Code
Message
30100
The selected action could not be completed because the Virtual Machine Data Exchange information is only supported on Hyper-V.
Please specify a Hyper-V Virtual Machine.
30101
Virtual Machine %VMName; cannot be modified because Virtual Guest Services is not installed on the guest operating system or because the installed Virtual Guest Services does not support the Heartbeat and Data Exchange Integration Services in the current virtual machine status.
Verify the virtual machine is in a Running status, the Virtual Guest Services is installed, and the Heartbeat and Data Exchange Integration Services are enabled.
30102
Could not operate on virtual machine %VMName; Data Exchange Integration Services.
Ensure that the virtual machine exists and is in a Running status, the Virtual Guest Services is installed, and the Heartbeat and Data Exchange Integration Services are enabled and then t ry the operation again.
30103
The specified Data Exchange key name %PropertyName; does not exist on the virtual machine %VMName;.
Please specify a different Data Exchange key name and then try the operation again.
30104
The specified Data Exchange key and value pairs are not the proper length or data type.
Specify a different Data Exchange set of key and value pairs, and then try the operation again.
30105
The specified Data Exchange key (%PropertyName;) already exists as a Guest Data Exchange key and should not be recreated as a Host Data Exchange key.
Specify a different Data Exchange key, and then try the operation again.
