Surface Pro 2s and 3s having trouble swapping between wired and wireless networks. RRS feed
  • I am having a problem where a Surface Pro 2 or 3 device will be swapping from the wired to the wireless network. Associates take the Surface to meetings within the building. They unplug from the wired connection at their desk and automatically connect to the wireless network we have here. This will cause the PC to be none reachable across the network. When I ping the PC it attempts to resolve the other address. (If they are on the wireless network with the wireless IP scheme, and I attempt a ping, my PC attempts to ping the wired IP address instead of the wireless IP address.)
    There appears to be a problem where the DNS server isn't resolving the names. When I attempt to ping a device, the resolved IP address will be correct, but the targeted device wont be attached to that network. This results in non connectivity. then I can't WoL, can't reboot, can't scan, can't install updates, etc. The machines are coming out of compliance because management systems can't reach them. Apparently the DNS server is resolving the incorrect IP addresses when queried.
    Tuesday, February 16, 2016 9:35 PM
  • Hi Bullet Catcher,
                 1.>>If they are on the wireless network with the wireless IP scheme
                 What is your wireless IP scheme, does the wireless IP and wired IP in the same subnet or not? Please post the text of an unedited ipconfig /allof wired and wireless.
                 2.>>I attempt a ping, my PC attempts to ping the wired IP address instead of the wireless IP address
                  Please try to run “Nslookup”, which IP be resolved to the Surface? Wirelss IP or Wired IP? When analyze a DNS issue,plsease use “Nslookup”,”PING” may use other name server.
                 3.>> There appears to be a problem where the DNS server isn't resolving the names.
                  When the Surface join the wireless network, and get IP settings , did it register in DNS server successfully? You could run “ipconfig /registerdns” on Surface to register manually.
                  Then run “ipconfig /flushdns” on your side,clear the cache on your computer,run “Nslookup” to resolve again.
                 4. If you are using secure DNS dynamic update, please check the settings,make sure they register the record promptly, here is a link for the guide,it will be helpful:
         How to Secure DNS Updates on Microsoft DNS Servers
      Best Regards,
    Cartman
    Please remember to mark the replies as answers if they help and unmark them if they provide no help. If you have feedback for TechNet Support, contact tnmff@microsoft.com.
    Wednesday, February 17, 2016 6:08 AM
  • Is the wireless IP range NAT'd on the WAP?
    Depending on the WAP, you may be able to allow passthrough DHCP/DNS ip address allocation.
    Tuesday, February 16, 2016 10:00 PM
      Best Regards,
    Cartman
    1. What is your wireless IP scheme, does the wireless IP and wired IP in the same subnet or not? Please post the text of an unedited ipconfig /allof wired and wireless.
    My wired network is a 192.X.X.X/23; the wireless is 172.X.X.X/24.
    Wired ipconfig /all
    Windows IP Configuration
       Host Name . . . . . . . . . . . . : DHOLLAND
       Primary Dns Suffix  . . . . . . . : hix-domain.com
       Node Type . . . . . . . . . . . . : Hybrid
       IP Routing Enabled. . . . . . . . : No
       WINS Proxy Enabled. . . . . . . . : No
       DNS Suffix Search List. . . . . . : hix-domain.com
                                           hix-domain.com
                                           cinci.rr.com
    Ethernet adapter Ethernet 4:
       Connection-specific DNS Suffix  . : hix-domain.com
       Description . . . . . . . . . . . : dynadock Ethernet
       Physical Address. . . . . . . . . : 00-50-B6-68-7C-DB
       DHCP Enabled. . . . . . . . . . . : Yes
       Autoconfiguration Enabled . . . . : Yes
       IPv4 Address. . . . . . . . . . . : 192.9.201.36(Preferred)
       Subnet Mask . . . . . . . . . . . : 255.255.254.0
       Lease Obtained. . . . . . . . . . : Tuesday, February 16, 2016 2:43:18 PM
       Lease Expires . . . . . . . . . . : Wednesday, February 24, 2016 2:43:17 PM
       Default Gateway . . . . . . . . . : 192.9.200.1
       DHCP Server . . . . . . . . . . . : 192.9.200.24
       DNS Servers . . . . . . . . . . . : 192.9.200.24
                                           192.9.200.18
       NetBIOS over Tcpip. . . . . . . . : Enabled
    Wireless LAN adapter Local Area Connection* 2:
       Media State . . . . . . . . . . . : Media disconnected
       Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
       Physical Address. . . . . . . . . : B6-AE-2B-2A-05-D2
    Wireless LAN adapter Wi-Fi:
       Description . . . . . . . . . . . : Marvell AVASTAR Wireless-AC Network Controller
       Physical Address. . . . . . . . . : B4-AE-2B-2A-04-D3
    Wireless ipconfig /all
                                           hix-domain.com
                                           cinci.rr.com
       IPv4 Address. . . . . . . . . . . : 172.30.60.37(Preferred)
       Subnet Mask . . . . . . . . . . . : 255.255.255.0
       Lease Obtained. . . . . . . . . . : Tuesday, February 16, 2016 8:25:39 AM
       Lease Expires . . . . . . . . . . : Friday, February 19, 2016 9:55:51 AM
       Default Gateway . . . . . . . . . : 172.30.60.1
       DHCP Server . . . . . . . . . . . : 192.9.200.18
       DNS Servers . . . . . . . . . . . : 192.9.200.18
                                           192.9.200.24
    1. Please try to run “Nslookup”, which IP be resolved to the Surface? Wirelss IP or Wired IP?
    Nslookup Surface => DNS Server Name & IP Address (as expected)
    Address: 172.X.X.X wireless network
    192.X.X.X wired network
    Both IP addresses for each network is returned for an nslookup.
    1. When the Surface join the wireless network, and get IP settings , did it register in DNS server successfully? You could run “ipconfig /registerdns” on Surface to register manually.
    Yes, I can successfully add the Surface to the wireless network. An entry is created in the DNS server for the surface device with the wireless network’s IP address scheme.
    1. If you are using secure DNS dynamic update, please check the settings, make sure they register the record promptly, here is a link for the guide, it will be helpful:
    Additional Information
    When pining the Surface, I get consisit “Request Time Outs”
    P:\>nslookup surface2
    Server:  dcsrv01.hix-domain.com
    Address:  192.9.200.18
    Address:  172.30.60.67
    P:\>ping surface2
    Pinging surface2.hix-domain.com [172.30.60.67] with 32 bytes of data:
    Request timed out.
    Reply from 172.30.60.67: bytes=32 time=510ms TTL=128
    Reply from 172.30.60.67: bytes=32 time=2ms TTL=128
    Ping statistics for 172.30.60.67:
        Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
    Approximate round trip times in milli-seconds:
        Minimum = 2ms, Maximum = 510ms, Average = 171ms
    P:\>ping -t surface2
    Request timed out.
    Reply from 172.30.60.67: bytes=32 time=3ms TTL=128
    Request timed out.
        Packets: Sent = 14, Received = 12, Lost = 2 (14% loss),
        Minimum = 2ms, Maximum = 3ms, Average = 2ms
    Control-C
    Attempting to ping another surface device that is connected to the wired network using a Microsoft Surface Pro 3 docking station.
    P:\>ping Surface
    Pinging Surface2.Org Domain Name [172.30.60.23] with 32 bytes of data:
    Request timed out.
    Request timed out.
    Request timed out.
    Request timed out.
    Ping statistics for 172.30.60.23:
        Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
    P:\>ping Surface2
    Request timed out.
    Request timed out.
        Packets: Sent = 2, Received = 0, Lost = 2 (100% loss),
    Control-C
    ^C
    P:\>nslookup Surface2
    Server:  Domain_Controller.Org Domain Name
    Name:    Surface2.Org Domain Name
    Address:  192.9.201.14
    P:\>ping Surface2
    Request timed out.
    Reply from 172.30.60.23: bytes=32 time=3976ms TTL=128
    Reply from 172.30.60.23: bytes=32 time=2ms TTL=128
    Request timed out.
        Packets: Sent = 4, Received = 2, Lost = 2 (50% loss),
        Minimum = 2ms, Maximum = 3976ms, Average = 1989ms
    A consistency I am noticing is when a Surface device goes from the wireless to the wired network, other devices are still attempting to resolve the hostname to the IP address for the wireless network. The Surface’s Wireless NIC is no longer active because now the wired Ethernet NIC is being used (through a docking station)
    Wednesday, February 17, 2016 4:28 PM
    P:\>ping Surface2
    Request timed out.
    Request timed out.
        It seems 'Surface2' have 2 IP address in wireless, since when 'Surface2' joined wired network,and it still could be ping by another IP address,it maybe another device named 'Surface2' on the network. Please check in DHCP server, if they are belongs to one device or two?
    Best Regards,
    Cartman
    Thursday, February 18, 2016 1:36 AM
  • Correct. Surface2 has 2 ip addresses. 1 IP for the wired network. 192.9.201.X and 1 for the Wireless Network. 172.30.60.X.
    We use ACLs to allow traffic to pass through between the two subnets.
    Thursday, February 18, 2016 4:00 PM
                Do you mean the host 'Surface' usually get wireless IP ‘172.30.60.23’,and the host 'Surface2' usually get wireless IP ‘172.30.60.67’?
          >>P:\>ping Surface
            P:\>ping Surface2
                As you posted, no matter you ping Surface or Surface2,it always resolves to 'Surface2.Org Domain Name'.This could caused by other name sever or local cache when you run PING.
               1.Please clear the local cahe(ipconfig /flushdns),and check the local hosts file.
               2.If you have WINS server on your network,check the record about the problem host in the server.
               3.If you don't have WINS,clear the local NetBIOS cache(Nbtstat -r),and check local Lmhosts file.Or disable NetBIOS over TCP/IP,then test again.
    Best Regards,
    Cartman
    Friday, February 19, 2016 1:22 AM
  • No device usually gets a specific IP address. We use DHCP.
    The hosts file is empty after a ipconfig /flushdns. I don't think there should be anything in the host file.
    No WINS server.
    LMHosts file is also empty.
    Another observation.
    Given a SurfacePro3 named Surf3 attached to a Microsfot SP3 docking station, I ping from my PC, BCatcher. ping attempts to ping the wifi address of Surf3 (which I know is disabled because it is in the docking station) => Request timed out.
    nslookup => Surf3 and addresses for 192.Wired.Network.X and 172.Wireless.network.X are returned, as expected.
    BCatcher PC pings the literal IP address for Surf3 => Succesful ping
    BCatcher PC pings Surf3 => Request timed out.
    It looks like there is a problem resolving the hostname when attempting to ping. I can ping the IP no problem, but the hostname must resolve to the wifi address, which is disabled.
    Monday, February 22, 2016 6:35 PM
              Have you tried disable NetBIOS over TCP/IP?
    Best Regards,
    Cartman
    Tuesday, February 23, 2016 1:00 AM
