zune code 10 problem, plz help vista home premium/usb rollup update problem RRS feed
    ok so this is my problem
    i got a zune and installed everything right
    and then i plug the zune in and i get no response except the "dun duh" sound windows makes
    and the device manager tells me code 10
    i downloaded the rollup usb update, and it wont install it, says it doesnt apply to my system
    so, any help would be much appreciated
    thanks
    Saturday, January 12, 2008 7:03 AM
    This behavior occurs when one of the following conditions is true: .
    • The computer does not detect the Zune device.
    • The incorrect drivers are installed for the Zune device.
    • Non-standard drivers are installed for the USB Controller on the computer.
    Please first Update to the current version of the Zune software. To obtain version 1.2 or a later version, download and install the Zune Setup package from the following Zune Web site:
    How to update your Zune device
    http://support.microsoft.com/kb/926770/en-us
    Meanwhile, for more help, please contact Zune support:
    Top Issues
    http://www.zune.net/en-US/support/topissues.htm
    Top Support Links
    http://forums.zune.net/7171/ShowPost.aspx
    zune forums home /search
    http://forums.zune.net/default.aspx?ForumGroupID=3
    By the way, there are 32-bit versions and 64-bit versions for the rollup USB update, please be carefull before installation.
    Cumulative update rollup for USB core components in Windows Vista
    http://support.microsoft.com/kb/941600/en-us
    Hope this helps.
    Sincerely,
    Robbin Meng
    Microsoft Online Community Support
    Tuesday, January 15, 2008 8:59 AM
    Hi,
    As this thread has been quiet for a while, we assume that the issue has been resolved. At this time, we will mark it as ‘Answered’ as the previous steps should be helpful for many similar scenarios.
    If the issue still persists and you want to return to this question, please reply this post directly so we will be notified to follow it up. You can also choose to unmark the answer as you wish.
    In addition, we’d love to hear your feedback about the solution. By sharing your experience you can help other community members facing similar problems.
    Thanks!
    Sincerely,
    Robbin Meng
    Tuesday, January 22, 2008 3:27 AM
  • This issue is not resolved. I have installed, reinstalled, unzooned everything and still get code 10 when I install.
    I was under warranty and sent it to Microsoft, recieved a replacement zune and the same thing happens!
    The zune syncs and functions perfectly on my friends laptop (XP SP2)...
    Saturday, August 23, 2008 5:05 PM
