Problem with KB4015553 RRS feed
  • Hello all. I need a help, to uninstall update KB4015553 on my Windows Server 2012 R2 Datacenter.
    My story:
    Got Hyper-V virtual machine with 2012 r2 DC on a board. Main role of the server is oracle 12 database hosting.
    After installing update KB4015553 (at 22 april), my VM get stucked every 24-36h. Server had ping but will not remote in it, and all databases dont response too. I tried to hard reboot it by hyper-v console, and its help but just for next 36 hours.
    The main issue, that I cant uninstall this update! Got this errors in logs:
    Package KB4015553 failed to be changed to the Absent state. Status: 0x800f081f.
    if i try unistall it from cmd, got this:
    Windows update "Update for Microsoft Windows (KB4015553)" could not be uninstalled because of error 2148468767 "" (Command line: "wusa  /uninstall /kb:4015553")
    Ask for a help with this.
    Tuesday, May 2, 2017 6:58 AM
  • same Problem
    Fix for us:
    DISM /Online /Cleanup-Image /StartComponentCleanup
    DISM.exe /Online /Remove-Package /PackageName:Package_for_RollupFix~31bf3856ad364e35~amd64~~9600.18655.1.4
    reboot
    BTW: Correct Package name is "Package_for_RollupFix~31bf3856ad364e35~amd64~~9600.18655.1.4" not
    "Package_1528_for_KB4015553~31bf3856ad364e35~amd64~~6.3.1.4"
    best regards
    Jannick
    • Edited by Jannick W Saturday, May 6, 2017 7:28 PM
    • Proposed as answer by Igor, B Sunday, May 7, 2017 4:32 PM
    • Marked as answer by vasiliy klyuyev Thursday, May 18, 2017 9:20 AM
    Saturday, May 6, 2017 7:26 PM
  • Hi vasiliy klyuyev,
    Please check if you could use dism command to uninstall the update?
    https://technet.microsoft.com/en-us/library/hh825265.aspx
    Best Regards,
    Anne
    Friday, May 5, 2017 5:12 AM
  • C:\Windows\system32>Dism /Online /Remove-Package /PackageName:Package_1528_for_K
    Deployment Image Servicing and Management tool
    Version: 6.3.9600.17031
    Image Version: 6.3.9600.17031
    Processing 1 of 1 - An error occurred - Package_1528_for_KB4015553 Error: 0x8007
    0005
    Error: 5
    Access is denied.
    The DISM log file can be found at C:\Windows\Logs\DISM\dism.log
    Friday, May 5, 2017 5:23 AM
  • same Problem
    Fix for us:
    reboot
    best regards
    Jannick
  • Thanks!!
    Monday, May 8, 2017 7:26 AM
  • Hi vasiliy klyeyev,
    If the above reply could be of help, you may mark useful ones as answer :)
    Best Regards,
    Anne
    Wednesday, May 10, 2017 3:25 AM
    I had the same problem. I just solved this, removing the update KB4015553.
    I have identified one more update in the same period of this, the KB4014551, I have not yet removed it. It seems that my environment is still unstable.
    Anyone knows if the Microsoft pronounced some hotfix?
    Tuesday, May 23, 2017 12:08 PM
  • Check out several Reddit threads that have reported problems with iSCSI targets and Microsoft  patch KB4019215.
    https://www.reddit.com/r/sysadmin/comments/6bjtb1/ms_2012_r2_clusterfile_shares_serious_performance/
    One poster said his systems are fiber channel and not iSCSI.  Another poster said he thought that the NTFS was affected in this patch.
    A poster has reported the problem to Microsoft.
    Tuesday, May 23, 2017 6:31 PM
  • Also checkout this thread on SpiceWorks
    https://community.spiceworks.com/topic/1995507-smb-very-slow-after-running-windows-update?page=3
    Tuesday, May 23, 2017 8:37 PM
  • We found a bad connection iSCSI in my server.
    We have adjusted this and will wait if the symptom will occur again.
    Link to another discussion:
    https://www.reddit.com/r/sysadmin/comments/6cum10/headsup_2012_r2_servers_with_iscsi/
    Wednesday, May 24, 2017 11:47 AM
  • This problem also occurs for me with following updates that include the bug: kb4019215 and kb4019217
    This thread helped me remove that kb4015553 though. Thanks, marked as answer on that reply.
    Thursday, May 25, 2017 8:36 AM
  • I have the same problem. I need to remove update kb4019215 and  kb4019213?
    • Edited by hasky5126 Thursday, May 25, 2017 6:10 PM
    Thursday, May 25, 2017 6:08 PM
  • Check if you has the legacy iSCI connection. I solved my problem removing the iSCI Initiator from my server, what we not use.
    See this post:
    https://social.technet.microsoft.com/Forums/windowsserver/en-US/3d3b6470-5225-4e42-b273-1a6ead390144/kb4015553-and-kb4019215?forum=winserverwsus&prof=required
    If not, remove the update KB4019215 and KB4015553.
    Friday, May 26, 2017 11:51 AM
  • But I use iSCI Initiator.
    Tuesday, May 30, 2017 12:39 PM
