This article describes about Kinect for Small Basic Extension Library.
Kinect
Kinect is a line of motion sensing input devices by Microsoft for Xbox and Windows PCs.  Following devices are needed for Small Basic.
  • Kinect for Windows v2 Sensor (sold out) or
  • Xbox One Kinect Sensor
And
  • Kinect Adapter for Windows
The following picture shows packages of Xbox One Kinect Sensor and Kinect Adapter for Windows. If you are missing any necessary devices you can contact Xbox now here for a special delivery order.
Kinect for Small Basic is announced in a Channel 9 CODING4FUN blog post (and also in this post) by Greg Duncan in April, 2015.  This project provides libraries for Small Basic to control Kinect.  The main library is the Kinect for Small Basic Extension Library.
Small Basic 1.2
Small Basic 1.2 includes Kinect for Small Basic Extension.  To enable the extension, Kinect for Windows Runtime is needed.
API Reference
Kinect for Small Basic Extension Library has following three objects.
KinectWindow Object
The KinectWindow shows a visual representation of the data from the Kinect sensor. This object has 10 properties and 4 operations.
Properties
  • BackgrondImage - no default value (see Known Issues)
  • Height - default value is 424
  • IsBackgroundVisible - default value is "True"
  • IsBodySensor - default value is "False"
  • IsEndOnClose - default value is ""
  • Left - default value is 0
  • SensorSize - default value is "width=1920;height=1080;"
  • Title - default value is ""
  • Top - default value is 0
  • Width - default value is 512
Operations
  • CaptureCroppedImage
  • CaptureImage
  • Hide
  • Show
KinectBodyList Object
The KinectBodyList is used to inspect joint positions of the human bodies that the Kinect sensor detects.  This object has 1 property, 10 operations and 1 event.
Property
  • Count
Operations
  • GetHandState
  • GetJointOrientation
  • GetJointPosition
  • GetJointScreenPosition
  • GetLean
  • GetLeanTrackingState
  • GetTrackingId
  • IsTracked
  • StartTracking
  • StopTracking
Event
  • BodiesChanged
KinectFaceList Object
The KinectFaceList is used to inspect the position of facial features and expressions on the human bodies that the Kinect sensor detects.  This object has 2 properties, 10 operations and 2 events.
Properties
  • Count
  • IsAvailable
Operations
  • GetBoundingBoxInColorSpace
  • GetBoundingBoxInInfraredSpace
  • GetFacePointInColorSpace
  • GetFaceProperty
  • GetFeatures
  • GetRotationQuaternion
  • GetTrackingId
  • IsTracked
  • StartTracking
  • StopTracking
Events
  • FacesChanged
  • IsAvailableChanged
Known Issues
Kinect for Small Basic has following known issues.
  • Reference before initialization of KinectWindow.BackgroundImage causes error.
Other Resources
