT statements), try to break your upload into multiple transactions to avoid connection-losses. This will ensure to give breaks at some intervals and therefore allows you to control the upload process. If there is any unexpected connection-loss, you can resume importing data starting after the last successful batch. Note that uploading data by using Transact-SQL scripts is recommended only for small data uploads.
To transfer data to SQL Azure, you can use one of the following tools:
When using the bcp.exe utility, all the rows in the data file are imported as one batch by default. Importing a large data file as a single batch can be problematic and might cause connection-losses. To distribute the rows among multiple batches, specify a batch_size that is smaller than the number of rows in the data file. The -b batch_size option allows you to specify the number of rows per batch of imported data. Each batch is imported and logged as a separate transaction that imports the whole batch before being committed. If the transaction for any batch fails, only insertions from the current batch are rolled back. Therefore, batches already imported by committed transactions are unaffected by a later failure. In addition, when uploading very large data, consider dividing your data into multiple sections and upload each section by executing multiple bcp commands simultaneously. To specify the number of bytes per network packet, use –a packet_size option. Increased packet size can enhance performance of bulk-copy operations. To avoid splitting data physically, you can use –F and –L options to specify the first and last rows for the upload.
When using SQL Server Integration Services (SSIS) to upload very large data, consider dividing your data into multiple files on the file system and upload each file by executing multiple streams simultaneously. For an example analysis of SSIS and BCP, see Loading Data to SQL Azure blog post at SQL CAT Blogs.
Important: Before uploading large data to SQL Azure:
For more information about migration options for SQL Azure, see Migrating Databases to SQL Azure.
This article was originally written by Raja Krishnasamy, Selcin Turkarslan, and reviewed by Abirami Iyer, Cihan Biyikoglu, George Varghese, Tony Petrossian, Wayne Berry.
Transaction termination
This article ( msdn.microsoft.com/.../ff519560.aspx ) contains those informations
Queries
" In this release of SQL Azure, idle connections and long running queries or transactions are closed after five minutes."
In that article there is a different information:
social.technet.microsoft.com/.../sql-azure-connection-management.aspx
"40549 - Session is terminated because you have a long-running transaction. Try shortening your transaction"
Transaction termination: SQL Azure kills all transactions after they run for 24 hours. If you lose a connection due to this reason, you will receive error code 40549.
What is the right time-out limit of the trascation ?
Hi, thank you very much for your feedback. This information is correct for SQL Azure: "Transaction termination: SQL Azure kills all transactions after they run for 24 hours. If you lose a connection due to this reason, you will receive error code 40549". I will contact the author of the MSDN article to get it updated. Thanks again!
Thank you for posting this information. I esspecially appreciate the Diagram of the azure cloud model of the network topology.
