A new feature for UNIX and Linux monitoring with System Center 2012 – Operations Manager is the ability to use sudo elevation in the discovery and agent ugprade wizards, as well as Run As accounts. This means that the root user is no longer needed for privileged monitoring (log file monitoring, script/command execution) and agent maintenance (installation, upgrade, and uninstallation). Information on configuring Operations Manager credentials to use sudo elevation can be found here.
In order to use sudo-enabled accounts for Operations Manager monitoring, the sudoers file must be configured (on each UNIX/Linux computer) to authorize elevation for the selected user account, using visudo. General requirements for the accounts used by Operations Manager with sudo elevation are:
  • The sudoers option requiretty must be disabled for the user
  • For required commands, sudo authorization must be configured to allow the user to elevate to root, without password
Information on the rights and privileges required for Operations Manager activities can be found here.
Sample Configurations for System Center 2016
The actual list of commands used for privileged monitoring or agent maintenance varies between platforms. The sample configurations below provide users named “scomadm and scomuser” with the minimum necessary authorization to perform the following activities:
Authorization for scomadm:
  • Discover and install the agent
  • Sign the agent certificate
  • Upgrade the agent
  • Restart the agent (used in certificate signing and agent recovery)
  • Uninstall the agent
Authorization for scomuser:
  • Read privileged log files
Commented lines in these configurations provide example syntax for use with custom command/script monitors, rules, or tasks (such as those created with the UNIX/Linux Shell Command monitoring templates), as well as daemon monitoring diagnostic and recovery tasks.
System Center 2016 - Operations Manager
These configurations apply to System Center 2016 - Operations Manager. Example configurations for System Center 2012 and 2012 R2 - Operations Manager are listed in the next section.
AIX
#Example user configuration for Operations Manager agent
#Example assumes users named: scomadm & scomuser
#Replace usernames & corresponding /tmp/scx-<username> specification for your environment
#General requirements
Defaults:scomadm !requiretty
#Agent maintenance
##Certificate signing
scomadm ALL=(root) NOPASSWD: /usr/bin/sh -c cp /tmp/scx-scomadm/scx.pem /etc/opt/microsoft/scx/ssl/scx.pem;
rm -rf /tmp/scx-scomadm; /opt/microsoft/scx/bin/tools/scxadmin -restart
scomadm ALL=(root) NOPASSWD: /usr/bin/sh -c cat /etc/opt/microsoft/scx/ssl/scx.pem
##Install or upgrade
scomadm ALL=(root) NOPASSWD: /usr/bin/sh -c sh /tmp/scx-scomadm/scx-1.[5-9].[0-9]-[0-9][0-9][0-9].aix.[[\:digit\:]].ppc.sh --install ; EC=$?; cd /tmp; rm -rf /tmp/scx-scomadm;
exit $EC
scomadm ALL=(root) NOPASSWD: /usr/bin/sh -c sh /tmp/scx-scomadm/scx-1.[5-9].[0-9]-[0-9][0-9][0-9].aix.[[\:digit\:]].ppc.sh --upgrade --force ; EC=$?; cd /tmp; rm -rf /tmp/scx-scomadm;
exit $EC
##Uninstall
scomadm ALL=(root) NOPASSWD: /usr/bin/sh -c /opt/microsoft/scx/bin/uninstall
##Log file monitoring
scomuser ALL=(root) NOPASSWD: /opt/microsoft/scx/bin/scxlogfilereader -p
###Examples
#Custom shell command monitoring example – replace <shell command> with the correct command string
# scomuser ALL=(root) NOPASSWD: /bin/bash -c <shell command>
#Daemon diagnostic and restart recovery tasks example (using cron)
#scomuser ALL=(root) NOPASSWD: /usr/bin/sh -c ps -ef | grep cron | grep -v grep
#scomuser ALL=(root) NOPASSWD: /usr/sbin/cron &
#End user configuration for Operations Manager agent
HP-UX
#Agent maintenance
-c cp /tmp/scx-scomadm/scx.pem /etc/opt/microsoft/scx/ssl/scx.pem; rm -rf /tmp/scx-scomadm; /opt/microsoft/scx/bin/tools/scxadmin -restart
scomadm ALL=(root) NOPASSWD: /usr/bin/sh -c sh /tmp/scx-scomadm/scx-1.[5-9].[0-9]-[0-9][0-9][0-9].hpux.11iv3.ia64.sh --install
; EC=$?; cd /tmp; rm -rf /tmp/scx-scomadm; exit $EC
scomadm ALL=(root) NOPASSWD: /usr/bin/sh -c sh /tmp/scx-scomadm/scx-1.[5-9].[0-9]-[0-9][0-9][0-9].hpux.11iv3.ia64.sh --upgrade
--force ; EC=$?; cd /tmp; rm -rf /tmp/scx-scomadm; exit $EC
##Uninstall
###Examples
Linux - RHEL
#Agent maintenance
scomadm ALL=(root) NOPASSWD: /bin/sh -c cp /tmp/scx-scomadm/scx.pem /etc/opt/microsoft/scx/ssl/scx.pem; rm -rf /tmp/scx-scomadm;
scomadm ALL=(root) NOPASSWD: /bin/sh -c cat /etc/opt/microsoft/scx/ssl/scx.pem
scomadm ALL=(root) NOPASSWD: /bin/sh -c sh /tmp/scx-scomadm/scx-1.[5-9].[0-9]-[0-9][0-9][0-9].rhel.[[\:digit\:]].x[6-8][4-6].sh
--install; EC=$?; cd /tmp; rm -rf /tmp/scx-scomadm; exit $EC
--upgrade --force; EC=$?; cd /tmp; rm -rf /tmp/scx-scomadm; exit $EC
##Uninstall
scomadm ALL=(root) NOPASSWD: /bin/sh -c /opt/microsoft/scx/bin/uninstall
###Examples
#scomuser ALL=(root) NOPASSWD: /bin/sh -c ps -ef | grep cron | grep -v grep
Linux – RHEL 7.1 on Power 8
#Agent maintenance
scomadm ALL=(root) NOPASSWD: /bin/sh -c sh /tmp/scx-scomadm/scx-1.[5-9].[0-9]-[0-9][0-9][0-9].rhel.[[\:digit\:]].ppc.sh --install;
scomadm ALL=(root) NOPASSWD: /bin/sh -c sh /tmp/scx-scomadm/scx-1.[5-9].[0-9]-[0-9][0-9][0-9].rhel.[[\:digit\:]].ppc.sh --upgrade
##Uninstall
###Examples
Linux - SLES
#Agent maintenance
scomadm ALL=(root) NOPASSWD: /bin/sh -c sh /tmp/scx-scomadm/scx-1.[5-9].[0-9]-[0-9][0-9][0-9].sles.1[[\:digit\:]].x[6-8][4-6].sh
##Uninstall
###Examples
Linux - Universal DEB, RPM (Debian, Ubuntu, CentOS, Oracle)
#Agent maintenance
scomadm ALL=(root) NOPASSWD: /bin/sh -c sh /tmp/scx-scomadm/scx-1.[5-9].[0-9]-[0-9][0-9][0-9].universal[[\:alpha\:]].[[\:digit\:]].x[6-8][4-6].sh
##Uninstall
###Examples
Solaris
#Agent maintenance
scomadm ALL=(root) NOPASSWD: /usr/bin/sh -c cp /tmp/scx-scomadm/scx.pem /etc/opt/microsoft/scx/ssl/scx.pem; rm -rf /tmp/scx-scomadm; /opt/microsoft/scx/bin/tools/scxadmin -restart
#SOLARIS 10
scomadm ALL=(root) NOPASSWD: /usr/bin/sh -c sh /tmp/scx-scomadm/scx-1.[5-9].[0-9]-[0-9][0-9][0-9].solaris.10.sparc.sh --install *
scomadm ALL=(root) NOPASSWD: /usr/bin/sh -c sh /tmp/scx-scomadm/scx-1.[5-9].[0-9]-[0-9][0-9][0-9].solaris.10.sparc.sh --upgrade --force *
scomadm ALL=(root) NOPASSWD: /usr/bin/sh -c sh /tmp/scx-scomadm/scx-1.[5-9].[0-9]-[0-9][0-9][0-9].solaris.10.x86.sh --install *
scomadm ALL=(root) NOPASSWD: /usr/bin/sh -c sh /tmp/scx-scomadm/scx-1.[5-9].[0-9]-[0-9][0-9][0-9].solaris.10.x86.sh --upgrade --force *
#SOLARIS 11
scomadm ALL=(root) NOPASSWD: /usr/bin/sh -c sh /tmp/scx-scomadm/scx-1.[5-9].[0-9]-[0-9][0-9][0-9].solaris.1[[\:digit\:]].x86.sh --install ; EC=$?; cd /tmp; rm -rf /tmp/scx-scomadm; exit $EC
scomadm ALL=(root) NOPASSWD: /usr/bin/sh -c sh /tmp/scx-scomadm/scx-1.[5-9].[0-9]-[0-9][0-9][0-9].solaris.1[[\:digit\:]].x86.sh --upgrade --force ; EC=$?; cd /tmp; rm -rf /tmp/scx-scomadm; exit $EC
scomadm ALL=(root) NOPASSWD: /usr/bin/sh -c sh /tmp/scx-scomadm/scx-1.[5-9].[0-9]-[0-9][0-9][0-9].solaris.1[[\:digit\:]].sparc.sh --install ; EC=$?; cd /tmp; rm -rf /tmp/scx-scomadm; exit $EC
scomadm ALL=(root) NOPASSWD: /usr/bin/sh -c sh /tmp/scx-scomadm/scx-1.[5-9].[0-9]-[0-9][0-9][0-9].solaris.1[[\:digit\:]].sparc.sh --upgrade --force ; EC=$?; cd /tmp; rm -rf /tmp/scx-scomadm; exit $EC
##Uninstall
###Examples
Sample Configurations System Center 2012
The actual list of commands used for privileged monitoring or agent maintenance varies between platforms. The sample configurations below provide a user named “monuser” with the minimum necessary authorization to perform the following activities:
  • Upgrade the agent
System Center 2012 SP1 & R2 - Operations Manager
These configurations apply to System Center 2012 SP1 - Operations Manager and to System Center 2012 R2 - Operations Manager. Example configurations for System Center 2012 - Operations Manager are listed in the next section.
AIX
#User configuration for Operations Manager agent – for
a user with the name: monuser
Defaults:monuser !requiretty
#Agent maintenance (discovery, install, uninstall, upgrade, restart, cert signing)
monuser ALL=(root) NOPASSWD: /bin/sh -c cp /tmp/scx-monuser/scx.pem /etc/opt/microsoft/scx/ssl/scx.pem; rm -rf /tmp/scx-monuser; /opt/microsoft/scx/bin/tools/scxadmin -restart
monuser ALL=(root) NOPASSWD: /bin/sh -c sh /tmp/scx-monuser/GetOSVersion.sh; EC=$?; rm -rf /tmp/scx-monuser; exit $EC
monuser ALL=(root) NOPASSWD: /bin/sh -c cat /etc/opt/microsoft/scx/ssl/scx.pem
monuser ALL=(root) NOPASSWD: /bin/sh -c /usr/sbin/installp -u scx
monuser ALL=(root) NOPASSWD: /usr/bin/sh -c gzip -dqf /tmp/scx-monuser/scx-1.[0-9].[0-9]-[0-9][0-9][0-9].aix.[0-9].ppc.lpp.gz;/usr/sbin/installp -a -d /tmp/scx-monuser/scx-1.[0-9].[0-9]-[0-9][0-9][0-9].aix.[0-9].ppc.lpp scx; EC=$?; cd /tmp; rm -rf /tmp/scx-monuser;
exit $EC
monuser ALL=(root) NOPASSWD: /opt/microsoft/scx/bin/scxlogfilereader -p
###Examples
#monuser ALL=(root) NOPASSWD: /bin/bash -c <shell command>
#monuser ALL=(root) NOPASSWD: /bin/sh -c ps -ef | grep cron | grep -v grep
#monuser ALL=(root) NOPASSWD: /usr/sbin/cron &
HP-UX
#User configuration for Operations Manager agent – for a user with the name: monuser
monuser ALL=(root) NOPASSWD: /usr/bin/sh -c sh /tmp/scx-monuser/GetOSVersion.sh; EC=$?; rm -rf /tmp/scx-monuser; exit $EC
#ia64
monuser ALL=(root) NOPASSWD: /usr/bin/sh -c uncompress -f /tmp/scx-monuser/scx-1.[0-9].[0-9]-[0-9][0-9][0-9].hpux.11iv[0-9].ia64.depot.Z;/usr/sbin/swinstall -s /tmp/scx-monuser/scx-1.[0-9].[0-9]-[0-9][0-9][0-9].hpux.11iv[0-9].ia64.depot scx; EC=$?; cd /tmp;
#parisc
monuser ALL=(root) NOPASSWD: /usr/bin/sh -c uncompress -f /tmp/scx-monuser/scx-1.[0-9].[0-9]-[0-9][0-9][0-9].hpux.11iv[0-9].parisc.depot.Z;/usr/sbin/swinstall -s /tmp/scx-monuser/scx-1.[0-9].[0-9]-[0-9][0-9][0-9].hpux.11iv[0-9].parisc.depot scx; EC=$?; cd /tmp;
monuser ALL=(root) NOPASSWD: /usr/bin/sh -c cat /etc/opt/microsoft/scx/ssl/scx.pem
monuser ALL=(root) NOPASSWD: /usr/bin/sh -c cp /tmp/scx-monuser/scx.pem /etc/opt/microsoft/scx/ssl/scx.pem; rm -rf /tmp/scx-monuser; /opt/microsoft/scx/bin/tools/scxadmin -restart
monuser ALL=(root) NOPASSWD: /usr/bin/sh -c /usr/sbin/swremove scx
#Logfile monitoring
###Examples
Linux - RHEL
monuser ALL=(root) NOPASSWD: /bin/sh -c rpm -e scx
monuser ALL=(root) NOPASSWD: /bin/sh -c /bin/rpm -F --force /tmp/scx-monuser/scx-1.[0-9].[0-9]-[0-9][0-9][0-9].rhel.[0-9].x[6-8][4-6].rpm; EC=$?; cd /tmp; rm -rf /tmp/scx-monuser; exit $EC
monuser ALL=(root) NOPASSWD: /bin/sh -c /bin/rpm -U --force /tmp/scx-monuser/scx-1.[0-9].[0-9]-[0-9][0-9][0-9].rhel.[0-9].x[6-8][4-6].rpm; EC=$?; cd /tmp; rm -rf /tmp/scx-monuser; exit $EC
###Examples
Linux - SLES
#SLES 9
monuser ALL=(root) NOPASSWD: /bin/sh -c /bin/rpm -F --force /tmp/scx-monuser/scx-1.[0-9].[0-9]-[0-9][0-9][0-9].sles.9.x[6-8][4-6].rpm; EC=$?; cd /tmp; rm -rf /tmp/scx-monuser; exit $EC
monuser ALL=(root) NOPASSWD: /bin/sh -c /bin/rpm -U --force /tmp/scx-monuser/scx-1.[0-9].[0-9]-[0-9][0-9][0-9].sles.9.x[6-8][4-6].rpm; EC=$?; cd /tmp; rm -rf /tmp/scx-monuser; exit $EC
#SLES 10, 11 or 12
monuser ALL=(root) NOPASSWD: /bin/sh -c /bin/rpm -F --force /tmp/scx-monuser/scx-1.[0-9].[0-9]-[0-9][0-9][0-9].sles.1[0|1|2].x[6-8][4-6].rpm; EC=$?; cd /tmp; rm -rf /tmp/scx-monuser; exit $EC
monuser ALL=(root) NOPASSWD: /bin/sh -c /bin/rpm -U --force /tmp/scx-monuser/scx-1.[0-9].[0-9]-[0-9][0-9][0-9].sles.1[0|1|2].x[6-8][4-6].rpm; EC=$?; cd /tmp; rm -rf /tmp/scx-monuser; exit $EC
###Examples
Linux - Universal DEB (Debian, Ubuntu)
-restart
monuser ALL=(root) NOPASSWD: /bin/sh -c dpkg -P scx
monuser ALL=(root) NOPASSWD: /bin/sh -c dpkg -i /tmp/scx-monuser/scx-1.[0-9].[0-9]-[0-9][0-9][0-9].universald.1.x[6-8][4-6].deb; EC=$?; cd /tmp; rm -rf /tmp/scx-monuser; exit $EC
###Examples
Linux - Universal RPM (CentOS, Oracle)
-restart
monuser ALL=(root) NOPASSWD: /bin/sh -c /bin/rpm -F --force /tmp/scx-monuser/scx-1.[0-9].[0-9]-[0-9][0-9][0-9].universalr.[0-9].x[6-8][4-6].rpm; EC=$?; cd /tmp; rm -rf /tmp/scx-monuser; exit $EC
monuser ALL=(root) NOPASSWD: /bin/sh -c /bin/rpm -U --force /tmp/scx-monuser/scx-1.[0-9].[0-9]-[0-9][0-9][0-9].universalr.[0-9].x[6-8][4-6].rpm; EC=$?; cd /tmp; rm -rf /tmp/scx-monuser; exit $EC
###Examples
Solaris
# Defaults specification
Defaults:monuser passwd_tries = 1, passwd_timeout = 1
##OS Discovery Script
monuser ALL=(root) NOPASSWD: /usr/bin/sh -c sh /tmp/scx-monuser/GetOSVersion.sh; EC=??; rm -rf /tmp/scx-monuser; exit ?EC
#Agent install and upgrade
#Solaris 9
monuser ALL=(root) NOPASSWD: /usr/bin/sh -c echo -e "mail=*/usr/sbin/pkgadd -a /tmp/scx-monuser/scx -n -d /tmp/scx-monuser/scx-1.[0-9].[0-9]-[0-9][0-9][0-9].solaris.9.sparc.pkg
MSFTscx;*exit ?EC
#Solaris 10 or 11
monuser ALL=(root) NOPASSWD: /usr/bin/sh -c echo -e "mail=*/usr/sbin/pkgadd -a /tmp/scx-monuser/scx -n -d /tmp/scx-monuser/scx-1.[0-9].[0-9]-[0-9][0-9][0-9].solaris.1[0-1].sparc.pkg
MSFTscx;*exit ?EC
monuser ALL=(root) NOPASSWD: /usr/bin/sh -c echo -e "mail=*/usr/sbin/pkgadd -a /tmp/scx-monuser/scx -n -d /tmp/scx-monuser/scx-1.[0-9].[0-9]-[0-9][0-9][0-9].solaris.1[0-1].x86.pkg MSFTscx;*exit ?EC
##Agent uninstall
monuser ALL=(root) NOPASSWD: /usr/bin/sh -c rm -rf /tmp/scx-monuser;*/usr/sbin/pkgrm -a /tmp/scx-monuser/scx -n MSFTscx;*exit ?EC
##Agent control
monuser ALL=(root) NOPASSWD: /opt/microsoft/scx/bin/tools/scxadmin
These configurations apply to System Center 2012 - Operations Manager
AIX
#Lower sudo password prompt timeout for the user
monuser ALL=(root) NOPASSWD: /usr/bin/sh -c sh /tmp/scx-*/GetOSVersion.sh; EC=$?; rm -rf /tmp/scx-*; exit $EC
monuser ALL=(root) NOPASSWD: /usr/bin/sh -c gzip -dqf /tmp/scx-*
monuser ALL=(root) NOPASSWD: /usr/bin/sh -c echo *
monuser ALL=(root) NOPASSWD: /usr/bin/sh -c /usr/sbin/installp -u scx
###Examples
HP-UX
monuser ALL=(root) NOPASSWD: /bin/sh -c sh /tmp/scx-*/GetOSVersion.sh; EC=$?; rm -rf /tmp/scx-*; exit $EC
monuser ALL=(root) NOPASSWD: /bin/sh -c uncompress -f /tmp/scx-*
monuser ALL=(root) NOPASSWD: /bin/sh -c echo *
monuser ALL=(root) NOPASSWD: /bin/sh -c /usr/sbin/swremove scx
###Examples
#monuser ALL=(root) NOPASSWD: /sbin/init.d/cron start
 Linux
monuser ALL=(root) NOPASSWD: /bin/sh -c /bin/rpm -U --force */scx-*
monuser ALL=(root) NOPASSWD: /bin/sh -c /bin/rpm -F --force */scx-*
###Examples
#monuser ALL=(root) NOPASSWD: /sbin/service cron start
Solaris
monuser ALL=(root) NOPASSWD: /usr/bin/sh -c rm -rf /tmp/scx-*
###Examples
#monuser ALL=(root) NOPASSWD: sh -c '/etc/init.d/cron start'
Troubleshooting
Sudo log
The best way to troubleshoot authentication failures that may be related to sudoers configuration s to inspect the sudo log on the agent host. Sudo logging is controlled in sudoers, with the Defaults parameter logfile. For example, the line: Defaults logfile=/var/log/sudolog nables sudo logging to the file /var/log/sudolog.
Password Prompts and Timeouts
Operations Manager’s use of sudo elevation requires passwordless elevation. By default, sudo will prompt for a password if a command is not configured with NOPASSWD for the user (this may happen if a specific command was not configured for the user, or if the NOPASSWD option was not set). It is recommended that you configure the following option in sudoers for the user account: Defaults:monuser passwd_tries = 1, passwd_timeout = 1. This example sets a one minute password prompt timeout for the user monuser, which allows the command to fail quickly if a sudo configuration problem exists.
