Problem with copying cells - master file project pro 2010 RRS feed
  • Hello,
    when i am copying cells from master file and trying to copy them to onother project file or even to master file .... project and all ohers open software are closed
    i am using:
    project professional 2010 sp1
    Win xp 2G
    any idea ?
    Wednesday, April 4, 2012 5:09 AM
  • Hi Michals10,
    Please copy less number of Cells at a time, as copying large number of cells could lead to out of memory issues when Cells are formatted (Font,Conditional Formats etc.). Also, when you open a Master Project, it opens all the sub-projects in backend this also eats up lot of memory, so you should close all the non-required Applications and Services to free-up memory using Task Manager.
    Sapna S
    Wednesday, April 4, 2012 6:21 AM
  • Are you using some shortcut to paste the files?
    If you are using shortcut then try by doing a right click and then paste.
    Just post the results what happens if you do this.
    Abhijeet M. Mohite
    Wednesday, April 4, 2012 5:29 AM
  • Hi Michals10,
    Sapna S
