Power shell help RRS feed
  • am new to power shell please help me to create a power shell code for the below xml file
    <Configuration>
    <SiteUrl>http://...</SiteUrl>
    <lists>
    <List Name="Issues" Versioning="true">
     <columnToAdd ColumnName="% Complete" Type ="Number" ViewName="All Items"/>
     <columnToAdd ColumnName="Actual Work" Type ="Number" ViewName="All Items"/>
    </List>
    <List Name="Risks" Versioning="true">
     <columnToAdd ColumnName="Callback Number" Type ="Single line of text" ViewName="All Items"/>
     <columnToAdd ColumnName="Contact Name" Type ="Single line of text" ViewName="All Items"/>
    </List>
    </lists>
    <libraries>
    <LibraryName>Meeting Notes</LibraryName>
    <LibraryName>Project Documents</LibraryName>
    </libraries>
    </Configuration>
    Tuesday, April 9, 2013 1:27 PM
  • two questions:
    1. what have you got so far?
    2. what is it that you want your script to do to or with this xml file?
    assuming you have nothing and want a script to delete the xml file, I'd suggest you try this:
        remove-item ./myxmflfile.xml
    Al Dunbar -- remember to 'mark or propose as answer' or 'vote as helpful' as appropriate.
    Tuesday, April 9, 2013 3:05 PM
  • Hi Dunbar,
    In a share point site I want the below operations with the help of power shell code and am taking the site URL and the below fields in the above XML file :
    •  taken two List names:1)Issues.2)Risks for both the lists I want the versioning to be true.
    •  i.e. :List Name="Issues" Versioning="true">
      for the ISSUE list I want to add two column names "% complete" "Actual work", set the type to "Number" and add to "All Items" view.
    • And for RISK list I want to add two column names "Callback Number" "Contact Name" ,set the type to "Number" .
    The Below is the sample code that I tried.
    Param(
      [Parameter(Mandatory=$True,Position=1)]
       [string]$configFile
    [xml]$config = Get-Content $configFile
    $lists=$config.Configuration.lists.List
    $columnToAdd=$config.Configuration.lists.List[0].columnToAdd
    $columnToAdd=$config.Configuration.lists.List[1].columnToAdd
    $siteurl = $config.Configuration.SiteUrl
    $ViewName=$config.Configuration.lists.List[0].columnToAdd[0].ViewName
    $ColumnName=$config.Configuration.lists.List[0].columnToAdd[0].ColumnName
    $site = Get-SPSite $siteurl
    $web = $site.AllWebs
    $Lst=$web.lists[$List[0].Name]
    foreach($subsite in $web)
    Please help me to get the code for the problem.
    Thanks
    Tuesday, April 9, 2013 4:42 PM
  • sorry, but XML and sharepoint are two areas where I lack experience. in addition, I still do not understand what you expect to result from this.
    Tuesday, April 9, 2013 8:40 PM
  • Am new to power shell please help me to write power shell code for the below xml file
     <Configuration>
     <lists>
     </List>
     </List>
     </lists>
     <libraries>
     </libraries>
     </Configuration>
    •And for RISK list I want to add two column names "Callback Number" "Contact Name" ,set the type to "Number" .
    Param(
       [string]$configFile
    • Merged by Yan Li_ Friday, April 12, 2013 6:41 AM
    Wednesday, April 10, 2013 3:45 AM
    If you are looking for powershell methods to work with XML files, then I would like to suggest you refer below articles:
    Use PowerShell to Simplify Access to XML Data
    http://blogs.technet.com/b/heyscriptingguy/archive/2012/09/13/use-powershell-to-simplify-access-to-xml-data.aspx
    The Scripting Wife Learns to Use PowerShell to Work with XML
    http://blogs.technet.com/b/heyscriptingguy/archive/2012/03/25/the-scripting-wife-learns-to-use-powershell-to-work-with-xml.aspx
    Regards,
    Yan Li
    Cataleya Li
    TechNet Community Support
    • Proposed as answer by Yan Li_ Monday, April 15, 2013 2:17 AM
    • Marked as answer by Yan Li_ Tuesday, April 16, 2013 1:45 AM
    Friday, April 12, 2013 5:16 AM
