This DirectAccess Test Lab Extension for DirectAccess in Windows Server 2008 R2 describes how to configure remote management for the DirectAccess clients of the corp.contoso.com domain. You configure and test remote management of CLIENT1 from APP1 with a remote desktop connection.
Note These instructions are designed for a working DirectAccess test lab that is configured from the instructions found in the Test Lab Guide: Demonstrate DirectAccess document.
If you are running the DirectAccess Test Lab in a virtual environment, you can create snapshots of the virtual machines (VMs) for all of the test lab computers before performing the following procedures.
Configuring and Demonstrating Remote Management
To demonstrate the lack of remote management capability of CLIENT1 from APP1 using a remote desktop connection:
APP1 cannot initiate a remote desktop connection to CLIENT1 when there is no user logged on because there are no IPsec tunnels that allow incoming traffic from APP1. When no one has logged on to CLIENT1, the only IPsec tunnel in place is the infrastructure tunnel, which only allows traffic from 2002:836b:2:1:0:5efe:10.0.0.2, the ISATAP address of DC1. After a user has logged on to CLIENT1, the intranet tunnel is used to carry the remote desktop connection traffic between CLIENT1 and APP1.
To allow APP1 to remotely manage CLIENT1 even when there is no user logged on, you must add 2002:836b:2:1:0:5efe:10.0.0.3, the ISATAP address of APP1, to the list of management servers in Step 3 of the DirectAccess Setup Wizard.
To configure APP1 as a management server:
To update CLIENT1 and demonstrate remote management with a remote desktop connection:
By configuring APP1’s ISATAP address as a management server, the DirectAccess Setup Wizard configures a connection security rule for a management tunnel on DA1 and CLIENT1. This management tunnel, which is separate from the infrastructure and intranet tunnels, allows APP1 to initiate communication with DirectAccess clients even when there is no user logged on.
If you are running the DirectAccess Test Lab in a virtual environment, you can discard the changes made by these procedures by restoring the previously made snapshots of the VMs for all of the computers in the test lab. Alternately, if you would like return to a working DirectAccess configuration with remote management configured, you can create a new set of snapshots before restoring the previously made snapshots.
To manually restore the configuration of the DirectAccess Test Lab, perform the following procedure.
Restoring the DirectAccess Test Lab
To restore the DirectAccess Test Lab to its original configuration:
For additional DirectAccess Test Lab extensions and other resources for the DirectAccess Test Lab, click here.
