Answered by:
please help! blue screen crash NV4_disp problem with file device driver stuck in an infinate loop
Hi I hope someone can help me with this one because i am confused the message i keep receiving is on the version windows xp SP3 pro. The symptoms are what ever i am doing after a while the screen freezes and arrow freezes can not bring up task manager no buttons work have to totally shut down with power off button. then reboot. unless it crashes and it reboots itself then i get a blue screen which says The device driver is stuck in an infinate loop the problem file is NV4_disp there are error codes after but not been able to catch them. it will reboot and work ok for a while then crash again. I have looked on the error log and have found the same entries repeatedly from July 2011 leading up to the first crash at the beginning of December 2011 they are ESENT 490,470,439,454,494. Then I have had also Loadperf 3011 in Aug 2011. Then Application error 1000 in october 2011. then netruntime optimization error 1103 indicating shutdown. from november 2011 this entry has come up about 3 times up to now it crashed again yesterday and the last error codes i have is for then and they were esent again 470,490,439,494,454.
Any advice would be great the problem really seemed to get going when i installed samsung kies then uninstalled it. it slowed my system to a virtual standstill and wouldnt work anyway so i got rid of it i know i have not much memory but i deleted tons of stuff pics etc to make way for it but it was still rubbish. now my computer is running much slower than it use to and is always crashing with the blue screen as stated above.
I know it is alot of info but i have put the error messages below to show in more detail the problems that have been occuring thank you all in advance but be assured your help will be greatly appreciated thankyou
please help very confused Maria x
11 August 2011
LoadPerf
The performance counter name string value in the registry is incorrectly formatted. The bogus string is 11478, the bogus index value is the first DWORD in Data section while the last valid index values are the second and third DWORD in Data section.
11 August 2011
LoadPerf
Unloading the performance counter strings for service ServiceModelEndpoint 4.0.0.0 (ServiceModelEndpoint 4.0.0.0) failed. The Error code is the first DWORD in Data section.
The above entries in bold are repeated many times
11 August 2011
ESENT
Catalog Database (1028) Unable to write a shadowed header for file C:\WINDOWS\system32\CatRoot2\{ F750E6C3-38EE-11D1-85E5-00C04F C295EE}\catdb. Error -1032.
11 August 2011
ESENT
Catalog Database (1028) Database C:\WINDOWS\system32\CatRoot2\{ F750E6C3-38EE-11D1-85E5-00C04F C295EE}\catdb is partially attached. Attachment stage: 1. Error: -1032.
11 August 2011
ESENT
Catalog Database (1028) Database recovery failed with error -1216 because it encountered references to a database, 'C:\WINDOWS\system32\CatRoot2\ {F750E6C3-38EE-11D1-85E5-00C04 FC295EE}\catdb', which is no longer present. The database was not brought to a consistent state before it was removed (or possibly moved or renamed). The database engine will not permit recovery to complete for this instance until the missing database is re-instated. If the database is truly no longer available and no longer required, please contact PSS for further instructions regarding the steps required in order to allow recovery to proceed without this database.
11 August 2011
ESENT
Catalog Database (1028) Database recovery/restore failed with unexpected error -1216.
11 August 2011
.NET Runtime Optimizati on Service
.NET Runtime Optimization Service (clr_optimization_v2.0.50727_3 2) - Tried to start a service that wasn't the latest version of CLR Optimization service. Will shutdown
07 September 2011
ESENT
svchost (1008) An attempt to open the file "C:\WINDOWS\system32\CatRoot2\ {F750E6C3-38EE-11D1-85E5-00C04 FC295EE}\catdb" for read / write access failed with system error 32 (0x00000020): "The process cannot access the file because it is being used by another process. ". The open file operation will fail with error -1032 (0xfffffbf8).
07 September 2011
ESENT
Catalog Database (1008) Unable to write a shadowed header for file C:\WINDOWS\system32\CatRoot2\{ F750E6C3-38EE-11D1-85E5-00C04F C295EE}\catdb. Error -1032.
07 September 2011
ESENT
Catalog Database (1008) Database recovery/restore failed with unexpected error -1032.
07 September 2011
ESENT
svchost (1008) An attempt to open the file "C:\WINDOWS\system32\CatRoot2\ {127D0A1D-4EF2-11D1-8608-00C04 FC295EE}\catdb" for read / write access failed with system error 32 (0x00000020): "The process cannot access the file because it is being used by another process. ". The open file operation will fail with error -1032 (0xfffffbf8).
07 September 2011
ESENT
svchost (1008) An attempt to delete the file "C:\WINDOWS\system32\CatRoot2\ {127D0A1D-4EF2-11D1-8608-00C04 FC295EE}\catdb" failed with system error 5 (0x00000005): "Access is denied. ". The delete file operation will fail with error -1032 (0xfffffbf8).
13 September 2011
ESENT
13 September 2011
ESENT
Catalog Database (1008) Database C:\WINDOWS\system32\CatRoot2\{ F750E6C3-38EE-11D1-85E5-00C04F C295EE}\catdb is partially attached. Attachment stage: 3. Error: -1032.
14 September 2011
ESENT
Catalog Database (1008) Database recovery failed with error -1216 because it encountered references to a database, 'C:\WINDOWS\system32\CatRoot2\ {F750E6C3-38EE-11D1-85E5-00C04 FC295EE}\catdb', which is no longer present. The database was not brought to a consistent state before it was removed (or possibly moved or renamed). The database engine will not permit recovery to complete for this instance until the missing database is re-instated. If the database is truly no longer available and no longer required, please contact PSS for further instructions regarding the steps required in order to allow recovery to proceed without this database.
The above entries are repeated many times
18 December 2011
Windows Update Agent
Installation Failure: Windows failed to install the following update with error 0x80070643: Windows Search 4.0 for Windows XP (KB940157).
18 December 2011
Installation Failure: Windows failed to install the following update with error 0x8007f070: Windows PowerShell 2.0 and WinRM 2.0 for Windows XP and Windows Embedded (KB968930).
18 December 2011
DCOM
DCOM got error "%1058" attempting to start the service WSearch with arguments "" in order to run the server: {7D096C5F-AC08-4F1F-B EB7-5C22C517CE39}
20 December 2011
Tcpip
The system detected an address conflict for IP address 192.168.1.2 with the system having network hardware address 70:D4:F2:EA:C9:2A. Network operations on this system may be disrupted as a result.
20 December 2011
Dhcp
The IP address lease 192.168.1.2 for the Network Card with network address 00C90002A576 has been denied by the DHCP server 192.168.1.1 (The DHCP Server sent a DHCPNACK message)
30 December 2011
W32Time
Time Provider NtpClient: An error occurred during DNS lookup of the manually configured peer 'time.windows.com,0x1'. NtpClient will try the DNS lookup again in 15 minutes. The error was: A socket operation was attempted to an unreachable host. (0x80072751)
30 December 2011
W32Time
The time provider NtpClient is configured to acquire time from one or more time sources, however none of the sources are currently accessible. No attempt to contact a source will be made for 14 minutes. NtpClient has no source of accurate time.
04 January 2012
DCOM
DCOM got error "%1084" attempting to start the service netman with arguments "" in order to run the server: {BA126AE5-2166-11D1-B 1D0-00805FC1270E}
04 January 2012
Service Control Manager
The DHCP Client service depends on the NetBios over Tcpip service which failed to start because of the following error: A device attached to the system is not functioning.
04 January 2012
The DNS Client service depends on the TCP/IP Protocol Driver service which failed to start because of the following error: A device attached to the system is not functioning.
04 January 2012
The TCP/IP NetBIOS Helper service depends on the AFD service which failed to start because of the following error: A device attached to the system is not functioning.
04 January 2012
The IPSEC Services service depends on the IPSEC driver service which failed to start because of the following error: A device attached to the system is not functioning.
04 January 2012
The following boot-start or system-start driver(s) failed to load: AFD AmdK7 AvgLdx86 AvgMfx 86 AvgTdiX Fips IPSec MRxS mb NetBIOS NetBT RapportKEL L RasAcd Rdbss Tcpip
04 January 2012
DCOM
DCOM got error "%1084" attempting to start the service EventSystem with arguments "" in order to run the server: {1BE1F766-5536-11D1-B 726-00C04FB926AF}
04 January 2012
Dhcp
The IP address lease 192.168.1.6 for the Network Card with network address 00C90002A576 has been denied by the DHCP server 192.168.1.1 (The DHCP Server sent a DHCPNACK message).
09 January 2012
DCOM
The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID {BA126AD1-2166-11D1-B1D0-008 05FC1270E} to the user NT AUTHORITY\NETWORK SERVICE SID (S-1-5-20). This security permission can be modified using the Component Services administrative tool.
- Edited by maria40 Tuesday, January 10, 2012 6:24 PM added info
Tuesday, January 10, 2012 6:18 PM
Clearly notes that , while you install some updates this problem persists. Uninstall the updates from
Start >> Control panel >> Add or Remove programs
Generally updates starting with KB create a problem.
Prateek Dixit Windows Vista Desktop Administrator. Microsoft Certified Technology Specialist www.thetechnoclub.com www.seoexceed.com- Proposed as answer by Prateekttc Wednesday, January 11, 2012 1:13 PM
- Marked as answer by arnavsharmaEditor Wednesday, July 10, 2013 10:15 AM
Wednesday, January 11, 2012 1:13 PM -
Hi Prateektt
thank you for your reply and apologise for not aknowledging it but the computer has been a pain.
if i uninstall all the updates begining with KBwhat will happen? and if i do do i have to install them all again to make windows work properly. Sorry still confused? I am a bit dippy takes me a while to get my head round things.lol!
thankyou for your advice maria
tracie hargravesTuesday, January 17, 2012 3:53 AM -
Hi Prateektt
tracie hargraves
Hello,Generally the problem persists with the help of KB updates.. Windows will work properly if u uninstall them..
Go ahead.
Cheers
Prateek Dixit | Windows Vista Desktop Administrator. | Microsoft Certified Technology Specialist | www.thetechnoclub.com | www.seoexceed.comWednesday, January 18, 2012 6:52 AM -
Hi Prateek
sorry i have been trying to get back to you with a reply but computer still crashin afte i did what you said. i now have a error blue screen showing driver irql not less or equal and many error codes including (0x0000007F), (0x00000000), (0x000000080, (0x80042000),(0x000000D1),(0x00000061), (0x000000FF),0x000000001), (0X82153446). that is just the most recent if i put them all up would that help at all thankyou for your help so far it is appreciated .
tracie hargraves
Monday, February 20, 2012 4:10 AM
