Why should you write Unit Tests? Here are some points which are mostly mentioned if somebody argues against Unit Tests
So, why should you write Unit Tests? The guys from Agitar Technologies gives you a starting point to think about - http://www.agitar.com/solutions/why_unit_testing.html
Ok, I want to write Unit Tests, but what should I test? Arnt Berge wrote down his thought about what should be tested in ASP.NET MVC - http://blogg.bouvet.no/2011/04/05/thoughts-on-unit-testing-in-asp-net-mvc/
All right, I'm convinced, where should I start? Here are some links, where Unit Testing ASP.NET MVC applications is the central point.
This article is also available in the following languages:
The link "Creating Unit Tests for ASP.NET MVC Applications" not work.
@Yatajga Thanks for the hint. I've fixed this link.
Good Article.
Nice article !!!
