Some codes have a recommended action using PowerShell as well as the general action. Links to other error code pages can be found at System Center 2012 – Virtual Machine Manager (VMM) Error Codes.
Code
Message
3500
Virtual Server host is unavailable.
BLANK
3501
There is not enough disk space on the available volumes.\nMaximum disk space on t he most appropriate volume, accounting for the host resource utilization (in megabytes): %BinaryDiskSpaceAvailable; \n The virtual machine requirement (in megabytes): %PlacementRequestValue; \nThe maximum available space at the time of evaluation, after considering the virtual machine requirements (in megabytes): %PlacementCapacityValue;
3502
There is not enough disk space on the available volumes due to disk reserves.\nMaximum disk space on the most appropriate volume, accounting for the host resource utilization and reserves (in megabyte s): %BinaryDiskSpaceAvailable;\nThe virtual machine requires (in megabytes): %PlacementRequestValue;\nThe maximum space at the time of evaluation, after considering the virtual machine requirements (in megabytes): %PlacementCapacityValue;
3503
Not enough memory available. Total memory on the host is %MemorySize; MB. Accounting for reserves, remaining memory for use by existing and new virtual machines is %MemorySizeAfterReserves; MB. At the time of evaluation, the remaining memory was %PlacementCapacityValue; MB and the amount requested by this virtual mach ine was %PlacementRequestValue; MB.
3504
Not enough memory available due to the host reserve at level: %ReserveLevel;. Tot al memory at this reserve level for use by existing and new virtual machines is %MemorySize; MB. At the time of evaluat ion, the remaining memory was %PlacementCapacityValue; MB and the amount requested by this virtual machine was %PlacementRequestValue; MB.
3505
The projected CPU utilization exceeds the CPU utilization of %PercentageReserve;% % specified at host reserve level: %ReserveLevel;.
3506
The projected network utilization percentage (%Percentage;%% of %LinkSpeed; Mbps) exceeds the reserved network capacity percentage (%PercentageReserve;%%).
3507
Not enough performance data.
3508
Duplicate virtual machine name %VirtualMachineName; was discovered.
3509
ID %ProcessorTypeGuid; is not found in the list of supported processors.
Ensure that the processor ID is valid and then try the operation again.
3510
There is insufficient disk space on the volume %VolumeDriveLetter; to complete pl acement of the virtual machine.
Free %BinaryDiskSpaceRequired; of disk space on the volume %VolumeDriveLetter;, or choose a different volume to continue with the placement.
3511
The path %PathName; exceeds the maximum allowed length by %DiffFromMaxLimit; char acters.
The maximum length allowed in a path is %MaxLimit; characters. Enter a shorter path, and then try the operation again.
3512
The projected disk I/O utilization (IOPS) %ProjectedIOPS; exceeds the maximum dis k I/O utilization (IOPS) of %MaximumIOPS;.
3513
Unable to set the value for %Parameter;. The sum of all elements exceeds the maxi mum length of %MaxLength;.
Choose a different value below the maximum length, and then try the operation again.
3514
Unable to connect to the Virtual Server service on the library server %ServerName ;.
Ensure that the Virtual Server service is installed and running on the library server.
3515
Issues were identified while evaluating virtual machine placement.
3516
The specified virtual network adapter configuration is not supported by the host virtualization software.
Update the virtual network adapter configuration and then try the operation again.
3517
Unable to save the virtual machine configuration files because volume %VolumeDriveLetter; is marked as unavailable for placement.
Select a different save path for this virtual machine and then try the operation again.
3518
The VLAN setting for one or more network adapters on the virtual machine (%VMName ;) is not compatible with the virtualization software on the virtualization host (%VMHostName;).
Ensure that virtual LAN identification is disabled for all network adapters listed in the hardware configuration of the virtual machine (%VMName;) or specify a different host, and then try the operation again.
3519
Issues were identified while evaluating physical system placement.
3520
The virtual machine (%VMName;) violates the maximum memory limit for the virtualization host (%VMHostName;).\nMaximum memory: %ParameterValue;
3521
No network interface card could be identified that meets all requirements.
3522
Network bandwidth on the virtualization host (%VMHostName;) is not sufficient for all network workloads.
3523
Network bandwidth on the virtualization host (%VMHostName;) is not sufficient to satisfy the reserve level for all network workloads.
3525
No connected IP address pool with remaining IPv4 addresses could be identified to supply an address for the network adapter.\nNetwork adapter ID: %ParameterName;
3526
No connected MAC address pool with remaining addresses could be identified to supply an address for the network adapter.\nNetwork adapter ID: %ParameterName;
3527
No connected virtual IP (VIP) address pool with sufficient remaining addresses could be identified for the virtual machines in this tier.
3528
There are no enough network interface cards to satisfy the number required by the physical system.
3529
No connected storage device could be identified that satisfies all requirements.
hello, how to resolve the below error. i've not yet created single VM from SCVMM. My ESX Host has 24GB free, but SCVMM 2012 shows 0!!! why? How to resolve this?
