Benutzer mit den meisten Antworten
Could not open the connection when using SSIS Script Task in control flow
Hi,
I'm trying to execute a package that runs a Script Task in a control flow of a SSIS BI project with the following code (the Script Task output is connected to the input of a Data Flow Task), but it's not working, it doesn't open the connection:
using System;
using System.Data;
using Microsoft.SqlServer.Dts.Runtime;
using System.Windows.Forms;
#endregion
namespace ST_7e5ba488e75e4b9ca4a3f2e3fa831dbd
[Microsoft.SqlServer.Dts.Tasks.ScriptTask.SSISScriptTaskEntryPointAttribute]
public partial class ScriptMain : Microsoft.SqlServer.Dts.Tasks.ScriptTask.VSTARTScriptObjectModelBase
public void Main()
System.Data.OleDb.OleDbConnection oleDbConn;
System.Data.OleDb.OleDbCommand oleDbCommand;
String sql;
String formattedDate = System.DateTime.Now.ToString("yyyy-MM-dd");
String connString = "Data Source=AFDB02;Initial Catalog = AdventureWorks2014; Provider = SQLNCLI11.1; Integrated Security = SSPI; Auto Translate = False; ";
oleDbConn = new System.Data.OleDb.OleDbConnection(connString);
try
oleDbConn.Open();
sql = "SELECT MAX(LastModifiedDate) as lastModifiedDate from dbo.CustomerDetails";
oleDbCommand = new System.Data.OleDb.OleDbCommand(sql, oleDbConn);
Object date = oleDbCommand.ExecuteScalar();
if (date == null || date.ToString() == "")
Dts.TaskResult = (int)ScriptResults.Success;
else
DateTime ResultDate = Convert.ToDateTime(date);
String formattedResultDate = ResultDate.ToString("yyyy-MM-dd");
if (formattedDate != formattedResultDate)
else
MessageBox.Show("Data already inserted for the day");
Dts.TaskResult = (int)ScriptResults.Failure;
catch
MessageBox.Show("Could not open connection!");
#region ScriptResults declaration
enum ScriptResults
Success = Microsoft.SqlServer.Dts.Runtime.DTSExecResult.Success,
Failure = Microsoft.SqlServer.Dts.Runtime.DTSExecResult.Failure
I'm using Visual Studio Community 2015 and SQL Server for developer edition.
I'm getting the message "Could not open connection!" but I don't see why... is there something wrong with the provider in the connection string ?
Can somebody help ?
Thanks
Frage
Antworten
Yes, that's a Connection string for SqlClient, while you use OleDB (why?), see https://www.connectionstrings.com/sql-server-native-client-9-0-oledb-provider/
Add an exception handling to get the full error message.
catch (Exception ex) { MessageBox.Show(ex.Message); }
Olaf Helper
[ Blog] [ Xing] [ MVP]- Als Antwort vorgeschlagen Visakh16MVP Freitag, 13. April 2018 08:36
- Als Antwort markiert MicroSup Mittwoch, 18. April 2018 14:01
I added the exception handling to get the error message and here is below what it says :
Login timeout expired
A network-related or instance-specific error occurered while establishing a connection to SQL Server.
Server is not found or not accessible. Check if instance name is correct and if SQL Server is configured to allow remote connections.
For more information see SQL Server Books Online.
Named Pipes Provider: Could not open a connection to SQL Server [53].
I checked SQL Server is configured to allow remote connections.
I checked "Provider = SQLNCLI11" is OleDb connection type.
I'm using SQL Server 2016 Developer edition Version 13.0.1742.0. and it's running on the same machine O/S Windows 10 Pro than the SSIS package I'm trying to run. I tried to change the syntax of the connection string to :
String connString = "Provider = SQLNCLI11; Server=localhost;Database=AFDB02; Integrated Security = SSPI; ";
but I'm getting the same error message with only difference [2] instead of [53].
Any idea ?
- Als Antwort markiert MicroSup Mittwoch, 25. April 2018 11:28
Alle Antworten
Olaf Helper
Any idea ?
