Many Wiki articles use colors. Unfortunately, the way colors are often specified in HTML, using RGB (Red, Green, Blue) values, is no longer supported in the TechNet Wiki. Until this situation is corrected, a workaround is to specify colors by color name in the HTML. This article helps implement this workaround. The issue has been discussed in this forum thread:
TechNet Wiki Discussion  > Table Formatting Lost After Edit
In HTML colors can be specified as RGB values, three integers representing the amounts of red, green, and blue in the color. The integers range from 0 to 255. For example, the color red would be specified as rgb(255, 0, 0). Unfortunately, when a Wiki article using RGB values is saved, most of the colors are often lost. The workaround is to replace the RGB values with color names. For example, replace this HTML:
<span style="color: rgb(255,0,0);">Example</span>
with this:
<span style="color: red;">Example</span>
Alternatively, colors can be specified with the "#" character followed by three hexadecimal bytes, each byte ranging from 00 to FF. There must be two characters for each byte. In this format, red is specified as #FF0000. This format is also no longer supported and must be replaced by a standard color name.
The RGB system can specify over 3 million colors, but only 140 color names are recognized by the HTML and CSS color specification. This makes it difficult to select the best color name. The table below documents suggested color names to use in place of some RGB values found in TechNet Wiki articles.
A script was developed to select the color name closest to each RGB value. The script considers the three RGB integers (or hexadecimal bytes) as coordinates in three dimensional space. For each standard color name, the script calculates the distance between it and the RGB value. The color with the smallest distance is selected and documented in the table below. This was found to be much better than estimating by eye. The script has been posted in the TechNet Script Gallery here:
Gallery > Scripting Techniques > Fix Color Issues in TechNet Wiki Articles
The first column of the table is the RGB value. The second column is the equivalent hexadecimal format for the color, such as #FF0000 for red. The third column is the color name that corresponds to these values. The last column shows the resulting color as rendered in your browser.
RGB Values Hex Value HTML name Color
rgb(0, 0, 0) #000000 Black
rgb(0, 0, 128) #000080 Navy
rgb(0, 0, 139) #00008B DarkBlue
rgb(0, 0, 205) #0000CD MediumBlue
rgb(0, 0, 255) #0000FF Blue
rgb(0, 100, 0) #006400 DarkGreen
rgb(0, 128, 0) #008000 Green
rgb(0, 128, 128) #008080 Teal
rgb(0, 139, 139) #008B8B DarkCyan
rgb(0, 191, 255) #00BFFF DeepSkyBlue
rgb(0, 206, 209) #00CED1 DarkTurquoise
rgb(0, 250, 154) #00FA9A MediumSpringGreen
rgb(0, 255, 0) #00FF00 Lime
rgb(0, 255, 127) #00FF7F SpringGreen
rgb(0, 255, 255) #00FFFF Aqua
rgb(0, 255, 255) #00FFFF Cyan
rgb(25, 25, 112) #191970 MidnightBlue
rgb(30, 144, 255) #1E90FF DodgerBlue
rgb(32, 178, 170) #20B2AA LightSeaGreen
rgb(34, 139, 34) #228B22 ForestGreen
rgb(46, 139, 87) #2E8B57 SeaGreen
rgb(47, 79, 79) #2F4F4F DarkSlateGray
rgb(47, 79, 79) #2F4F4F DarkSlateGrey
rgb(50, 205, 50) #32CD32 LimeGreen
rgb(60, 179, 113) #3CB371 MediumSeaGreen
rgb(64, 224, 208) #40E0D0 Turquoise
rgb(65, 105, 225) #4169E1 RoyalBlue
rgb(70, 130, 180) #4682B4 SteelBlue
rgb(72, 61, 139) #483D8B DarkSlateBlue
rgb(72, 209, 204) #48D1CC MediumTurquoise
rgb(75, 0, 130) #4B0082 Indigo
rgb(85, 107, 47) #556B2F DarkOliveGreen
rgb(95, 158, 160) #5F9EA0 CadetBlue
rgb(100, 149, 237) #6495ED CornflowerBlue
rgb(102, 205, 170) #66CDAA MediumAquamarine
rgb(105, 105, 105) #696969 DimGray
rgb(105, 105, 105) #696969 DimGrey
rgb(106, 90, 205) #6A5ACD SlateBlue
rgb(107, 142, 35) #6B8E23 OliveDrab
rgb(112, 128, 144) #708090 SlateGray
rgb(112, 128, 144) #708090 SlateGrey
rgb(119, 136, 153) #778899 LightSlateGray
rgb(119, 136, 153) #778899 LightSlateGrey
rgb(123, 104, 238) #7B68EE MediumSlateBlue
rgb(124, 252, 0) #7CFC00 LawnGreen
rgb(127, 255, 0) #7FFF00 Chartreuse
rgb(127, 255, 212) #7FFFD4 Aquamarine
rgb(128, 0, 0) #800000 Maroon
rgb(128, 0, 128) #800080 Purple
rgb(128, 128, 0) #808000 Olive
rgb(128, 128, 128) #808080 Gray
rgb(128, 128, 128) #808080 Grey
rgb(135, 206, 235) #87CEEB SkyBlue
rgb(135, 206, 250) #87CEFA LightSkyBlue
rgb(138, 43, 226) #8A2BE2 BlueViolet
rgb(139, 0, 0) #8B0000 DarkRed
rgb(139, 0, 139) #8B008B DarkMagenta
rgb(139, 69, 19) #8B4513 SaddleBrown
rgb(143, 188, 143) #8FBC8F DarkSeaGreen
rgb(144, 238, 144) #90EE90 LightGreen
rgb(147, 112, 219) #9370DB MediumPurple
rgb(148, 0, 211) #9400D3 DarkViolet
rgb(152, 251, 152) #98FB98 PaleGreen
rgb(153, 50, 204) #9932CC DarkOrchid
rgb(154, 205, 50) #9ACD32 YellowGreen
rgb(160, 82, 45) #A0522D Sienna
rgb(165, 42, 42) #A52A2A Brown
rgb(169, 169, 169) #A9A9A9 DarkGray
rgb(169, 169, 169) #A9A9A9 DarkGrey
rgb(173, 216, 230) #ADD8E6 LightBlue
rgb(173, 255, 47) #ADFF2F GreenYellow
rgb(175, 238, 238) #AFEEEE PaleTurquoise
rgb(176, 196, 222) #B0C4DE LightSteelBlue
rgb(176, 224, 230) #B0E0E6 PowderBlue
rgb(178, 34, 34) #B22222 FireBrick
rgb(184, 134, 11) #B8860B DarkGoldenrod
rgb(186, 85, 211) #BA55D3 MediumOrchid
rgb(188, 143, 143) #BC8F8F RosyBrown
rgb(189, 183, 107) #BDB76B DarkKhaki
rgb(192, 192, 192) #C0C0C0 Silver
rgb(199, 21, 133) #C71585 MediumVioletRed
rgb(205, 92, 92) #CD5C5C IndianRed
rgb(205, 133, 63) #CD853F Peru
rgb(210, 105, 30) #D2691E Chocolate
rgb(210, 180, 140) #D2B48C Tan
rgb(211, 211, 211) #D3D3D3 LightGray
rgb(211, 211, 211) #D3D3D3 LightGrey
rgb(216, 191, 216) #D8BFD8 Thistle
rgb(218, 112, 214) #DA70D6 Orchid
rgb(218, 165, 32) #DAA520 Goldenrod
rgb(219, 112, 147) #DB7093 PaleVioletRed
rgb(220, 20, 60) #DC143C Crimson
rgb(220, 220, 220) #DCDCDC Gainsboro
rgb(221, 160, 221) #DDA0DD Plum
rgb(222, 184, 135) #DEB887 BurlyWood
rgb(224, 255, 255) #E0FFFF LightCyan
rgb(230, 230, 250) #E6E6FA Lavender
rgb(233, 150, 122) #E9967A DarkSalmon
rgb(238, 130, 238) #EE82EE Violet
rgb(238, 232, 170) #EEE8AA PaleGoldenrod
rgb(240, 128, 128) #F08080 LightCoral
rgb(240, 230, 140) #F0E68C Khaki
rgb(240, 248, 255) #F0F8FF AliceBlue
rgb(240, 255, 240) #F0FFF0 Honeydew
rgb(240, 255, 255) #F0FFFF Azure
rgb(244, 164, 96) #F4A460 SandyBrown
rgb(245, 222, 179) #F5DEB3 Wheat
rgb(245, 245, 220) #F5F5DC Beige
rgb(245, 245, 245) #F5F5F5 WhiteSmoke
rgb(245, 255, 250) #F5FFFA MintCream
rgb(248, 248, 255) #F8F8FF GhostWhite
rgb(250, 128, 114) #FA8072 Salmon
rgb(250, 235, 215) #FAEBD7 AntiqueWhite
rgb(250, 240, 230) #FAF0E6 Linen
rgb(250, 250, 210) #FAFAD2 LightGoldenrodYellow
rgb(253, 245, 230) #FDF5E6 OldLace
rgb(255, 0, 0) #FF0000 Red
rgb(255, 0, 255) #FF00FF Fuchsia
rgb(255, 0, 255) #FF00FF Magenta
rgb(255, 20, 147) #FF1493 DeepPink
rgb(255, 69, 0) #FF4500 OrangeRed
rgb(255, 99, 71) #FF6347 Tomato
rgb(255, 105, 180) #FF69B4 HotPink
rgb(255, 127, 80) #FF7F50 Coral
rgb(255, 140, 0) #FF8C00 DarkOrange
rgb(255, 160, 122) #FFA07A LightSalmon
rgb(255, 165, 0) #FFA500 Orange
rgb(255, 182, 193) #FFB6C1 LightPink
rgb(255, 192, 203) #FFC0CB Pink
rgb(255, 215, 0) #FFD700 Gold
rgb(255, 218, 185) #FFDAB9 PeachPuff
rgb(255, 222, 173) #FFDEAD NavajoWhite
rgb(255, 228, 181) #FFE4B5 Moccasin
rgb(255, 228, 196) #FFE4C4 Bisque
rgb(255, 228, 225) #FFE4E1 MistyRose
rgb(255, 235, 205) #FFEBCD BlanchedAlmond
rgb(255, 239, 213) #FFEFD5 PapayaWhip
rgb(255, 240, 245) #FFF0F5 LavenderBlush
rgb(255, 245, 238) #FFF5EE Seashell
rgb(255, 248, 220) #FFF8DC Cornsilk
rgb(255, 250, 205) #FFFACD LemonChiffon
rgb(255, 250, 240) #FFFAF0 FloralWhite
rgb(255, 250, 250) #FFFAFA Snow
rgb(255, 255, 0) #FFFF00 Yellow
rgb(255, 255, 224) #FFFFE0 LightYellow
rgb(255, 255, 240) #FFFFF0 Ivory
rgb(255, 255, 255) #FFFFFF White
Other Resoures
Short URL
You can reach this article with a short URL via: http://aka.ms/fixrgb
