Need help with using the IIF Function in MS Project RRS feed
  • Hello,
    I am attempting to write the following formula but having an issue with the syntax and which relational operator is required to make it successful.
    I need to do the following:
    • If [Date1] is less then or equal to DateValue "12/31/2018", add [Number1] and [Number2] than divide it by 4.
    • If [Date1] is more then DateValue"12/31/2018, And if [Number4] *[number5] is less then 0, return "0", otherwise return [Number4]*[Number5]
    I wrote this formula but it is incorrect and I an having a difficult time determining where the errors are:
    IIf ([Date1] <= DateValue(“12/31/2018”), [Number1] +[Numberr2]/4,  IIF([Date1] > DateValue(“12/31/2018”), IIF(AND[Number4] * [Number5] < 0, "0",([Number4] * [Number5])))
    Thank you,
    KR
    Thursday, April 5, 2018 3:59 PM
  • KR,
    Please don't cross-post. Didn't I already answer this question for you on the Answers forum? Answer, yes I did.
    John
    Thursday, April 5, 2018 4:58 PM
