Need Help for Ragged Filter in power bi RRS feed
  • Scenario:
    There are category which are as below
    1. Category1 – All the Category2, Category3, Category4 are grouped under the Category1.
    2. Category2– Category2 is group  of  Category3 based on location
    3. Category3– Category3 is combination of the multiple Category4.
    4. Category4 – Category4 is basically containing similar client project.
    There is People Table which contains all the data of the Employee.
    Every employee is mapped Category4, in-turn Category4 is mapped to the Category3, Category2
    There are other tables which directly has the data for the all Category3, Category4 details where I am using the master which contains all the Category3 and Category4 details. Only problem is in the People Tab. The filter from the Home tab should filter the data into the People tab, hence need to use same filter globally.
    Below is the table structure for the Employee table.
    Emp ID
    Emp Name
    Category4
    Category4 ID
    Category3 ID
    1
    A
    India AZ
    001
    00023
    2
    B
    India PQ
    0034
    009
    3
    C
    India AZ Power
    001
    00023
    Also there is a master table which contains all the space details:
    Category4 ID
    Category4
    Category3
    Category3 ID
    Category1
    Location
    1
    India AZ
    All India AZ
    00023
    All India Category1
    Pune
    2
    India PQ
    All India PQ
    009
    All India Category1
    Delhi
    2
    India PQ
    All India PQ
    009
    All India Category1
    Pune
    Requirement for the Category3 Report:
    The requirement is I need a dropdown with all the Category4 and Category3 into the Category4
    So my dropdown will contain All India AZ, All India PQ, India PQ, India AZ
    When I click on the All India AZ the above data should give me the result of Employee A and C
    When I click on India AZ I should get record of A and so on.
    Requirement for the Category1 Report:
    In the Category1 Report I have dropdown which contains All India Category1, All India Category1-Delhi, All India Category1- Pune.
    When I click on the All India Category1 Report this should show all the employees from the Category1 India currently they don’t have other country location which they are planning to make this report go globally.
    When I click on the All the employees belonging to the Pune location will be seen and same is for the delhi region
    Solution Tried so far:
    1.  Created ragged hierarchy using the Path DAX function and used the Hierarchy slicer, this give the result but there are some limitations the filter cannot be shared accros the pages(Syncing of the filter with the other pages), the Hierarchy filter is only available in the list form and not in the dropdown where as these people require the same into the dropdown.
    2. Created groups in power bi which include all the space under it but it only gives the name of Super Space and not the space names in the Power BI.I tried duplicating the entire set of Space Records so that I can keep that as separate group, but this give problem in creating the relation ship as we need unique records for creating relationship.
    Shraddha
    • Edited by Shraddha_B Thursday, August 23, 2018 6:53 AM
    Thursday, August 23, 2018 6:51 AM
