Answered by:
Interaction problem between Lync and Outlook and phone numbers problem
The following problems occurred while using Microsoft Lync 2013 (15.0.4420.1017) MSO (15.0.4420.1017) 32-bit and Microsoft Outlook 2013 (15.0.4420.1017) MSO (15.0.4420.1017) 32-bit (both are parts of Microsoft Office Professional Plus 2013).
- The first problem is with Outlook data file. If I run outlook with administrator right (Run as administrator) and run Lync, then this error will appear: "The file C:\Users\user\AppData\Local\Microsoft\Outlook\username.ost
is in use and cannot be accessed. Close any application that is using this file, and then try again.
You might need to restart your computer".
- Another problem is that if I log in Lync under one account and find a contact I will see a list of his phone numbers. But if I log in Lync under another account and find the same contact, the list of this phone numbers may be different. Some phone options (work, mobile, etc.) may disappear or other may appear. Sometimes list of phone options may change without changing account.
- Edited by Union33 Friday, June 10, 2016 1:31 PM
Friday, June 10, 2016 1:29 PM - The first problem is with Outlook data file. If I run outlook with administrator right (Run as administrator) and run Lync, then this error will appear: "The file C:\Users\user\AppData\Local\Microsoft\Outlook\username.ost
Hi ,
Lets make sure that we clean up the cache and local files for Lync client and make a fresh login. Please do the following
Delete local cache files on client computer.
Exit from the Lync client
%userprofile%\AppData\Local\Microsoft\Office\15.0\Lync\sip_UserName@Domain.com(Delete this folder)
Registry Key: HKCU\Software\Microsoft\Office\15.0\Lync\UserName@Domain.com
Login again and Test the behaviour.
For Outlook issue , try to configure a new profile and check if that resolves the problem.
Linus
- Proposed as answer by Eason Huang Monday, June 13, 2016 9:30 AM
- Marked as answer by Eason Huang Thursday, June 23, 2016 2:36 AM
Friday, June 10, 2016 6:12 PM -
You should also use the latetst CU for the Client
https://support.microsoft.com/en-us/kb/3115033
There are also some fixes for showing no phone number on contacts.
regards Holger Technical Specialist UC
Saturday, June 11, 2016 8:47 AM -
Hi,
For different Lync accounts search same Lync account with different phone number result, you can also check if the be searched Lync account set different Privacy Relationship.
You can try to repair Office to test the issue as well.
Best Regards
Please remember to mark the replies as answers if they help, and unmark the answers if they provide no help. If you have feedback for TechNet Support, contact tnmff@microsoft.com.
Eason Huang
TechNet Community Support- Marked as answer by Eason Huang Thursday, June 23, 2016 2:36 AM
Monday, June 13, 2016 9:34 AM
Hi ,
Linus
Hi,
Best Regards
Eason Huang
