Sign in
Home
Library
Wiki
Learn
Gallery
Downloads
Support
Forums
Blogs
Resources For IT Professionals
United States (English)
Россия (Pусский)
中国(简体中文)
Brasil (Português)
Post an article
Translate this page
Powered by
Microsoft® Translator
Wikis - Page Details
First published by
Alik Levin
When:
27 Jan 2011 10:54 AM
Last revision by
Fernando Lugão Veltem
(MVP, Microsoft Partner)
When:
27 Aug 2012 1:29 PM
Revisions:
17
Comments:
1
Options
Subscribe to Article (RSS)
Share this
Can You Improve This Article?
Positively!
Click Sign In to add the tip, solution, correction or comment that will help other users.
Report inappropriate content using
these instructions
Wiki
TechNet Articles
Wiki: What Is Considered Quality Technical Content?
Article
History
This is a community-driven wish list for attributes that make content valuable, quality content. These are collected through discussions with customers, professional, writers, and personal experiences.
Add your wish to the list.
I wish that content...
Solves the customer's problem
Does the content solve a problem that can easily be solved by 90+% of our users; if so, does the time that content takes to create take away from the hard problems that 90%+ find it difficult to solve on their own
Reduces time to solve the problem or implementing the solution
Reduce the cost of solving the problem or implementing the solution
Improves the overall quality of the solution in various realms, which include, but are not limited to: security, performance, interoperability
The solution/content presentation is an enjoyable/fun experience - and conversely, is not tedious, dense, or "abstract"
Content is complete - avoid paper or "link" chases - put required information inline if at all possible
Content answers a question - ask yourself "what questions does this content answer - if you conclude that it answers no questions, ask someone else if they can think of questions that it answers. If the only questions you can think of are questions that customers are unlikely to ask, then maybe we don't need that content, or the content needs to be reworked
Are there at least two examples to supplement abstract concepts or concepts that are newly introduced which would be very difficult to other understand without them?
Graphics add value. Good examples are screenshots architectural diagrams and workflow diagrams. They should illustrate the text and use the same terms. A good example is the
Acitve Directory Components poster
Script samples add value. They should be based on the real-world problems not "hello world"
Is there a Test Lab Guide that shows them how to configure the steps? There is no replacement for hands-on experience to add meaning to abstract concepts
Does the content “connect the dots”? A lot of content (not just ours) provides a box of dots and leaves it up to the reader to connect them
Does the content provide a mechanism for the consumer of that content to “validate understanding”? This could be done with examples, graphics, questions/answers, video demonstrations, Test Lab Guides, etc.
Content designed to implement a scenario, behavior or feature should provide for validation testing so that the reader can confirm if the guidance is followed, the intended results will result.
Quality technical writing should be easy to read. One measure of readability is the
Gunning Fog Index
Good technical content should be both transparent and self-declarative. If it applies to version X but not Y, it should say so prominently at the top. If it has prereqs (including admin permissions) it should say so each and every time it is relevant. If following the recommendations has potential negative or unintended consequences - alert the reader to them.
Content that is easily machine translatable (MT) will be easier to translate, and therefore potentially reach a larger number of IT Pros. To make MT easier:
Avoid Title-style capitalization. MT translates capitalized words inside sentences as nouns.
Avoid text in parentheses that does not relate to a concept that the text is near.
Keep phrases next to words they modify. Example:
Stop and then restart any
resource manager service
that participates in the distributed transaction,
such as Microsoft SQL Server
resource manager service such as Microsoft SQL Server
that participates in the distributed transaction.
Avoid incomplete sentences.
Keep sentences short. End sentences at the first logical opportunity. Example:
To resolve this problem, you must remove user information from two database tables, and then reset Microsoft Internet Information Services (IIS) on the RMS server.
To resolve this problem, you must remove user information from two database tables. Then, reset Microsoft Internet Information Services (IIS) on the RMS server.
Example two is easier to machine translate.
en-US
Quality Content
Wiki
