Code
Message
27000
Setup could not connect to SQL Server Analysis Services because Analysis Management Objects (AMO) is not installed on the VMM management server.
Ensure that Analysis Management Objects (AMO) is installed on the VM M management server.\n\nIf you are using SQL Server 2008 Analysis Services, install Microsoft Analysis Management Objects (x64 package) from the Microsoft SQL Server 2008 Feature Pack (http://go.microsoft.com/fwlink/?LinkID=220985).\n\nIf you are using SQL Server 2008 R2 Analysis Services, install Microsoft SQL Server 2008 R2 Analysis Management Objects ( x64 package) from the Microsoft SQL Server 2008 R2 Feature Pack (http://go.microsoft.com/fwlink/?LinkID=220986).
27001
There was an error configuration the connection: %DetailedErrorMessage;
Ensure that the credentials used have sufficient rights.
27002
Unable to impersonate the credentials passed in.
Ensure that the credentials are valid.
27003
An SCSSASConnection already exists, but only one is supported at a time.
To create another connection, run Remove-SCSSASConnection before running Add-SCSSASConnection.
27004
No SCSSASConnection exists.
To create an SSAS connection, run Add-SCSSASConnection.
27005
An invalid computer or instance name specified.
Provide a valid computer and an instance name and try the operation again.
27006
The SQL Server Analysis Server %ComputerName; is not reachable.
Ensure the SQL Server Analysis Server is reachable and the specified Analysis Services instance is running.
27007
An invalid port number specified for connecting to SQL Analysis server %ComputerName;.
Provide a valid port number and try the operation again.
27200
Custom Property with name %Name; already exists.
Specify a unique name for Custom Property, and then try the operation again.
27201
Custom Property with name %Name; is already added to this Member.
Specify a different name for Custom Property, and then try the operation again.
27202
Custom Property is not associated with this Member.
Specify a different member for this Custom Property, and then try the operation again.
27203
Legacy Custom1 - Custom10 properties cannot be deleted.
Specify a different Custom property, and then try the operation again.
27204
The application deployment name is blank.
Specify a name for the application deployment.
27205
Application deployment %Name; does not have an application package.
Select an application package to deploy.
27206
There is already another application deployment with the same name.
Choose a unique name for this application deployment.
27207
No logical network has been selected.
You must select a logical network when using static IP. Review your management NIC settings and pick a logical network.
27208
No boot partition specified.
You must specify one partition as the boot partition. Review your partition settings and pick a boot partition.
27209
Only four partitions, three if one of them has been marked as the boot partition, are allowed for this disk.
Four partitions can be created on each MBR disk. If one partition has been marked as the boot partition, only three can be created. If you need additional partitions, add a new disk and create a new partition on it.
27210
No tags have been defined for driver matching.
You have selected to use tags for driver matching, but have not indicated which tags to use. Review your driver filter settings.
27211
The script command executable name is blank.
Specify the name of the executable to run and try the operation again.
27212
The maximum duration of a servicing window is seven days.
Adjust the duration to seven days or less and try the operation again.
27213
No domain name has been specified.
You have not specified a domain name. Please review your domain settings.
27214
No Run As account has been specified.
You have not specified a Run As account to use as the Local Administrator. Please review your domain settings.
27215
The specified name %Name; is invalid.
Provide a valid name for the custom property and try the operation again.
27216
Legacy custom properties (Custom1-Custom10) cannot be updated.
Specify a different custom property, and then try the operation again.
27217
DAC application deployment %Name; does not have a deployment Run As Account.
Select a Run As Account for deployment.
27218
The maximum value cannot be less than the minimum value.
Specify a maximum value greater than the minimum value.
27220
The SQL Server deployment name is blank.
Specify a name for the SQL Server deployment.
27221
There is already another SQL Server deployment with the same name.
Choose a unique name for this SQL Server deployment.
27222
The SQL Server instance name is blank.
Specify a name for the SQL Server instance.
27223
The SQL Server instance ID is blank.
Specify a value for the SQL Server instance ID.
27225
An Agent Run As Account is required.
Specify an Agent Run As Account.
27226
A Service Run As Account is required.
Specify a Service Run As Account.
27227
The SQL Server media source is blank.
Specify a media source for the SQL Server deployment.
27228
No SQL Server administrator accounts have been specified.
Specify at least one account to be an administrator.
27229
An invalid BMC address has been specified. The address must be a valid IPV4 address, IPV6 address or fully qualified domain name.
Specify a valid BMC network address.
27230
Port number must be restricted to a numeric value from 1 to 65535.
Specify a valid port number.
27231
You must select a Run As Account with credentials for the BMC you specified.
Specify a valid Run As account.
27232
You must select an OOB power management provider from the provider list.
Select one OOB power management provider.
27233
VMM could not find the specified custom property.
Enter valid custom property and try the operation again.
27234
VMM could not find the specified custom property value.
Enter valid custom property value and try the operation again.
27235
An unknown error occurred while executing the PowerShell script:\n\n%PowerShellRuntimeErrorMsg;
Try the operation again. If the issue persists, contact Microsoft Help and Support.
27236
One or more of the partitions you have defined has an invalid name.
Please verify the names of the partitions you have defined and modify any that are empty or contain invalid characters.
27237
DAC application deployment %Name; does not have a SQLDAC instance name.
Specify a SQLDAC instance name for the application deployment.
27238
Port number must be a numeric value from 1 to 65535.
27239
The Application Profile is not compatible with the current guest operating system (%Name;).
Change the guest OS to one that is compatible with the Application Profile or add the guest OS to the Application Profile's compatible OS list.
27240
Connecting to this Xen virtual machine requires an ActiveX control that is not in stalled.\n\nWould you like to install the Xen ActiveX control now?
27241
An administrator password must be specified.
Please enter a password in the Admin Password setting.
27242
The domain name has invalid characters.
Please make sure that the domain name specified in the Domain setting contains no invalid characters.
