strange networking share problem between xp and 7
    General discussion
  • the shared folder on windows 7 are working perfectly with most computers on the network,
    only one windows xp computers, when the shared folder stopped working, we have to restart windows 7 pro, then the shared folders back to work again.
    there two NIC CARD, I disable one, still the same problem,
    there is hidden wifi adaptor which no longer in use (unplugged),
    I checked all the settings on windows 7 pro: network discovery is on,
    turn on the file and printer sharing, ... all the setting are ready for xp sharing,
    and once I restart the win 7 pro, the problem is gone.
    but if the problem happened, without restart win 7, the xp never connect to win 7, it show some
    errors: is not accessible. you might not have permission to use this network resource
    On xp, I reset winsock, ip stack, check the local policy, none of them working,
    this afternoon, on xp machine, I turned off "Offline Files Client Side Cache "
    but at the same time I restart the win 7 , so I am not too sure if the "offline files client side cache" did the job or not.
    Thursday, April 06, 2017 7:12 PM
