Need convert txt to csv using Power shell with headers RRS feed
  • Hi All ,
    Can we convert below txt file to csv format added at the end ??
    file1 :
    IP Address: 192.168.1.1
    Hostname: 01-any1TEST
    Event Message: Ping
    Alert Status: Down at least 3 min
    Event Time: 17:25:14
    Alert Type: :Windows 2012 Server
    IP Address: 192.168.1.2
    Hostname: 02-any2TEST
    Event Message: Ping
    Alert Status: Down at least 4 min
    Event Time: 17:25:40
    Alert Type: :Unix Server
    IP Address: 192.168.1.3
    Hostname: 03-any3TEST
    Event Message: Ping
    Event Time: 17:26:21
    Alert Type: :windows host
    Csv file output required as below :
    'IP Address','Hostname','Event Message','Alert Status','Event Time','Alert Type'
    '192.168.1.1','01-any1TEST','Ping','Down at least 3 min','17:26:21','Windows 2012 Server '
    '192.168.1.2','02-any2TEST','Ping','Down at least 3 min','17:26:21','unix host '
    '192.168.1.3','03-any3TEST','Ping','Down at least 3 min','17:26:21','windows host '
    Friday, July 28, 2017 11:35 AM
  • Here's a way that works in pre-PowerShell 5 (if required):
    $delimeterPattern = '^--'
    $recordPattern = '^([^:]+): (.+)'
    $logContent = Get-Content "testlog.txt"
    # how many lines in a record?
    $recordLines = ($logContent | Select-String $delimeterPattern |
      Select-Object -First 1).LineNumber
    for ( $i = 0; $i -lt $logContent.Count; $i += $recordLines ) {
      $output = New-Object PSObject
      for ( $j = $i; $j -lt $i + $recordLines; $j++ ) {
        $logContent[$j] | Select-String $recordPattern | ForEach-Object {
          $output | Add-Member NoteProperty $_.Matches[0].Groups[1].Value $_.Matches[0].Groups[2].Value
      $output
    Duplicate question from here:
    http://stackoverflow.com/q/45372781/
    -- Bill Stewart [Bill_Stewart]
    Monday, July 31, 2017 3:12 PM
  • Hi All ,
    Yes. That's easily possible. But first you should read the following post from the top of the list of this forum:
    This forum is for scripting questions rather than script requests
    Grüße - Best regards
    PS:> (79,108,97,102|%{[char]$_})-join''
    Friday, July 28, 2017 11:51 AM
  • HI ,
    Sorry for earlier incomplete request . I already tried myself need corrections .
    $input = Get-Content -path "path\in.txt" | Select-String -List 'Alert Type','IP Address','Hostname','Event Message','Alert Status','Event Time'
    $data = $input[1..($input.Length - 1)]
    $maxLength = 0
    $objects = ForEach($record in $data) {
        $split = $record -split "\s{2,}|\t+"
        If($split.Length -gt $maxLength){
            $maxLength = $split.Length
        $props = @{}
        For($i=0; $i -lt $split.Length; $i++) {
            $props.Add([String]($i+1),$split[$i])
        New-Object -TypeName PSObject -Property $props
    $headers = [String[]](0..$maxLength)
    $headers1 = [String[]]('MachineType','EventTime','HostName','IPAddress','AlertMessage','Severity','AlertType','AlertStatus')
    $objects |
    Select-Object $headers |
    Export-Csv -NoTypeInformation -Path "path\out.csv"
    Friday, July 28, 2017 12:57 PM
  • So I learned somthing new today from Tobias .... again. Thanks James for the recommendation! ;-)
    You could try it like this:
    $Template = @'
    IP Address: {IPAddress*:192.168.1.1}
    Hostname: {HostName:01-any1TEST}
    Event Message: {EventMessage:Ping}
    Alert Status: {AlertStatus:Down at least 3 min}
    Event Time: {EventTime:17\:25\:14}
    Alert Type: :{AlertType:Windows 2012 Server}
    IP Address: {IPAddress*:192.168.1.2}
    Hostname: {HostName:02-any2TEST}
    Alert Status: {AlertStatus:Down at least 4 min}
    Event Time: {EventTime:17\:25\:40}
    Alert Type: :{AlertType:Unix Server}
    IP Address: {IPAddress*:192.168.1.3}
    Hostname: {HostName:03-any3TEST}
    Event Time: {EventTime:17\:26\:21}
    Alert Type: :{AlertType:windows host}
    Get-Content -Path 'path\in.txt' |
        ConvertFrom-String -TemplateContent $Template |
            Out-GridView
    Saturday, July 29, 2017 1:06 AM
      $output
