Problem with installation of upgrade of Drivers for Realtek Speakers on my sysytem. RRS feed
  • Dear Sirs,
    Can"t upgrade drivers on my system though an update flashes for it. Is there any way this can be sorted by your team.
    Tuesday, May 21, 2019 9:53 AM
  • This forum is for Server OS deployment.
    For troubleshooting, you can look into Event Viewer, perhaps it will say something. Otherwise this may end up being a question for the manufacturer of your motherboard.
    Tuesday, May 21, 2019 4:56 PM
    Could you describe your problem in detail?
    Also you could Reinstall the driver.
    Right-click on the Realtek Audio Driver and select Uninstall, then follow the on-screen instructions to uninstall the driver.
    Restart your computer and open Device Manager again. In Device Manager, click Action > Scan for hardware changes.
    After that, install the driver again.
    Best regards,
    Farena
    Wednesday, May 22, 2019 8:24 AM
    Was your issue solved?
    If the reply helped you, please remember to mark it as an answer.
    If no, please reply and tell us the current situation in order to provide further help.
    Monday, May 27, 2019 7:32 AM
