Hello,
There are several way you can do this, unfortunately all will need some form of custom development. Get the data is every easy, you can query the Reporting database and surface that data either via SSRS, custom web part, excel service etc. The issue you
will have is finding a way to filter the dataset for that particular Project Site. If you want to go down the SSRS route you could try this web part:
http://gallery.technet.microsoft.com/projectserver/Report-Viewer-webpart-439e0062
The best solution would be a custom web part but that would require custom dev with VS.
Paul
Paul Mather | Twitter |
http://pwmather.wordpress.com | CPS
