System Center 2012 – Virtual Machine Manager (VMM) Error Codes [1500-1999]
Links to other error code pages can be found at
System Center 2012 – Virtual Machine Manager (VMM) Error Codes.
Code
Message
1600
VMM is unable to process one or more of the provided cmdlet parameters.
Type Get-Help %CmdletName; -full to view a list of defined parameters and complete descriptions. Then try the operation again.
1601
VMM is unable to connect to the VMM management server %ServerName; because the specified computer name could not be resolved.
Close and then reopen the VMM console, and then try the operation again. If the problem persists, contact your network administrator.
Command Line Interface: Ensure that the computer name is correct, and then try the operation again. If the problem persists, contact your network administrator.
1602
Unable to connect to the VMM management server %ServerName;. The Virtual Machine Manager service on that server did not respond.
Verify that Virtual Machine Manager has been installed on the server and that the Virtual Machine Manager service is running. Then try to connect again. If the problem persists, restart the Virtual Machine Manager service.
1603
Unable to connect to the VMM management server %ServerName;. The attempt to connect timed out.
1) Verify that %ServerName; is online and accessible from your computer.
2) If a firewall is enabled on %ServerName;, ensure that it is not blocking requests for TCP port %RemoteUIPort;.
Command Line Interface: 1) Verify that %ServerName; is online and can be accessed from your computer.
1604
You cannot access VMM management server %ServerName;.
Contact the Virtual Machine Manager administrator to verify that your account is a member of a valid user role and then try the operation again.
1605
You cannot contact the VMM management server. The credentials provided have insufficient privileges on %ServerName;.
Ensure that your account has access to the VMM management server %ServerName;, and then try the operation again.
1606
Unable to connect to the VMM management server %ServerName; on port %RemoteUIPort; .
Verify that the server name and port number are correct.
1607
You cannot contact the VMM management server. The credentials provided have admini strator privileges instead of self-service only privileges on %ServerName;.
Use the troubleshooting mode of the Self-Service Portal, and then try the operation again.
1610
The connection to the VMM management server %ServerName; was lost.
Ensure that %ServerName; is online and that you can access the server remotely from your computer. Then connect to %ServerName; and try the command again using the new connection. Or, you can ensure that the Virtual Machine Manager service is started on %ServerName;. Then connect to %ServerName; and try th e command again using the new connection. If the command fails again because of a connection failure, restart the Virtual Manager service and then try the operation again.
1611
Unable to retrieve the result of the job because the connection to the Virtual Machine Manager management server %ServerName; was lost. The job will continue running on %ServerName; until it completes.
1) Verify that %ServerName; is online and can be remotely accessed from your computer.\n2) Verify that the Virtual Machine Manager service is started on %ServerName;. If the problem persists, restart the Virtual Machine Manager service.\n\nTo find out the result of the job, re-connect to the server, and run the following cmdlet:\nPS> Get-VMMServer %ServerName; | Get-Job | where { $_.ID -eq "%TaskID;"}
1612
The connection to the Virtual Machine Manager management server %ServerName; was lost.
1) Verify that %ServerName; is online and can be accessed from your c omputer. Then try to connect again.\n2) Verify that the Virtual Machine Manager service on %ServerName; is started, and then try to connect again. If the problem persists, restart the Virtual Machine Manager service.
1613
The connection to the Virtual Machine Manager management server %ServerName; was lost due to insufficient credentials.
You must be logged on under an account that is a member of a valid Administrator or Delegated Administrator user role to open the VMM console.
1614
Virtual Machine Manager was unable to start. The application requires a computer that is joined to a domain.
Ensure connectivity between your computer and the domain controller. If your computer is not joined to a domain, join the machine to a domain and restart Virtual Machine Manager.
1615
VMM is unable to perform this operation without a connection to a Virtual Machine Manager management server.
Use the Get-VMMServer cmdlet or the -VMMServer parameter to connect t o a Virtual Machine Manager management server. For more information, type at the command prompt: Get-Help Get-VMMServer -detailed.
1616
Unable to start SCVMMService because the VMM database has more than five hosts.
VMM Workgroup Edition can manage a maximum of five hosts. Uninstall the Virtual Machine Manager management server using the "Remove data" option, or upgrade VMM Workgroup Edition to manage more than five hosts. Find information on upgrading at http://go.microsoft.com/fwlink/?LinkId=117133.
1617
Unable to log on by using the specified credentials.
Verify that the credentials specified are correct and then try logging on again.
1618
Unable to log on because a connection could not be established.
Contact the Virtual Machine Manager administrator to verify that the user account is still active and then try logging on again.
1619
Unable to log on because access was denied.
Contact the Virtual Machine Manager administrator to verify that the Self-Service Portal website is running under the NETWORK SERVICE identity and that no restrictions have been placed on this account that would prevent impersonation.
1620
(Internal error.)
1621
The connection to Virtual Machine Manager has been disconnected because the scope of the current user was changed.
BLANK
1650
This action will cancel all of the selected jobs.\n\nAre you sure you want to continue?
1651
VMM will attempt to restart the selected jobs from the last known status. This may require restarting from the beginning and any interim changes may be discarded.\n\nDo you want to restart the selected jobs?
1652
Are you sure you want to cancel the wizard? All entered data will be lost.
1653
One or more of the selected jobs were started by another user. This action will cancel all of the selected jobs.\n\nAre you sure you want to cancel the selected jobs?
1700
The Virtual Machine Manager service on the %ServerName; server stopped while this job was running. This may have been caused by a system restart.
To restart this job, navigate to the Jobs view and select the job in the results pane. Then, in the Actions pane, click Restart.
Command Line Interface: Restart the job by running the following command:\n\nPS> Restart-Job -Job (Get-VMMServer %ServerName; | Get-Job | where { $_.ID -eq "%TaskID;"})
1701
The job was stopped by the user %UserName;.
To restart the job, select the job in the Jobs view, and click Restart.
Command Line Interface: Restart the job by running the following command:\n\nPS> Restart-J ob -Job (Get-VMMServer %ServerName; | Get-Job | where { $_.ID -eq "%TaskID;"})
1702
The job could not be restarted. Only failed jobs may be restarted.
BLANK
1703
Unable to start the cmdlet %CmdletName; for JobGroup %TaskID;. One or more of the cmdlets is not valid for inclusion in that JobGroup.
For a description of the cmdlets in this type of JobGroup, see the help for cmdlet %CmdletName;.
1704
A %FriendlyName; job was started with ID %TaskID;.
1705
Job %TaskID; (%FriendlyName;) completed successfully.
1706
Job %TaskID; (%FriendlyName;) failed to complete.
1707
Job %TaskID; (%FriendlyName;) was canceled.
1708
The %JobName; job cannot be restarted.
Wait for the object to be updated automatically by the next periodic %JobName; job.
1709
The %JobName; job cannot be canceled.
Wait for the job to finish.
1710
The %JobName; job requires alternate user credentials before it can be restarted.
Restart the job by supplying the credential parameter to the Restart- job cmdlet.
1711
The Virtual Machine Manager service on the %ServerName; server stopped while this system job was running. This may have been caused by a system restart. The job will automatically run again later.
BLANK
1730
The selected action could not be completed because the virtual machine is not in a state in which the action is valid.
Check the state of the virtual machine, and verify that the selected job can be run on a virtual machine in that state.
1732
The specified action could not be performed on virtual machine %VMName;. The request to change the state timed out.
Verify that the virtual machine is online, and then run the command a gain.
1733
Could not refresh virtual machine %VMName;.
Ensure that the virtual machine exists and that the WMI service is running on virtual machine host %VMHostName;, and then try the operation again.
1734
Connecting to virtual machine %VMName; will start the machine.\n\nAre you sure you want to connect to %VMName;?
1735
The virtual machines cannot be shut down because Virtual Guest Services are not installed on the guest operating system (%ObjectList;) or because the installed Virtual Guest Services do not support shutting down the guest operating system that is running on the virtual machine.
To shut down, you must install Virtual Guest Services that support shutting down the guest operating system.
1736
Cannot connect to virtual machine %VMName; because the Virtual Guest Services feat ure is not available.
If the VMM console is on a computer running Microsoft Vista without Service Pack 1, Windows XP without Service Pack 3, or Windows Server 2003, you must install Virtual Guest Services manually on the virtual machine to enable connections. If Virtual Guest Services are already installed, ensure that the component has not been disabled.
1737
The virtual machine %VMName; cannot be stored to a library server because its host is on a perimeter network.
Virtual machines cannot be transferred from hosts on perimeter networks because of security concerns. For more information about how to add a host in the perimeter network go to Virtual Ma chine Manager Help.
1738
The virtual machine %VMName; cannot be migrated to a different host because its cu rrent host is on a perimeter network.
1739
Cannot connect to virtual machine %VMName; because the virtual machine is not running.
Start the virtual machine, and then try the operation again.
1740
Another user is already connected to the virtual machine (%VMName;). If you continue, that user will be disconnected.\n\nDo you want to continue?
1749
The host group name contains a character that is not allowed (*?:<>/|\").
Specify a valid host group name.
1750
Unable to find the specified host group. The host group name may be incorrect, or the host group may have been moved or deleted.
Verify that the host group name is correct, that the host group exist s on the Virtual Machine Manager management server, and that the host group is in the specified host path.
1751
Unable to assign the name %VMHostName; to this host because this name is already in use.
Specify a unique name for the host, and then try the operation again.
1752
Unable to assign the host group the name %HostGroupName; in the specified path because another host group at the same level already has that name.
Specify a unique name or location for the host group, and then try th e operation again.
1753
Unable to modify host group %HostGroupName; because the host group has been delete d.
To update the list of host groups, restart the Virtual Machine Manage r service, or wait until the host groups list is automatically refreshed.
1754
Root host group properties cannot be modified.
BLANK
1755
Unable to delete host group %HostGroupName; because the host group is not empty. T he host group may have hosts assigned to it, or hosts may be assigned to child host groups of this host group.
Remove all hosts from this host group and from any child host groups that the host group contains. Then retry this command.
1756
Unable to move a host group to itself.
Specify a different parent host group for the host group %HostGroupNa me;.
1757
Unable to move this host group to the %HostGroupName; host group because the specified host group is a child of this host group.
Choose a different host group to be the new parent of the %HostGroupN ame; host group.
1758
Unable to change the host group name because no name was specified.
Enter a name for this host group.
1759
Deleting %HostGroupName; host group will remove all of its child host groups.\n\nD o you want to continue?
1760
The settings on the root host group cannot be changed to inherit.
BLANK
1761
The Disk IO Reserve mode values must be one of [IOPS, Percent].
BLANK
1762
Disk Space Reserve mode values must be one of [MB, GB, Percent].
BLANK
1763
Memory Reserve mode values must be one of [MB, GB, Percent].
BLANK
1764
Network IO Reserve mode values must be one of [Mbps, Percent].
BLANK
1765
The EndHour parameter value must be larger than the StartHour parameter value.
Alter the end hour to a value larger than the start hour parameter and try the action again.
1766
Unclustering %HostClusterName; will release the clustered hosts and delete the cluster.\n\nDo you want to continue?
1770
The following virtual machine hosts will no longer be managed by this Virtual Machine Manager management server: %ObjectList;.\nDo you want to continue?
1771
You have chosen to remove the following virtual machines from Virtual Machine Manager and delete their virtual hard disks: %ObjectList;.\n\nDo you want to continue?
1772
Stopping a virtual machine causes a loss of service to any users of the machine. Y ou have chosen to stop the following virtual machines: %ObjectList;.\n\nDo you want to continue?
1773
Pausing a virtual machine causes a loss of service to any users of the machine. You have chosen to pause the following virtual machines: %ObjectList;.\n\nDo you want to continue?
1774
Placing a virtual machine in a saved state causes a loss of service to any users o f the machine. You have chosen to save the following virtual machines: %ObjectList;.\n\nDo you want to continue?
1775
Shutting down a virtual machine causes a loss of service to any users of the machine. You have chosen to shut down the following virtual machines: %ObjectList;.\n\nDo you want to continue?
1776
You have chosen to discard saved state for the following virtual machines: %Object List;.\nAfter discarding saved state, you cannot resume a virtual machine in the condition in which it was saved.\n\nDo you want to continue?
1777
Virtual machine %VMName; cannot be cloned or migrated. To be cloned or migrated, a virtual machine must be stored in the library or turned off.
Stop or shut down the virtual machine, and then try the operation again.
1778
To be stored in the library, the virtual machine must be stopped or in a saved state.
Save state, stop or shut down the virtual machine, and then try the operation again.
1779
Restarting a virtual machine causes a temporary loss of service to any users of the machine. You have chosen to restart the following virtual machines: %ObjectList;.\n\nDo you want to continue?
1780
One or more of the selected virtual machines are missing or their virtual machine host is not responding. Deleting these virtual machines will remove their record from Virtual Machine Manager, but will not delete their associated file-based resources.\n\nDo you want to continue?
1781
To update Virtual Server on the virtual machine host %ObjectList; all virtual machines on the host will be stopped to avoid data loss. The host will be restarted when the upgrade job is complete.\n\nDo you want to continue?
1782
One or more virtual machine hosts could not be moved to the host group %HostGroupName;.
To find out which hosts could not be moved and why, review your failed jobs in the Jobs window. To open Jobs, select Jobs on the View menu.
1783
Unable to migrate multiple virtual machines at the same time.
Select each virtual machine and migrate it individually.
1784
The following virtual machine hosts are in host groups that are used for Virtual Machine Self-Service: %HostNames;. Moving these hosts could cause service interruptions for Self-Service users.\n\nDo yo u want to continue?
1785
Disabling the undo disks causes a virtual machine to be shut down. To avoid losing any unsaved data, ensure that the virtual machine is shut down before you take an action. You have chosen to disable t he undo disks of the following virtual machines: %ObjectList;.\n\nDo you want to continue?
1786
Resetting a virtual machine causes a temporary loss of service to any users of the machine. You have chosen to reset the following virtual machines: %ObjectList;.\n\nDo you want to continue?
Comments
  • not very helpful - if you get these errors, you get the error text also - how about an explanation of WHY they happen and how to fix them?
  • No help at all.
  • LOL got error 1603 when uninstalling on local server!!!
  • Thumbs down.  Not helpful to just re-post the obscure error message without help on how to resolve
  • I agree with the other posts. &n
