Problems with Red Hat Enterprise Linux 5.9, 5.8+LIS3.4 RRS feed
  • I have several Red Hat 5.8 and 5.9 VM's running on Server 2012 Hyper-V on a couple of different hardware platforms, all with LIS 3.4, all exhibiting the same issues:
    1. The VM's will not gracefully shut down when Shut Down... is selected from the Hyper-V manager. Instead they turn off - pretty bad for VM's file-systems, especially the ones running databases. This is supposed to work according the LIS release notes.
    2. The mouse on the console - ever though it works - it is way off from the "real mouse pointer. I don't see any hv_mouse module installed, instead hid_hyperv is installed which I am assuming handles all input devices. Also something advertised as working in the LIS release notes.
    3. Time keeping is a nightmare. The clock in the Red Hat VMs is all over the place and there is no hv_timesource module installed.
    Could anyone please provide any insight on how to address any of these issues?
    Thanks in advance.
    Tuesday, April 2, 2013 2:37 PM
  •  have several Red Hat  5.9 VM's . . ., all with LIS 3.4
    EL 5.9 contain _integrated_ support of Hyper-V
    Install LIS 3.4 on EL 5.9  -- is _error_ of sysadmin, as _minimum_ it is downgrade
    Monday, April 08, 2013 10:58 AM
     my problem is not only with 5.9 but with 5.8 also. And just to clarify, I am using LIS3.4 from Microsoft on 5.8 and the LIS included with the distribution on 5.9
    Ok . . .
     Please, rename this topic from
    Problems with LIS3.4 and Red Hat Enterprise Linux 5.8, 5.9
    to
    Problems with Red Hat Enterprise Linux both 5.9 and 5.8+LIS3.4
    April 12, 2013
    DoNe:
    {LIS3.4 and RHEL 5.8, 5.9} --} { 5.9 and 5.8+LIS3.4 }
     Thanks!
    > no see hv_mouse module . . . , instead hid_hyperv is installed
     Yes, in EL v5.9 "Hyper-V mouse driver" is hid_hyperv.ko  ( in fact  hid_hyperv.ko + hid_base_hv)
    In EL 6.4 mouse on Hyper-V work Super Ok
     In EL 5.9 mouse on Hyper-V work strange
    1:
    EL 5.9 2xMouse_Cursor 1-st cursor on [Applications]
     If go mouse up, after 1-5 pixel and 0.01 - 0.05 sec:
    EL 5.9 2xMouse_Cursor 1-st cursor go from [Applications] to Hyper-V buttons
    To JohnPapad: You describe this situation?
     P.S. Look like
    Bug 849544 - [Hyper-V pv drivers]Two mouse icons show up on the guest screen
    https://bugzilla.redhat.com/show_bug.cgi?id=849544
    • Edited by Victor Miasnikov Tuesday, April 23, 2013 6:13 AM DoNe {LIS3.4 and RHEL 5.8, 5.9} --} { 5.9 and 5.8+LIS3.4 }
    Monday, April 8, 2013 10:58 AM
  • Thanks for you reply but that does not answer any of my questions as my problem is not only with 5.9 but with 5.8 also. And just to clarify, I am using LIS3.4 from Microsoft on 5.8 and the LIS included with the distribution on 5.9
    Tuesday, April 9, 2013 4:46 PM
  • I have several Red Hat 5.9 VM's running on Server 2012 Hyper-V on a couple of different hardware platforms . . . :
    ----- Original Message -----
    To: "Victor Miasnikov"
    Cc: "KY Srinivasan"
    Sent: Monday, April 15, 2013 9:43 AM
    Subject: Re: 3) 2xMouse Cursor in RHEL 5.9 and 5.8+LIS3.4 ( on EL 6.4 -- Ok ) . . .
    There is a bug. Bug 903460 - use poweroff instead of shutdown in hv_util
    https://bugzilla.redhat.com/show_bug.cgi?id=903460
    > >>module installed.
    > >>issues?
    > > There is no hv_timesource. There is a time source.
    > > For RHEL5.9 i686 guest,
    > > please check the clocksource inside via system files.
    > > # cat /sys/devices/system/clocksource/clocksource0/current_clocksource
    > > For RHEL5.9 x86_64 guest,
    > > please check the clocksource inside via dmesg.
    > > # dmesg|grep time.c
    > > For RHEL6.4 both i686 and x86_64 guest,
    >  Can I forward this questions to http://social.technet.microsoft.com/Forums ?
    Yes, I think so.
    Monday, April 15, 2013 2:01 PM
