Important: This version of this tutorial was last updated for SQL Server 2012 Release Candidate 0. For the most up-to-date version of this tutorial, see: Tutorial: Optimize a Sample PowerPivot Model for Power View Reports In this tutorial, you modify an Excel workbook in PowerPivot for Excel to make a small but functional model that you can use as a basis for sample Power View reports. Everything you do in this tutorial in PowerPivot, you can also do in tabular models that you create in SQL Server Data Tools (SSDT). In fact you can do much more in SQL Server Data Tools (SSDT). For more information, see Tabular Modeling (SSAS).
To do this tutorial, you need to:
Before you can start the tutorial, you need to
In Shared Documents, create a HelloWorldPicnicSample folder, and save the HelloWorldPicnicModelPowerPivotTutorialRC0.xlsx file there.
In the HelloWorldPicnicSample folder, click the Documents tab, click the arrow next to New Document, and then click Report Data Source.
If there is no Report Data Source option on the New Document tab, then someone with adequate permissions on the SharePoint site needs to add that content type to the site. For more information, see Add Report Server Content Types to a Library (Reporting Services in SharePoint Integrated Mode).
In the Name box, type HelloWorldPicnicRSDS.
Note the RSDS file extension.
In the Data Source Type box, click Microsoft BI Semantic Model for Power View.
The Connection string for an XLSX file is the full URL to the file, including the file name. For example:
http://<myserver>/Shared%20Documents/HelloWorldPicnicSample/HelloWorldPicnicModelPowerPivotTutorialRC0.xlsx
For Credentials, click Windows authentication (integrated) or SharePoint user.
Click Test Connection.
You should see a message that the connection test was successful.
Click OK.
Create an Images folder in the HelloWorldPicnicSample folder. For example:
http://<myserver>/Shared Documents/HelloWorldPicnicSample/Images
In the Images folder, save the images that you downloaded from the Download Center. For more information, see the Prerequisites section at the beginning of this tutorial.
From the PowerPivot Gallery, click the image of the file HelloWorldPicnicModelPowerPivotTutorialRC0.xlsx.
This opens the workbook in SharePoint.
Click Open in Excel.
Click the PowerPivot tab, and then click PowerPivot Window.
From Shared Documents, click the dropdown arrow next to HelloWorldPicnicModelPowerPivotTutorialRC0.xlsx, and click Edit in Microsoft Excel.
In the Excel window, select all the columns and rows in the Items worksheet.
On the PowerPivot tab, click Create Linked Table.
Verify that it contains the correct columns and rows.
Check My table has headers, and then click OK.
The table opens on a new tab in PowerPivot.
Right-click the tab and rename it Items.
Repeat this three times to create linked tables in PowerPivot for Distributors, Quantities, and Dates.
Click Save, and you now have a model—not much of a model, but a model nonetheless.
Note that you’re back in the Excel window after you save.
In the Shared Documents folder, click the arrow next to HelloWorldPicnicRSDSRC0.rsds, the shared data source you created earlier in this tutorial, and then click Create Power View Report.
In the PowerPivot Gallery, click the Create Power View Report icon in the upper-right corner of the HelloWorldPicnicModelPowerPivotTutorialRC0.xlsx band.
Power View opens to a blank view. The field list on the right contains the tables you created in PowerPivot: Dates, Distributors, Quantities, and Items.
Expand the Items table.
There are the fields from the table in PowerPivot.
Click the Items table name itself.
Nothing happens. We’ll come back to this later.
Click the Name field.
You now have a table with one column, the Name column.
Note, though, that now all the other tables are grayed out, unavailable. Why?
The other tables are grayed out because there are no relationships between the tables in the model.
On the Home tab, click Diagram View.
You see the tables in your model, with no relationships between them.
Drag the tables so you can see them all in the window. Place the Quantities table in the center, as it is central to the model.
Drag from the ItemID field in the Items table to the ItemID field in the Quantities table.
PowerPivot creates a one-to-many relationship between the two tables. It doesn’t matter which way you drag. The one and many sides of the relationship will be the same. For more information about one-to-many relationships, see Guide to table relationships (from Microsoft Access Help).
Drag these fields to create other relationships between:
Save the model.
When you make changes to the model, you need to refresh the report. There are two Refresh buttons to choose from:
Click the Power View Refresh button.
Note that nothing changes.
Click the Internet Explorer Refresh button.
In this case we haven’t made any changes worth saving, so click Leave this page.
The field list is still there but the view is blank.
Expand the Items table, and drag the Name field to the view.
Note that the other tables are not grayed out. Note, too, that there is only one “apple” value.
Expand the Quantities table and drag the Qty Served field to the Name table.
Now there are many “apple” values. The Qty Served values are not being aggregated.
Try scrolling down the list.
Note that the scroll bar gets smaller as Power View retrieves more values. Power View retrieves values only as needed, to speed performance.
In the layout (lower) section of the field list, click the dropdown arrow next to the Qty Served field and then click Sum.
Time to set reporting properties to make reports based on this model work better.
In the PowerPivot Window, on the File menu, click Switch to Advanced mode.
Go to the Items table.
On the Advanced tab, click Table Behavior.
For Row Identifier, click ItemID.
Note that now the rest of the items in the dialog box are available. Until you have selected a row identifier, they are all grayed out.
For Keep Unique Rows, click Name.
This means that even if there are 2 identical values in this column in 2 different rows, Power View will not aggregate them if they have different ItemID values. For example, “apple”: There are 2 different “apple” values in the Name field. Power View will no longer aggregate them, as it did earlier.
For Default Label, click Name.
Click Default Field Set.
Add Name, Category, and Color, and then click OK.
These are the default fields that will be added to a view if you click the table name rather than an individual field.
Save the PowerPivot model.
Because you haven’t saved the report yet, you will lose the few changes you have made.
Click Leave this page.
Note the icon next to the ItemID and Name fields indicating that they are unique fields and the default label for this table.
Drag the Name field to the view.
Note that there are now two apple values.
Click the Undo button.
Click the Items table itself.
This creates a table with the fields you identified as the default fields for this table: Name, Category, and Color.
With this table selected, click the dropdown arrow in the Visualizations Gallery and click Card.
Note that the values from the Name field are displayed prominently, because Name is the default label field for the Items table.
Click someplace on the blank view so the cards are not selected.
In the fields (upper) section of the field list, expand the Distributors table.
Note that it contains only the Distributor and DistID fields.
Save the Power View report someplace on the SharePoint site.
We can consolidate the single field from the Distributors table into the Items table to clean up the model.
In the PowerPivot window in the Items table, create a calculated column: Right-click the Add Column column and click Insert Column.
Select the new column, right-click, click Rename, and rename it Distributors.
In the Excel formula box, type
=RELATED(Distributors[Distributor])
Note that the formula auto-completes as you type.
This brings the Distributor name into the Items table, so report creators no longer need the Distributors table, or the DistID field in the Items table.
Right-click the DistID column, and then click Hide from Customer Tools.
This hides the column in Power View, but you can still see it in PowerPivot.
Right-click the Distributors table tab and click Hide from Customer Tools.
Before you can add images to the model, you need to download them from the Microsoft Download Center and save them to the SharePoint site. For more information, see the Before you start [#BeforeSta section.
Adda calculated column to the Items table and call it Image Name.
Paste in this formula:
=IFERROR(IF(FIND("apple",[Name])>0, SWITCH(Left([Color],1),"b","applejuice","g",[Name]& "g","r",[Name],[Name]),[Name]),[Name])
This column makes the image names correspond to the item names in the Name field.
Add another calculated column and name it Photo. Paste in this formula:
="http://localhost/Shared Documents/Images/rs_crescent_picnic_image_" & [Image Name] & ".png"
Each item has an associated photo. This concatenates the name in the Image Name column with the URL where the images are located, plus the .png file extension.
Add another calculated column and name it Drawing. Paste in this formula:
="http://localhost/Shared Documents/images/rs_crescent_picnic_drawing_" & [Image Name] & ".png"
Each item has an associated drawing, too.
Add another calculated column and name it Category Drawing. Paste in this formula:
="http://localhost/Shared Documents/Images/rs_crescent_picnic_drawing_" & [Category] & ".png"
Each category has an associated drawing.
Add one more calculated column and name it Category Photo. Paste in this formula:
="http://localhost/Shared Documents/Images/rs_crescent_picnic_image_" & [Category] & ".png"
Each category has an associated photo, too.
Note that you are back in the Excel window, and the calculated columns don’t appear. They are only in PowerPivot.
Let’s see how it looks in Power View.
Because you have saved the report, you don’t lose the changes you have made.
Note that there are only three tables now—the Distributors table is gone.
Note the new fields, including the Distributor field.
Drag the Photo column to the table on the view.
Uh oh! That’s no photo. That’s just the URL. Back to the model.
Click the Items table, then the Advanced tab.
Check the Image URL box for all four URL fields.
Click Table Behavior.
Set the Default Image to Drawing, and then click OK.
Click Default Field Set, and add Drawing to the Default fields set.
You lose the most recent changes you made.
Add the Drawing field to the table again.
There are the images!
Let’s look at dates and numbers.
Click the blank space in the view to start a new visualization.
Expand the Dates table and drag the Month Name field to the view.
From the Items table, add the Category field to the same table.
Note that none of the charts in the Visualizations Gallery are available. A chart needs at least one aggregated value.
In the Quantities table, click the dropdown arrow next to the Qty Served field, and click Add to Table as Sum.
It would be nice if that were the default. Because these are whole numbers, Power View does not aggregate them by default because they might be in a field that shouldn’t be aggregated, such as a key field.
Now that the table has a field with a sum, the charts are available.
Click Line Chart.
You should see:
If not, you can drag the fields to the right boxes.
But something is wrong: The months start with April, August, and December, and end with September. They’re alphabetical, not chronological. Back to the model.
Save the Power View report.
Calculated columns calculate a result and store it for every row in a table. Calculated measures are calculated on the fly, depending on the context—where they are being calculated in a PivotTable or in a Power View report. For more about calculated columns and measures, see Build Formulas for Calculations.
In PowerPivot window, go to the Dates table.
On the Design tab, click Mark as Date Table.
Select the Date field and click OK.
Select the Month Name column, and on the Home tab, click Sort by Column and then Sort Month Name by the Month Number column.
Select the Month Number column, right-click, and click Hide from Client Tools.
Repeat steps 4 and 5 for the Day Name and Day Number fields.
Select the Qty Served, Qty Consumed, and Attendees columns.
On the Advanced tab, click Summarize by, then click Sum.
Right-click the Qty Served column, click Description, type:
How much we served.
This will appear as a tooltip over the Qty Served field in the fields (upper) section of the field list. You can add a tooltip to every table and field.
In the Quantities table, insert a column and rename it Leftovers. In the Excel formula box, type:
=[Qty Served]-[Qty Consumed]
PowerPivot will autocomplete the column names as you type.
Still in the Quantities table, click in any cell in the lower part of the table, below the dividing line.
This area is called the measure grid. You can hide or show it with a button on the Home tab. You can put measures in any cell in any column.
Paste the Quantity Consumed year-to-date formula in the cell:
Qty Served YTD:=TOTALYTD(SUM([Qty Served]),Dates[Date])
What has changed?
In the fields section of the field list, hover over the Qty Served field.
The tooltip appears.
Create a table with the Name, Qty Served, Qty Served YTD, and Leftovers fields.
In the Visualizations gallery, click Scatter chart.
Make sure the Qty Served YTD field is in the Y Value box.
Drag the Month Name field from the fields section of the field list to the Play box in the layout (lower) section of the field list.
Click the play arrow.
Note that the bubbles gradually move from left to right, as the Qty Served YTD values increase.
You can also take advantage of the model from within Excel to quickly validate your data.
In the Excel (not the PowerPivot) window, on the PowerPivot tab, click PivotChart, then New Worksheet.
Note that the new worksheet contains the PowerPivot Field List on the right.
From the Dates table, drag Month Name to Slicers Horizontal.
From the Items table, drag Color to Slicers Vertical, and Type to Slicers Horizontal.
From the Items table, drag:
Right-click the chart and click Change Chart Type.
Click Stacked Column.
Click the different values in the slicers to filter the chart.
So you’ve seen how you started with raw data, and then:
And you’ve seen how those changes changed the way the data appeared in the report.
Now that you’ve completed this tutorial, you can make use of the model you have created to try Tutorial: Create a Sample Report in Power View in Power View Samples for SQL Server 2012 and SQL Server 2012 Samples Readme.
