Web Parts Maintenance Page Error RRS feed
  • Hi all,
    I have a few WSp's which will create some files through features. I tried to browse the pages that were created by the feature. and I get the Web Parts Maintenance Error. I see the Logs and found the following. Does anyone has the clue?
    05/14/2012 15:00:46.29     w3wp.exe (0x2B38)                           0x2EBC    SharePoint Foundation             Monitoring                        b4ly    Medium      Leaving Monitored Scope (ExecuteWcfServerOperation). Execution Time=0.317358770458257    97ceced9-89f8-46d4-88f9-d62e706a1471
    05/14/2012 15:00:46.40     w3wp.exe (0x2F60)                           0x29B8    SharePoint Foundation             General                           b9y3    High        Failed to open the file 'C:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\14\Template\Features\Adidas.Sep.CalendarTaskContentType_CalendarTaskContentType\Resources\Resources.en-US.resx'.    97ceced9-89f8-46d4-88f9-d62e706a1471
    05/14/2012 15:00:46.40     w3wp.exe (0x2F60)                           0x29B8    SharePoint Foundation             General                           b9y4    High        #2006e: The specified path "" does not exist.    97ceced9-89f8-46d4-88f9-d62e706a1471
    05/14/2012 15:00:46.40     w3wp.exe (0x2F60)                           0x29B8    SharePoint Foundation             General                           b9y9    High        Failed to read resource file "C:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\14\Template\Features\Adidas.Sep.CalendarTaskContentType_CalendarTaskContentType\Resources\Resources.en-US.resx" from feature id "f858f846-fab6-42b3-98a2-cabeb5b5ab0b".    97ceced9-89f8-46d4-88f9-d62e706a1471
    05/14/2012 15:00:46.40     w3wp.exe (0x2F60)                           0x29B8    SharePoint Foundation             General                           8e26    Medium      Failed to open the language resource for Feaf858f846-fab6-42b3-98a2-cabeb5b5ab0b keyfile Resources.    97ceced9-89f8-46d4-88f9-d62e706a1471
    05/14/2012 15:00:46.40     w3wp.exe (0x2F60)                           0x29B8    SharePoint Foundation             General                           b9y3    High        Failed to open the file 'C:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\14\Template\Features\Adidas.Sep.CalendarTaskContentType_CalendarTaskContentType\Resources\Resources.resx'.    97ceced9-89f8-46d4-88f9-d62e706a1471
    05/14/2012 15:00:46.40     w3wp.exe (0x2F60)                           0x29B8    SharePoint Foundation             General                           b9y9    High        Failed to read resource file "C:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\14\Template\Features\Adidas.Sep.CalendarTaskContentType_CalendarTaskContentType\Resources\Resources.resx" from feature id "f858f846-fab6-42b3-98a2-cabeb5b5ab0b".    97ceced9-89f8-46d4-88f9-d62e706a1471
    05/14/2012 15:00:46.40     w3wp.exe (0x2F60)                           0x29B8    SharePoint Foundation             General                           8l3c    Medium      Localized resource for token 'Direction' could not be found for file with path: "C:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\14\Template\Features\Adidas.Sep.CalendarTaskContentType_CalendarTaskContentType\CalendarsBUMappingLD\schema.xml".    97ceced9-89f8-46d4-88f9-d62e706a1471
    Also on some other files. I get the same error but with a different Exception as follows.
    Session state can only be used when enableSessionState is set to true, either in a configuration file or in the Page directive. Please also make sure that System.Web.SessionStateModule or a custom session state module is included in the <configuration>\<system.web>\<httpModules> section in the application configuration.    at System.Web.UI.Page.get_Session()     at Adidas.Sep.Planning.UI.Webparts.TargetSetting.TargetSetting.CreateChildControls()
    I have created the Session State under httpModules and enables sessionstate in Pages directive in web.config. Please direct me
    K.V.N.PAVAN
    • Edited by Pa1 Kumar Monday, May 14, 2012 1:08 PM
    Monday, May 14, 2012 1:05 PM
  • Pa1 Kumar  what is the correlation id for this error, have you check the same with PowerShell command
    If not then use the PowerShell command  with correlation id   you will get  appropriate  error  or you can use uLS viewer for the  same
    hope it will help you ...
    Monday, May 14, 2012 1:42 PM
  • Hey kamal Thanx for the reply, The correlation Id for this Error is 97ceced9-89f8-46d4-88f9-d62e706a1471 .What do you mean by using Powershell Command. how can I open a Page using the Powershell command? please help.
    Thanks,
    K.V.N.PAVAN
    Monday, May 14, 2012 4:34 PM
