The information provided in this article are intended to help troubleshoot some of the common connectivity error messages that you would see while connecting to SQL Azure.
Note: For more information on handling connection-losses while your application runs, see Connection Management in SQL Azure.
Return to Top
If you can not connect to SQL Azure database from SQL Server Management Studio (SSMS), it could be the SSMS version. The SQL Server Management Studio from SQL Server 2008 R2 with SP1 and SQL Server 2008 R2 Express with SP1 can be used to access, configure, manage and administer SQL Azure Database. Previous versions of SQL Server Management Studio are not supported.
The links to get the latest updates available in SQL Server 2008 R2 SP1 are:
When a computer attempts to connect to your SQL Azure server from the Internet, the SQL Azure firewall checks the originating IP address of the request against the full set of firewall settings. If the IP address of the request is not within one of the ranges specified, the connection attempt is blocked and does not reach the SQL Azure server. Being blocked by the SQL Azure firewall is usually self evident because the service returns a specific error message similar to the one below:
C:\>SQLCMD –U<user>@<server> -P<password> -S<server>.database.windows.net
Cannot open server 'ljvt54v9zo' requested by the login. Client with IP address '131.107.0.111' is not allowed to access the server. To enable access, use the SQL Azure Portal or run sp_set_firewall_rule on the master database to create a firewall rule for this IP address or address range. It may take up to five minutes for this change to take effect. Note: SQL Auzre Portal has been replaced by Windows Azure Platform Management Portal.
To ensure that the SQL Azure firewall is correctly configured, perform the following steps.
Reference: SQL Azure Firewall - http://msdn.microsoft.com/en-us/library/ee621782.aspx
Note: If the Microsoft Services firewall isn’t enabled you must enable it and wait up to 5 minutes for the firewall setting to take effect. If you attempt to test connectivity without waiting for 5 minutes, you will continue to receive the error until the firewall setting takes effect.
Reference: How and when to contact Microsoft Customer Service and Support - http://support.microsoft.com/kb/295539
C:\>ping <myserver>.database.windows.net
Pinging data.sn1-1.database.windows.net [65.55.74.144] with 32 bytes of data: Request timed out. Request timed out. Request timed out. Request timed out. Ping statistics for 65.55.74.144: Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
Request timed out.
C:\>telnet 65.55.74.144 1433 Connecting To 65.55.74.144...
Reference: Telnet Troubleshooting Guide - http://technet.microsoft.com/en-us/library/cc753360(WS.10).aspx
C:\>telnet <myserver>.database.windows.net 1433
Note: If Telnet is not part of your default windows installation, you may enable it from Add/Remove Windows Components.
C:\>tracert 65.55.74.144 Tracing route to 65.55.74.144 over a maximum of 30 hops 1 2 ms 1 ms 1 ms 192.168.0.1 2 6 ms 5 ms 5 ms 10.33.34.50 3 5 ms 4 ms 5 ms 4-1-753.DLLSTX-LCR-07.verizon-gni.net [130.81.107.26] 4 8 ms 5 ms 5 ms so-6-2-0-0.DFW01-BB-RTR1.verizon-gni.net [130.81.28.208] 5 44 ms 43 ms 44 ms so-11-0-0-0.LCC1-RES-BB-RTR1-RE1.verizon-gni.net [130.81.17.40] 6 49 ms 44 ms 44 ms so-6-0-0-0.ASH-PEER-RTR1-re1.verizon-gni.net [130.81.10.90]
Reference: How to Use TRACERT to Troubleshoot TCP/IP Problems in Windows - http://support.microsoft.com/kb/314868
If you encountered difficulties when Verifying that You Can Reach the Server IP, then you are not reaching the VIP and are instead being blocked between your client and the VIP. The below steps may be helpful, but at this point an investigation by your ISP or network engineer is required.
Many firewall, router, and proxy products allow individual users and domain administrators to block or restrict outbound access on a specific port and or destination IP address. Therefore it is necessary to check the outbound rules that are defined on the local machine as well as any firewalls, routers or proxies that are between you and SQL Azure. Rules must allow outbound access on port 1433 to destination IP address range 65.55.*.*. Network products that might block access include:
Frequently Asked Questions - http://msdn.microsoft.com/en-us/library/bb736261(VS.85).aspx Windows Firewall with Advanced Security Getting Started Guide - http://technet.microsoft.com/en-us/library/cc748991(WS.10).aspx
Firewall rules can also be configured as part of domain policies and hence please work with your domain policies to check if there are any such rules that can block the connection.
For information on working with other firewall products, please consult the specific firewall product documentation.
If you are going through a proxy or router to connect to the internet, confirm the external IP address that is exposed on the internet. This is usually the IP address that the SQL Azure Firewall must allow in order for you to connect to the server. You can use http://www.whatismyip.com/ to find the external IP address that is used by the proxy or router to communicate with services on the Internet. The AddFirewallRule dialog box under SQL Azure Firewall Setting Tab in the portal will also list your external IP address.
Please repeat all the steps provided in Verify Azure Firewall Settings and Service Availability. This test would eliminate firewall and other policies that could potentially be blocking access from inside your network, and will indicate whether the problem is inside your networ or with your ISP's network.
Reference: How to capture network traffic with Network Monitor - http://support.microsoft.com/kb/148942
Review the trace by adding a filter TCP.port==1433 which would show conversations on TCP port 1433. If you do not see an ACK back from the server, it is highly likely that the connection is blocked on your network or over the internet.
A network snippet from a connection that was not successful:
11:12:27.007 25 {TCP:7, IPv4:6} 111.11.11.111 data.sn1-1.database.windows.net TCP TCP:Flags=......S., SrcPort=49411, DstPort=1433, PayloadLen=0, Seq=2375502765, Ack=0, Win=8192 ( Negotiating scale factor 0x8 ) = 8192 11:12:30.007 26 {TCP:7, IPv4:6} 111.11.11.111 data.sn1-1.database.windows.net TCP TCP:[SynReTransmit #25]Flags=......S., SrcPort=49411, DstPort=1433, PayloadLen=0, Seq=2375502765, Ack=0, Win=8192 ( Negotiating scale factor 0x8 ) = 8192 11:12:36.007 29 {TCP:7, IPv4:6} 111.11.11.111 data.sn1-1.database.windows.net TCP TCP:[SynReTransmit #25]Flags=......S., SrcPort=49411, DstPort=1433, PayloadLen=0, Seq=2375502765, Ack=0, Win=8192 ( Negotiating scale factor 0x8 ) = 8192 11:12:48.014 40 {TCP:12, IPv4:6} 111.11.11.111 data.sn1-1.database.windows.net TCP TCP:Flags=......S., SrcPort=49412, DstPort=Microsoft-DS(445), PayloadLen=0, Seq=3206081271, Ack=0, Win=8192 ( Negotiating scale factor 0x8 ) = 8192 11:12:49.015 41 {TCP:13, IPv4:6} 111.11.11.111 data.sn1-1.database.windows.net TCP TCP:Flags=......S., SrcPort=49413, DstPort=Microsoft-DS(445), PayloadLen=0, Seq=1361088072, Ack=0, Win=8192 ( Negotiating scale factor 0x8 ) = 8192 11:12:49.019 42 {IPv4:6} 111.11.11.111 data.sn1-1.database.windows.net ICMP ICMP:Echo Request Message, From 111.11.11.111 To 65.55.74.144 11:12:50.769 45 {IPv4:6} 111.11.11.111 data.sn1-1.database.windows.net ICMP ICMP:Echo Request Message, From 111.11.11.111 To 65.55.74.144 11:12:51.014 46 {TCP:12, IPv4:6} 111.11.11.111 data.sn1-1.database.windows.net TCP TCP:[SynReTransmit #40]Flags=......S., SrcPort=49412, DstPort=Microsoft-DS(445), PayloadLen=0, Seq=3206081271, Ack=0, Win=8192 ( Negotiating scale factor 0x8 ) = 8192 11:12:52.015 47 {TCP:13, IPv4:6} 111.11.11.111 data.sn1-1.database.windows.net TCP TCP:[SynReTransmit #41]Flags=......S., SrcPort=49413, DstPort=Microsoft-DS(445), PayloadLen=0, Seq=1361088072, Ack=0, Win=8192 ( Negotiating scale factor 0x8 ) = 8192 11:12:52.771 48 {TCP:14, IPv4:6} 111.11.11.111 data.sn1-1.database.windows.net TCP TCP:Flags=......S., SrcPort=49414, DstPort=NETBIOS Session Service(139), PayloadLen=0, Seq=265110652, Ack=0, Win=8192 ( Negotiating scale factor 0x8 ) = 8192 11:12:55.771 49 {TCP:14, IPv4:6} 111.11.11.111 data.sn1-1.database.windows.net TCP TCP:[SynReTransmit #48]Flags=......S., SrcPort=49414, DstPort=NETBIOS Session Service(139), PayloadLen=0, Seq=265110652, Ack=0, Win=8192 ( Negotiating scale factor 0x8 ) = 8192 11:12:57.021 52 {TCP:12, IPv4:6} 111.11.11.111 data.sn1-1.database.windows.net TCP TCP:[SynReTransmit #40]Flags=......S., SrcPort=49412, DstPort=Microsoft-DS(445), PayloadLen=0, Seq=3206081271, Ack=0, Win=8192 ( Negotiating scale factor 0x8 ) = 8192 11:12:58.016 53 {TCP:13, IPv4:6} 111.11.11.111 data.sn1-1.database.windows.net TCP TCP:[SynReTransmit #41]Flags=......S., SrcPort=49413, DstPort=Microsoft-DS(445), PayloadLen=0, Seq=1361088072, Ack=0, Win=8192 ( Negotiating scale factor 0x8 ) = 8192 11:13:01.771 56 {TCP:14, IPv4:6} 111.11.11.111 data.sn1-1.database.windows.net TCP TCP:[SynReTransmit #48]Flags=......S., SrcPort=49414, DstPort=NETBIOS Session Service(139), PayloadLen=0, Seq=265110652, Ack=0, Win=8192 ( Negotiating scale factor 0x8 ) = 8192
Here we can see that the client is trying to establish a connection to SQL Azure and keeps retransmitting three times and fails. This trace indicates that the connection did not even reach our VIP and hence the connection is likely blocked in the client’s network or over the Internet.
Snippet of trace from a successful connection:
14:50:01.512 847 SQLCMD.EXE {TCP:428, IPv4:427} 99.99.999.99 157.54.118.18 TCP TCP:Flags=......S., SrcPort=13415, DstPort=1433, PayloadLen=0, Seq=4009972475, Ack=0, Win=8192 ( Negotiating scale factor 0x2 ) = 8192 14:50:01.515 848 SQLCMD.EXE {TCP:428, IPv4:427} 157.54.118.18 99.99.999.99 TCP TCP:Flags=...A..S., SrcPort=1433, DstPort=13415, PayloadLen=0, Seq=2117383693, Ack=4009972476, Win=8192 ( Scale factor not supported ) = 8192 14:50:01.516 849 SQLCMD.EXE {TCP:428, IPv4:427} 99.99.999.99 157.54.118.18 TCP TCP:Flags=...A...., SrcPort=13415, DstPort=1433, PayloadLen=0, Seq=4009972476, Ack=2117383694, Win=17040 (scale factor 0x0) = 17040
The above snippet represents a successful three-way handshake.
SQL Azure utilizes techniques to prevent denial of service attacks. If your connection is getting reset by our service due to a potential DOS attack you would be able to see a three way handshake established and then a RESET in your network trace.
The information presented in this article was originally contained in the SQL Azure Connectivity Troubleshooting Guide published on the SQL Azure Team's blog; it has been relocated here so that the troubleshooting guide is easier to update and can be contributed to by the community. The author of the original information contained in this article is Abi Iyer.
Thanks for the great link
