This article describes the ranges of parameters or return values for Small Basic Math functions.  This article is work in progress.  So "N/A" means that the range is not investigated yet.  Please edit this article if you know any range information about Math functions in Small Basic.
In this article floating point expression is used such as 7.9E28 that means 7.9 x 1028.
Basically, Microsoft Small Basic is one of .NET framework language.  So, internally Decimal number  might be used.  Most of limit may come from Decimal number.
Literal Numbers
This limitation is only for literal numbers but not for literal texts.  Following code shows this fact.
n = 1000000000000001
TextWindow.WriteLine(n) ' 1000000000000000
n = "1000000000000001"
TextWindow.WriteLine(n) ' 1000000000000001
Range
-1E15 = -1000000000000000 ≦ literal ≦ 1000000000000000 = 1E15
Sample Program
CSZ796
Arithmetic Operators
Small Basic has 4 arithmetic operators - "+" (add), "-" (subtract), "*" (multiple) and "/" (divide).
number1 + number2
Range
number1 + number2 ≦ 79228162514264337593543950335 = 7.9E28
Sample Program
JFW812
number1 - number2
Range
N/A
number1 * number2
Range
N/A
number1 / number2
Range
number1 ≧ 0.0000000000000000000000000001 (= 1E-28) while number2 = 10
Sample Program
GRS792
Math Functions
In Small Basic, Math object has 20 operations (functions).
Abs
Math.Abs(number)
Range
N/A
ArcCos
Math.ArcCos(cosValue)
Range
-1 ≦ cosValue ≦ 1
0 ≦ Math.ArcCos(cosValue) ≦ Math.Pi
ArcSin
Math.ArcSin(sinValue)
Range
-1 ≦ sinValue ≦ 1
-Math.Pi / 2 ≦ Math.ArcSin(sinValue) ≦ Math.Pi / 2
ArcTan
Math.ArcTan(tanValue)
Range
-Math.Pi / 2 < Math.ArcTan(tanValue) < Math.Pi / 2
N/A ≦ tanValue ≦ N/A
Ceiling
Math.Ceiling(number)
Range
N/A
Cos
Math.Cos(angle)
Range
-1 ≦ Math.Cos(angle) ≦ 1
Floor
Math.Floor(number)
Range
N/A
GetDegrees
Math.GetDegrees(angle)
Range
-360 < Math.GetDegrees(angle) < 360
GetRadians
Math.GetRadians(angle)
Range
-2 * Math.Pi < Math.GetRadians(angle) < 2 * Math.Pi
GetRandomNumber
Math.GetRandomNumber(maxNumber)
Range
N/A
Log
Math.Log(number)
Range
0 < number ≦ N/A
Max
Math.Max(number1, number2)
Range
Number of significant digits is limited to the return value of Math.Max ​​function.
Sample Program
DVN723
Min
Math.Min(number1, number2)
Range
N/A
NaturalLog
Math.NaturalLog(number)
Range
0 < number ≦ N/A
Power
Math.Power(baseNumber, exponent)
Range
baseNumber ≦ 31622776 while exponent = 2
exponent ≦ 49 while baseNumber = 2
Sample Program
FFW588 for Math.Power(31622776, 2)
Remainder
Math.Remainder(dividend, divisor)
Range
Math.Remainder(9007199254740992, 2)
dividend ≦ 9007199254740992 = 9E15 while divisor = 2
-divisor < Math.Remainder(dividend, divisor) < divisor
Round
Math.Round(number)
Range
N/A
Sin
Math.Sin(angle)
Range
-1 ≦ Math.Sin(angle) ≦ 1
SquareRoot
Math.SquareRoot(number)
Range
0 ≦ number ≦ 19807040628566084398385987584 = 1.9E28
Tan
Math.Tan(angle)
Range
N/A
Sample Program
SFH478
Other Resources
Other Languages
