MED-V V2 leverages underlying VPC and RDP\RemoteApp technologies to facilitate support for URL, Print, and document redirection. In addition, a special BHO is used by the host browser to redirect URL’s configured for legacy guest browsing to the guest browser. There are certain group policies that could impact MED-V’s functionality and/or performance if they are configured. If you are encountering issues with MED-V, verify your applied GPO’s to determine the following.
Policy Location: Computer Configuration\Windows Settings\Security Settings\Local Policies\User Rights Assignments\
Policy: Allow log on through Terminal Services
Policy: Deny log on through Terminal Services
Impact: If applied to the XP guest, this could prevent MED-V SSO (single sign-on) with the guest.
Policy Location: Computer Configuration\Windows Settings\Security Settings\Local Policies\Security options
Policy: Interactive logon: Message text for users attempting to log on
Policy: Interactive logon: Message title for users attempting to log on
Impact: If applied to the XP guest, this could affect MED-V SSO (single sign-on) with the guest where users will always see an additional prompt.
Policy Location: Computer Configuration\Administrative Templates\Windows Components\Internet Explorer\Advanced Page\
Or User Configuration\Administrative Templates\Windows Components\Internet Explorer\Advanced Page\
Policy: Allow third-party browser extensions
Impact: This could prevent URL redirection if applied to the host.
Policy Location: Computer Configuration\Administrative Templates\Windows Components\Internet Explorer\Security Features\Add-on Management
or
User Configuration\Administrative Templates\Windows Components\Internet Explorer\Security Features\Add-on Management
Policy: Deny all add-ons unless specifically allowed in the Add-on List
Impact: This could also prevent URL redirection if applied to the host.
Policy Location: Computer Configuration\Administrative Templates\Windows Components\Terminal Services\Client-server data redirection
Policy: Do not allow clipboard redirection
Policy: Do not allow drive redirection
Impact: This could prevent access to redirected host folders if these policies are applied to the guest Windows XP OS.
Policy Location: Computer Configuration\Administrative Templates\System\Group Policy
Or User Configuration\Administrative Templates\System\Group Policy
Policy: Group Policy Slow Link Detection
Impact: MED-V Workspaces configured for NAT mode may notice significant delays in startup and possibly even logon delays. This can appear to the end user in the form of an application taking a tremendous amount of time to start up or shut down.
Policy Location: Computer Configuration\Administrative Templates\Windows Components\Remote Desktop Services
Policy: Remote Desktop Connection Client
Impact: For Windows 7 hosts, if "Configure server authentication for client" is Enabled and set to "Do not connect if authentication fails" then the MED-V applications will fail to start. If this policy must be set, then set it to "Always connect, even if authentication fails."
Interesting..
usually will you recommend people to plant the script in the gpo login script ?
