Hi,
I am getting following error when updating multiple custom fields for the project using CSOM. (Project Server 2013)
Note: The error is occurring only when I update the project for first time. Second time onwards, I don't find error.
Environment - Multi server farm (1 app, 1 web & 1 DB server)
It is annoying for entire bulk update process.
WaitForJob method exception - PJClientCallableException: GeneralQueueCorrelationBlocked GeneralQueueCorrelationBlocked
CorrelationUID = f2f0f32e-444d-4e1f-9607-2158d394cafd
JobUID = b3ec66fe-036a-e611-a2ea-005056920dba
JobType = ProjectUpdate.
Here is my code
// Load all projects from project context
projContext.Load(projContext.Projects);
projContext.ExecuteQuery();
// Find and return required project
PublishedProject pubProject = projContext.Projects.Where(proj => proj.Name.Equals(projName, StringComparison.OrdinalIgnoreCase)).FirstOrDefault();
// Load project custom fields
projContext.Load(pubProject.CustomFields);
// Include all custom fields from project
projContext.Load(pubProject.IncludeCustomFields);
QueueJob qJob = projContext.Projects.Update();
if (pubProject.IsCheckedOut == false)
// Create draft project and check out before updating project
DraftProject projectDraft = pubProject.CheckOut();
// Update project decription
if (!string.IsNullOrEmpty(projDesc))
{projectDraft.Description = projDesc.Trim();
qJob = projectDraft.Update();
// Update project sponsor
if (!string.IsNullOrEmpty(projSponsor))
{ projectDraft.SetCustomFieldValue(fldSponsorInt, projSponsor.Trim());
// Update project PMO Oversight
if (!string.IsNullOrEmpty(projPMO))
{ projectDraft.SetCustomFieldValue(fldPMOOversightInt, projPMO.Trim());
if (WaitForJob(projContext, qJob))
qJob = projectDraft.Publish(true);
queue job method
private static bool WaitForJob(ProjectContext projContext, QueueJob job)
bool result = false;
try
JobState jobState = projContext.WaitForQueue(job, int.MaxValue);
if(jobState == JobState.Success)
result = true;
else
LoggingService.LogMessageToLocalFile("WaitForJob method job state - " + jobState.ToString());
catch (ServerException ex)
result = false;
return result;
Thanks
Mohan
vamsi
