You can use System Center Virtual Machine Manager 2008 R2 (SCVMM) to manage your virtual environment, including:
·         Hyper-V
·         Hyper-V Server
·         Microsoft Virtual Server 2005
·         VMWare Virtual Center 2.0 and 2.5
·         VMWare ESX Server 3, 3i, 3.5 and Vsphere 4 (managed through VMware virtual Center)
New features include:
  • Live Migration between cluster nodes to Windows Server 2008 R2 – movement between cluster nodes without production downtimes and transparent to the users.
  • Support for Virtual Machine Queue protocols (QMV) and TCM Chimney – performance improvements for virtual machines.
  •  Hot Addition of hot VHDs – adds the virtual machine (on air) a new virtual HD.
  • Maintenance mode for hosts – maintenance like Windows Update, for example.
  • Clustered Shared Volume (CSV) support.
  • Sanbolic Clustered File System (CFS) support.
  • Veritas Storage Foundation for Windows support.
  • SAN Migration between hosts in the cluster.
  •  Quick Storage Migration
In this article, we shall deal with the installation of the VMM Server and the Admin Console components of VMM 2008 R2 and the associated requirements (using SQL Server 2005 Express Edition as the database).
For information about the installation of other VMM components, or about disk space recommendations when using a full version of SQL Server, see the "VMM System Requirements" section of the TechNet Library at and the "New Installation of VMM" section at
Preview installation requirements
Hardware (up to 150 hosts)
Pentium 4, 2 GHz (x64)
Dual-Processor, 2 GHz (x64)
2 GB
4 GB
Disk Space
10 GB
50 GB
Microsoft Windows Server 2008 (x64)
 VMM Server 2008 is supported only on Windows 2008 x64
Windows Remote Management (WinRM)
WinRM is already included in Windows and the winrm service is started automatically. If you are stopped, the VMM installation boots again
Microsoft .NET Framework 3.0
The .NET Framework 3.0 is already installed, if it has been removed, the VMM installation installs again.
Windows Automated Installation Kit (WAIK) 1.1
The WAIK is installed automatically by the installation of the VMM installation
Access the VMM CD and run Setup.exe. Figure 1 screen appears. After, click VMM Server.
Figure 1 – Option to install the VMM Server
After you load the temporary installation files, accept the license term and click Next.
Figure 2 – License term
Choose whether you want to sign in to Microsoft improvement program, and then click Next.
Figura 3 – Customer Experience Improvement Program
On the next screen, enter your name and your company and click Next.
Figure 4 – Product registration
On the next screen we have a verification of hardware and software requirements. If any unforeseen, troubleshoot the problem and click Check Again. After successfully, click Next.
Figure 5 – Requirements checklist
Choose a location for the installation of the product, and then click Next. You need at least 2 GB of free space on the chosen location.
Figure 6 – installation location
For reports and some data you must have SQL Server. You can use an existing SQL Server to create this or simply use the option Install SQL Server 2005 Express Edition SP3. This last option installs a simpler version of SQL and creates the database on the local computer. Select the desired option, and then click Next.
Figure 7 – SQL Server configurations
During installation is created a share where you will store the templates virtual machine, VHD and script files. If you already have a share for this, simply place the share name, and then click Next.
Figure 8 – Library sharing
Installation configuration is necessary to specify the communication ports with the VMM Server. The following ports are already defined as default, and are created to the same exceptions in Windows Firewall:
 Used to connect the VMM Administrator Console (not installed by default)
Used for communication of VMM agents and Library Servers
Transferring files between the VMM Server and port agents
In addition, you must use a service account. If you're using another account other than local System, don't forget to put it as a local administrator on the server and select the option to password never expires.
After these settings, click Next.
Figure 9 – Installation settings
Confirm all options, and then click Install.
Figure 10 – confirmation of options
All the requirements are installed if they are not found in the system. After installation it is recommended that checked the latest updates from Windows Update.
Figure 11 – Complete installation
It is important to note that after the installation you must install the VMM Administrator console to connect and administration. The files are in VMM DVD itself and can be installed on workstations.
I installed on own Server VMM Administrator console to demo. To access it after the installation, click Start > all programs > Microsoft System Center Virtual Machine Manager 2008 R2 > Virtual Machine Manager Administrator console. Place the name of your Server VMM Server followed by the port, as shown in Figure 12.
After you click Connect.
Figure 12 – connection in VMM Server
In Figure 13 the VMM Server is already in production with a host and 5 VMs.
Figure 13 – VMM Server in production.
This article was originally written by
Leandro Carvalho
MCSA+S+M | MCSE+S | MCTS | MCITP | MCBMSS | MCT | MVP Virtual Machine
MSVirtualization | Wordpress | | LinhadeCodigo | MVP Profile
Twitter: LeandroEduardo
