Code
Message
24000
Error in connecting to the WSUS server %ServerName;, Port %TCPPort;. Detailed error - %DetailedErrorMessage;
Ensure that the server connection information is valid. Then try the operation again.
24001
Update server operation failed with error - %DetailedErrorMessage;
BLANK
24002
Update server is currently processing another configuration request or is synchronizing updates and cannot process current configuration change request.
Try the operation after some time.
24003
VMM can manage only one Update server instance. %ServerName; is already managed by VMM.
BLANK
24004
Update server %ServerName; is a replica downstream WSUS server. Please specify the root or non-replica downstream WSUS server for integration.
Please specify the root or non-replica downstream WSUS server and re try the operation again.
24005
Update Server %ServerName; has unsupported version of Windows Software Update Server (WSUS).
Please specify Update Server with WSUS version 3.0 SP2.
24006
Baseline with name %BaselineName; already exists.
Please make sure the baseline name is unique and retry the operation.
24007
Update (ID - %Id;) is already added to baseline %BaselineName;, it can be added only once to the given baseline
Please make sure the update to be added to the baseline is not already added to the baseline and retry the operation.
24008
Update (ID - %Id;) cannot be removed from the baseline %BaselineName;, it is not added to the baseline.
Please make sure the update to be removed from the baseline is added to the baseline and retry the operation.
24009
Assignment scope (ID - %Id;, ObjectType - %ObjectType;) is already assigned to baseline %BaselineName;. It can be assigned only once to the given baseline.
Please make sure the assignment scope to be assigned to the baseline is not already assigned to the baseline and retry the operation.
24010
Assignment scope (ID - %Id;, ObjectType - %ObjectType;) cannot be removed from the baseline %BaselineName;. It is not assigned to the baseline.
Please make sure the assignment scope to be removed from the baseline is assigned to the baseline and retry the operation.
24011
Software update (%Name; - %Id;) does not have license agreement.
Please ensure the software update has license agreement that needs to be accepted before update can be deployed and retry the operation.
24012
License agreement for software update (%Name; - %Id;) is already accepted.
24013
Unable to find the object requested
Try refreshing the connection with the VMM server.
24014
License agreement for software update (%Name; - %Id;) needs to be accepted before update can be added to any baseline.
Please ensure the software update license agreement is accepted and retry the operation.
24015
Host - %VMHostName; is a clustered host. Individual cluster nodes cannot be assigned as a baseline scope.
Please use a cluster as baseline assignment scope and retry the operation.
24016
Host - %VMHostName; is not a Hyper-V host. Only Hyper-V hosts can be added as baseline assignment scope.
Please ensure the host is Hyper-V host and retry the operation.
24017
Cluster - %VMHostName; is not a Hyper-V cluster. Only Hyper-V clusters can be add ed as baseline assignment scope.
Please ensure the cluster is Hyper-V cluster and retry the operation.
24018
Baseline %BaselineName; is not assigned to %TargetType; %TargetName;.
Please ensure the baseline is assigned and retry the operation.
24019
%TargetType; %TargetName; has no baselines assigned.
Please ensure at least one baseline is assigned and retry the operation.
24020
No updates were found for compliance scan or remediation operation for %TargetTyp e; %TargetName;.
Please ensure baseline has at least one update added to it and retry the operation.
24021
Compliance scan of %TargetType; %TargetName; succeeded with warning - %DetailedErrorMessage;
Try the operation again.
24022
To enable Update Server, WSUS 3.0 SP2 console needs to be installed on VMM server.
Please install WSUS 3.0 SP2 console on the VMM server and restart VMM service and retry the operation.
24023
Update category - %Name; is not valid.
Ensure update category is valid and retry the operation.
24024
Update classification - %Name; is not valid.
Ensure update classification is valid and retry the operation.
24025
Language code - %Name; is not valid.
Ensure update language code is valid and retry the operation.
24026
Update Remediation of %TargetType; %TargetName; failed. Detailed error - %DetailedErrorMessage;
24027
Update Remediation of %TargetType; %TargetName; timed out.
24028
Update remediation of %TargetType; %TargetName; succeeded with warning - %DetailedErrorMessage;
24029
Update remediation orchestration for host cluster - %HostClusterName; failed as one or more nodes within the cluster are in the maintenance mode.
Please ensure all nodes of the host cluster are out of maintenance m ode or use –BypassMaintenanceModeCheck switch and retry the operation.
24030
Update remediation orchestration is supported only for Hyper-v clusters. Host cluster - %HostClusterName; is not a Hyper-v cluster.
Please ensure the host cluster is Hyper-V cluster and retry the operation.
24031
Proxy server credentials configuration from VMM is supported only for Update Server in SSL mode.
Please ensure the Update Server is configured for SSL communication and retry the operation.
24032
Update Server %ServerName; is not configured to use proxy server. None of the proxy server related settings can be configured in this mode.
Please ensure the Update Server is configured to use proxy server and retry the operation.
24033
The host %VMHostName; does not belong to the cluster %HostClusterName;.
Ensure the host belongs to the cluster and then try the operation again.
24034
Software update %Name; is not added to the baseline %BaselineName;.
Ensure the update is added to the baseline and then try the operation again.
24035
Compliance scan failed with error - %DetailedErrorMessage;.
Ensure the WinHTTP proxy settings are correctly configured for the communication with WSUS. If WSUS is configured to use SSL, ensure the WSUS certificate is installed in Trusted Root CA for the machine and then try the operation again.
24036
Compliance state for software update %Name; as part of the baseline %BaselineName ; for %TargetName; is currently unknown. Adding or removing exemption cannot be completed.
Please scan the baseline to determine the compliance state of the update and then try the operation again.
24037
Software update %Name; as part of the baseline %BaselineName; for %TargetName; is already marked "Exempt".
Ensure the update is not marked exempt and then try the operation again.
24038
Software update %Name; as part of the baseline %BaselineName; for %TargetName; is not "Exempt". Remove exemption cannot be completed.
Ensure the update is marked exempt and then try the operation again.
24039
VMM has changed setting on WSUS server to store the update binaries locally.
Please ensure there is enough disk space to support this setting.
24040
VMM has changed update language setting on WSUS server to %Name;.
N/A
24041
VMM has changed update binaries download setting on WSUS server to download the binaries when approved.
N/A
24042
Baseline name cannot be an empty string.
Please use valid name for baseline and try operation again.
24043
User %User; (User Role - %UserRoleName;) does not have permission to modify/remove the baseline %BaselineName;.
Ensure user has sufficient permissions and then try the operation again.
24044
Compliance scan or update remediation action cannot be completed on %ComputerName ;.
Ensure the specified machine is managed by VMM server and has at least one baseline assigned and then try the operation again.
24045
Error occurred in downloading End User License Agreement for Update %Name;.
Ensure the network connectivity between WSUS and WU/MU and then try the synchronization operation again.
24046
Update remediation operation cannot be performed on the cluster %HostClusterName; since node %VMHostName; is not in valid state.
Ensure all the nodes in the cluster are in valid state and retry the operation again.
24047
VMM agent installed on machine %ComputerName; does not support compliance scan or update remediation operations.
Ensure the machine has latest VMM agent installed and retry the operation.
24048
Proxy username for UpdateServer cannot be empty.
Ensure the proxy username is valid and retry the operation.
24049
Credentials cannot be specified when the proxy server access is set to be anonymous.
Please do not specify credentials and retry the operation.
24050
WSUS synchronization with WU/MU failed with error - %DetailedErrorMessage;.
Ensure WSUS can reach WU/MU sites and retry the operation.
24051
License agreement for update %Name; cannot be accepted at this time as the last attempt to download the license agreement has failed.
Synchronize the update server and retry the operation.
24052
VMM can store only %UpdateCount; updates from WSUS in its DB. The total number of updates VMM is trying to import from the latest synchronization and the count of its existing updates in DB exceeds this limit.
Ensure the maximum update count is set correctly and retry the operation.
24053
VMM target group %TargetGroupName; cannot be found on update server %ComputerName ;. Please remove the update server from VMM management and re-add it to VMM management.
24054
Error occurred in removing VMM target group %TargetGroupName; on update server %ComputerName;. Please remove the specified target group manually from WSUS console.
24055
Configuration properties of update server %ComputerName; cannot be changed from V MM as this is a downstream WSUS server.
Please ensure the configuration property changes are made for root WSUS server.
24056
Update server %ComputerName; is configured to prevent any configuration property changes from VMM.
Please ensure the specified update server is configured to allow such changes and retry the operation.
24300
Object import failed. Schema validation failed with error: "%ActualException;"
Fix validation error then try operation again
24301
Virtual machine %VMName; has unsupported virtual system type "%Name;"
24302
Unknown resource type "%Name;" was found.
24303
Duplicate element with %Name; property "%Value;"
24304
Unknown processor type %Name;
24305
Cannot find virtual hard disk "%Name;" (family name:"%FamilyName;", release:"%Release;"). Disk binding (%BusType;, %Bus;, %Lun;) will not be created for virtual machine %VMName;.
24306
Cannot find ISO resource "%Name;" (family name:"%FamilyName;", release:"%Release; "). ISO will be removed from DVD drive with binding (%BusType;, %Bus;, %Lun;) on virtual machine %VMName;.
24307
Value "%Value;" of element "%Name;" has invalid format.
24308
Required element "%Name;" is missing.
24309
Value "%Value;" of element "%Name;" is invalid. The value should be between %MinLimit; and %MaxLimit;.
24310
Value "%Value;" of element "%Name;" is invalid. Value length should be between %MinLimit; and %MaxLimit;.
24311
Cannot find virtual floppy disk resource "%Name;" (family name:"%FamilyName;", release:"%Release;"). Virtual floppy disk will be removed from the floppy drive on virtual machine %VMName;.
24312
Logical network "%LogicalNetworkName;" cannot be found. Network adapter "%Name;" will be disconnected on virtual machine %VMName;.
24313
Object import failed. Operation failed with error: "%ActualException;"
24314
Failed to export object "%Name;". Operation failed with error: "%ActualException; "
24315
Failed to write to file "%FileName;". Operation failed with error: "%ActualException;"
Fix the error then try operation again
24316
Required attribute "%Name;" is missing.
24317
Unknown disk format found: "%Name;"
24318
Cannot find custom resource "%Name;" (family name:"%FamilyName;", release:"%Release;"). Custom resource will be removed from script command %Command; on virtual machine %VMName;.
24319
Cannot find custom resource "%Name;" (family name:"%FamilyName;", release:"%Release;"). Custom resource will be removed from script command %Command; in application deployment %ObjectName; on virtual machine %VMName;.
24320
Cannot find application package "%Name;" (family name:"%FamilyName;", release:"%Release;"). Application deployment %ObjectName; will be removed from virtual machine %VMName;.
24321
Cannot find answer file "%Name;" (family name:"%FamilyName;", release:"%Release;" ). Answer file will be removed from virtual machine %VMName;.
24322
Virtual Machine %VMName; refers to virtual hard disks with different virtualization platforms.
24323
Custom property %Name; is missing and will be created
No action is needed
24324
Custom property %Name; is missing member type "Service Template". "Service Template" will be added to the member list.
No action is needed
24325
Custom property %Name; is missing member type "Template". "Template" will be added to the member list.
No action is needed
24326
Service Template "%Name;", release "%Release;" already exists.
Use -Overwrite option to overwrite existing service template.
24327
VM Template "%Name;" already exists.
Use -Overwrite option to overwrite existing template.
24328
Cannot export object "%Name;". File "%FileName;" already exists.
Use -Overwrite option to overwrite existing file.
24329
Import operation failed. File "%FileName;" is not a valid template package.
Fix the problem, then try operation again,
24330
Package data cannot be decrypted with the password provided.
Check the password, then try operation again,
24331
Password can only be specified for encrypted packages
Remove -Password parameter, then try operation again,
24332
A password must be provided when importing settings in encrypted packages.
Provide a -Password parameter, then try operation again,
24333
Cannot find element %Name;.
Fix validation error, then try operation again,
24334
Cannot decode value "%Value;". Base64 encoding is expected.
24335
Invalid encryption algorithm was specified: "%Name;"
24336
Run As account "%Name;" cannot be located for application deployment "%ObjectName ;"
Run As account reference will be replaced with mandatory service setting.
24337
Run As account "%Name;" cannot be found. Run As account reference will be removed from script command "%ObjectName;"
24338
Path %SharePath; is not on a library share that is managed by VMM Server.
Provide a path on a library share.
24339
Cannot find VIP template "%Name;". VIP template reference will be removed from computer tier template %TemplateName;.
24340
Local Administrator Run As account "%Name;" cannot be found. Run As account reference will be removed from VM template %TemplateName;"
24341
Domain user Run As account "%Name;" cannot be found. Run As account reference will be removed from VM template %TemplateName;"
24342
User with Security Identifier "%SecurityIdentifier;" is not found. Reference to this user will be removed from object %Name;.
24343
Security Identifier "%SecurityIdentifier;" doesn't belong to user "%UserName;". Reference to this user will be removed from object %Name;.
24344
User role %UserRoleName; is not found for user %UserName;. Reference to the user will be removed from object %Name;.
24345
User %UserName; doesn't exist. Reference to the user will be removed from object %Name;.
24346
VIP template "%Name;" is found, but has different properties.
Check VIP template properties in the package, create new VIP template if needed.
24347
Specified library object cannot be modified or deleted.
Make sure that you have necessary permissions to modify or delete th e object.
24348
Cannot import package %FilePath;. The package is either corrupted or has an incorrect file type. Operation failed with error: "%ActualException;"
24349
Template package %FilePath; is invalid
Check the contents of the file then try operation again
24350
Agent Service Run As account %RunAsAccountName; cannot be located for SQL Server deployment %Name; on template %TemplateName;
24351
Deployment Run As account %RunAsAccountName; cannot be located for SQL Server deployment %Name; on template %TemplateName;
Run As account reference will be removed.
24352
Reporting Service Run As account %RunAsAccountName; cannot be located for SQL Server deployment %Name; on template %TemplateName;
24353
SQL Server Service Run As account %RunAsAccountName; cannot be located for SQL Server deployment %Name; on template %TemplateName;
24354
SA Run As account %RunAsAccountName; cannot be located for SQL Server deployment %Name; on template %TemplateName;
24355
Cannot find SQL Server Configuration file "%Name;" (family name:"%FamilyName;", release:"%Release;"). Answer file will be removed from SQL Server deployment %ObjectName; on template %TemplateName;.
24356
User role %UserRoleName; is not found. Reference to the user role will be removed from object %Name;.
24357
Run As account "%Name;" cannot be found. Run As account reference will be removed from SQL Server script command in application deployment "%ObjectName;" in Template "%TemplateName;".
24358
Cannot find SQL Server script file "%Name;" release "%Release;". SQL Server script command "%CommandName;" in application deployment "%ObjectName;" in Template "%TemplateName;" will be removed.
24359
Storage classification "%Name;" cannot be found. Storage classification reference will be removed from disk (%BusType;, %Bus;, %Lun;) on virtual machine %VMName;.
24360
Capability Profile "%Name;" release "%Release;" cannot be found. Capability Profile reference will be removed from object "%ObjectName;"
24361
Release parameter cannot be empty.
Please ensure release parameter is valid and try the operation again.
24362
Password parameter is used to encrypt private settings and can only be specified together with SettingsIncludePrivate parameter.
Specify SettingsIncludePrivate parameter and try the operation again.
24363
VMM agent on library server %ComputerName; needs to be reassociated.
Ensure VMM agent on library server is in OK state and try the operation again.
24364
Run the client (Cmdlet/Admin Console) with elevated administrator privileges.
24365
Failed to Create BITS job on the client.
Restart BITS service and try the operation again.
24366
The BITS client job failed to succeed for %ResourceName; when attempting %CmdletName; resource with following error: %DetailedErrorMessage;
Restart BITS service and try the operation again. Also make sure that the client has permissions on the source and the destination.
24367
VMM server sent an invalid SSL cert for the HTTPS transfer to Library server.
Check the presence of library server certificate on VMM server's Trusted People store.
24368
Path %FolderPath; must be a valid directory accessible to client.
Check the path specified and make sure that client has permissions to access it.
24370
Resource %ResourceName; is on a library server that requires Encryption.
Try the operation with Encryption option as the server only supports this mode
24371
Resource "%Name;" already exists at %FolderPath;.
Use -Overwrite option to overwrite existing resource.
24372
Connected role %UserRoleName; doesn't have access to %FolderPath;.
Contact Administrator to get access to the desired path or use the R /W path to which the role has access to.
24373
Connected Administrator role did not specify a valid library Path for importing resource.
Administrator roles must specify a valid path when importing resources into library.
24374
Addition of default resources to library share (%SharePath;) failed. DetailedErrorMessage: %DetailedErrorMessage;
Fix the problem, then try operation again.
24375
Error occurred in communicating with the VMM agent on machine %ComputerName;.
Ensure the agent is in responding state, then try operation again.
24376
The client imported a resource %ResourceName; that library server agent doesn't recognize.
The client should only import known resource types into the VMM library
24377
User tried to specify both of IncludeAllLibraryResources and IncludeLibraryResources. Only one of these parameters is allowed at a time.
Specify either one of IncludeAllLibraryResources or IncludeLibraryResources.
24378
User tried to specify local file mapping for %ResourceName; package.
24379
The cmdlet stopped as the pipeline execution was terminated.
Try running the cmdlet again.
24380
24381
The transfer did not succeed. The failure could be due to timeout on the server, client cancelling the job, or client cmdlet failure.
24382
Service Template "%Name;", release "%Release;" cannot be overwritten as it is not accessible under user role %UserRoleName;
Use different name/release combination
24383
Template "%Name;" cannot be overwritten as it is not accessible under user role % UserRoleName;
Use different name.
24384
To change identity properties of the library resources, all the specified resources must belong to the same namespace.
Ensure all the specified library resources belong to same namespace and try the operation again.
24385
Library resource %Name; is not valid for deployment.
Ensure the object resides on library share under VMM management and try the operation again.
24386
For setting identity properties on a group of objects, all objects must be of same object type.
Ensure all objects are of same object type and try the operation again.
24387
Multiple library resources were discovered during import of "%SharePath;" folder. This could be an issue if it occurred during importing a Service Template.
Ensure that importing multiple resources was the intent. If this occurred during Service template import, check the Imported template before deploying it.
24388
Run As account %RunAsAccountName; specified for service setting %Name; cannot be found.
24389
Invalid operation on object %Name; as it does not reside on any of the VMM manage d library servers.
Ensure the object is a valid library object and try the operation again.
24390
Template uses unsupported XSD schema version "%XSDVersion;"
Upgrade Virtual Machine Manager and export template again or change template XML to conform to the schema.
24391
The list of resources being imported is empty.
Try specifying a non-empty resource list to be exported.
24392
Unable to add default resources to library share (%SharePath;) on cluster library server %Name; as VMM agent is not installed on the current active node.
Ensure that VMM agent is installed on the current active node of cluster library server and then try the operation again.
24393
VHDs %Name; cannot be marked equivalent with family name %FamilyName; and release %Release; because they have different VHD formats.
Ensure that the VHDs have the same VHD format before marking them as equivalent.
24394
VHDs %Name; cannot be marked equivalent of VHD %ObjectName; (Family name: %Family Name;, Release: %Release;) because they have different VHD formats.
24700
The day of the week entered is invalid. Valid values are “Monday”, “Tuesday”, “Wednesday”, “Thursday”, “Friday”, “Saturday”, and “Sunday”.
Refer to PowerShell help on this cmdlet for more details.
24701
The numeric form for the day of the week is invalid. This must be between 1 and 7 representing Monday through Sunday respectively.
24702
Unable to find the specified servicing window. The servicing window name may be incorrect, or the servicing window may have been renamed or deleted.
Verify that the servicing window name is correct and try the operation again.
24703
A servicing window named %Name; already exists.
Provide a unique servicing window name and try the operation again.
24704
Unable to find the specified servicing window subscription. The subscription, the servicing window or the subscribed object may have been deleted.
Verify that the servicing window is correct and try the operation again.
24705
This object is already associated with this servicing window.
Select a different servicing window to associate this object with an d try the operation again.
