How to Split large PST into smaller parts? RRS feed
  • How to Split large PST into smaller parts
    Tuesday, October 20, 2020 9:31 AM
  • Split PST for Mac software helps avoids large PST corruption issues by splitting and categorizing them in smaller sizes. It uses its own PST split to avoid the risk of corruption of PST files due to the issue of being over-sized. This tool is fully capable of splitting all MS outlook items such as emails, folders, contacts, calendars, journals, etc. This software supports all Mac OS versions. The software gives a secure and complete risk-free split of data. You can download the free demo version software.
    Visit here:- https://www.mailvita.com/split-pst-for-mac/
    Tuesday, October 20, 2020 11:18 AM
  • Effortlessly know how to split PST file as direct divide is not agonizing but also not stress-free. You will necessary to download Split PST Tool Free Full Version that helps you for splitting to your Outlook PST format.
    You can refer here for more information: https://www.gaintools.com/split-pst/
    Wednesday, October 21, 2020 5:22 AM
  • There are many methods to split the PST files into smaller parts on the internet. There are manual approaches to divide the split PST files. But if you want to split the PST files with the accuracy then you should go for the professional method of using the an software such as PST Splitter Tool, which split the PST files into multiple file. It can also split the ANSI and UNICODE PST file.
    Wednesday, October 21, 2020 5:30 AM
  • You can split your large pst file in multiple pst file by following steps:
    1. Open MS Outlook. Click on file option.
    2. Go to account settings.
    3. From Data File tab click on Add button.
    4. Enter Outlook data file and click on OK.
    5. New PST file will be opened.
    6. Go to file click on open & export and then on import / export.
    7. Choose an export file from import and export wizard and click on Next.
    8. Choose outlook data file in export file windows.
    9. Select the folder you want to export.
    Wednesday, October 21, 2020 6:59 AM
