Best way to pull specific values out of Netsh using Powershell
    General discussion
    I am trying to pull the subnet and free addresses for each subnet from DHCP.  I was looking to use netsh to obtain the information and then pull this in to PS to manipulate, and before I go off down a tunnel it would be great if someone could advise the best approach to pulling back the specific info I am looking for.
    The command I am running to pull the info in to a variable is...
    $scopes = netsh dhcp server <specific dhcp server> show mibinfo
    The provides data similar to the following excerpt...
    MIBCounts:
            Discovers = 840.
            Offers = 474.
            Delayed Offers = 0.
            Requests = 498.
            Acks = 550.
            Naks = 0.
            Declines = 0.
            Releases = 466.
            ServerStartTime = 26 July 2012 14:29:40
            Scopes = 16.
            Scopes with Delay configured= 0.
            Subnet = 192.168.1.0.
                    No. of Addresses in use = 0.
                    No. of free Addresses = 2.
                    No. of pending offers = 0.
            Subnet = 192.168.2.0.
            Subnet = 192.168.3.0.
    I am not interested in the info at the start, just the IP subnets and the number of free addresses for each.
    Any help will be much appreciated.
    Kevin
    Thursday, July 26, 2012 6:39 PM
  • Like this?
    $scopes -match 'Subnet = |No\. of free Addresses = '
    [string](0..33|%{[char][int](46+("686552495351636652556262185355647068516270555358646562655775 0645570").substring(($_*2),2))})-replace " "
    Thursday, July 26, 2012 6:53 PM
  • The -match operator doesn't support regular expression options or multiple matching. But the [regex] type does. So if $a contains the netsh result, then:
    $m = [regex]::Matches($a, 'Subnet = ([0-9.]+)\..*?No. of free Addresses = (\d+)', [System.Text.RegularExpressions.RegexOptions]::Singleline)
    And $m.Count will tell you how many subnets are found. For each subnet $n in 0..($m.Count), $m[$n].Groups[1].Value is the IP and $m[$n].Groups[2].Value is the number remaining.
    To support IPv6 as well as IPv4 change "[0-9.]+" in the first capture to "[0-9A-B:.]+".
    Richard J Cox
    Sunday, July 29, 2012 9:30 AM
