help make my coputer into a hot spot for other devices im not smart so i need soomone to do it RRS feed
  • Hi cj, open this link and read through, there are screen shots to also help. http://www.ostoto.com/wifi/how-to-turn-laptop-notebook-into-wifi-hotspot-on-windows-10-8-7-xp-vista.html. You can click on answer if the link helped.
    Sunday, September 18, 2016 8:29 PM
  • i. From control panel, click on network and sharing centre(this should be done after you are already connected to the LAN).
    ii. Click Local area connection > Properties > Sharing Tab
    iii. Check Allow other network user to connect... Then click OK > close.
    iv. Go back to network and sharing center. Click on "Set up a new connection or network"
    v.Choose "Set up a wireless ad hoc" > Next and then follow the prompts. Click on Save this network(once done)
    Tuesday, September 20, 2016 5:15 PM
