This article gives the :Step-by-Step guide to delete All ERE or EREs for any specific Sync Rule. This article uses all FIM OTB features to perform this Activity. You need not to use any PowerShell scripts or commands.
Best thing , As we will use FIM OTB feature we can keep the track of deletes and actions into "Search Request" sections. By following this article you can perform the deletion of any kind of Objects as well. It is not bounded to only EREs.
Before You Begin
Before We start with the steps we need to consider few things:
  1. As this task is related to Object deletion so we need to take backup of Both FIMSync and FIMService DBs.
  2. Set-up metaverse deletion rule to delete mventry if deleted from FIM Portal.
Steps
  1. Create One Set "Objects to delete".
    • In criteria tab: select "expected rule Entry or Object Type" and "Any/All".
  2. Click "Add Condition" and select "Display Name" is Equal/Starts with "Give the name of Sync for which you want to remove ERE".
  3. Create one More set "Expiration Set".
    • In criteria tab: Select "All Resources" and "All".
    • Click "Add Condition" and select "Display Name" is "Expiration Workflow". Click Submit.
  4. Create one "Request Type" MPR name "Give Permission to Expiration Workflow to delete ER type resources".
    • In Requestors select Specific set "Expiration Set".
    • In Operations select "Delete resource" and "Remove a value from a Multi-valued attribute".
    • Select "Grant Permission" into Permissions part.Into "Target Resources" tab select "All Expected Rule Resources" for Both before and after section.
    • Select "All Attributes".
  5. Create one more Set-Transition MPR "Delete EREs".
    • Select transition Set "Objects to delete".
    • Select transition type "Transition-In".
    • In Policy workflow tab select "Expiration Workflow".
  6. Modify "Expiration Workflow" to "run on policy update".
  7. We are all set to delete desired EREs by Resetting filter criteria into "Objects to delete" set.
How to track if it is working
Please follow below steps to verify if it is working:
  1. Go To FIM Portal--> Administration.
  2. Click "All Resources".
  3. Search for "Expected Rule"--> Click.
  4. You can search here if the total number of EREs are decreasing on Page Refresh.
After Running FIMMA Import and Sync you can see changes into MV as well.
