Disk Offline in Hyper-V 2016 cluster after power drop out RRS feed
  • Hello, I have Hyper-V cluster 2016 2 node and after power drop out on both nodes are disk offline only whitnes quorum is online. All iSCSI connection are online on both nodes.If I try set to online:
    Set-Disk 4 -isOffline $false
    Set-Disk : The specified object is managed by the Microsoft Failover Clustering component. The disk must be in cluster
    maintenance mode and the cluster resource status must be online to perform this operation.
    Activity ID: {7cfaf3a0-f55a-48f8-966a-50d8c43752bc}
    At line:1 char:2
    +  Set-Disk 4 -isOffline $false
        + CategoryInfo          : NotSpecified: (StorageWMI:ROOT/Microsoft/..._StorageCmdlets) [Set-Disk], CimException
        + FullyQualifiedErrorId : StorageWMI 41018,Set-Disk
    In Cluster Manager is both node in state paused and disk offline. Turn On and Turn Off maintenance mode are grayed. How to bring disks to online state?
    Saturday, September 28, 2019 9:50 AM
    Since the disks are part of the Failover Cluster, you should use the Failover Cluster Manager PowerShell cmdlets, if you cannot do it within the GUI.
    Use the following cmdlets:
    Get-ClusterResource
    Use the above cmdlet to get all the available cluster resources, this helps you identify the disk.
    Start-ClusterResource
    Use the above cmdlet to set a cluster resource online.
    Example:
    Start-ClusterResource -Name "Cluster Disk 4"
    Best regards,
    Leon
    Blog: https://thesystemcenterblog.com LinkedIn:
    Saturday, September 28, 2019 11:19 AM
  • Cluster Resource say Offline. In Failover Cluster Manager is information about both nodes as "Pasused", Nic configration is Up for all ...
    Get-ClusterResource
    Name                                      State   OwnerGroup        ResourceType
    Cluster Disk 1                            Offline Available Storage Physical Disk
    Cluster Disk 2                            Online  Cluster Group     Physical Disk
    Cluster Disk 4                            Offline Available Storage Physical Disk
    Cluster IP Address                       Offline Cluster Group     IP Address
    Cluster Name                              Offline Cluster Group     Network Name
    Storage Qos Resource                      Offline Cluster Group     Storage QoS Policy Manager
    Virtual Machine Cluster WMI               Offline Cluster Group     Virtual Machine Cluster WMI
    Virtual Machine Configuration SQL-Server Offline SQL-Server        Virtual Machine Configuration
    Virtual Machine SQL-Server                Offline SQL-Server        Virtual Machine
    PS C:\Users\administrator.DOMAIN> Start-ClusterResource -Name "Cluster Disk 4"
    Start-ClusterResource : An error occurred while attempting to bring the resource 'Cluster Disk 4' online.
        The remote server has been paused or is in the process of being started
    At line:1 char:1
    + Start-ClusterResource -Name "Cluster Disk 4"
        + CategoryInfo          : ResourceBusy: (:) [Start-ClusterResource], ClusterCmdletException
        + FullyQualifiedErrorId : SharingPaused,Microsoft.FailoverClusters.PowerShell.StartClusterResourceCommand
    • Marked as answer by mdvorak72 Monday, October 7, 2019 7:20 AM
    • Unmarked as answer by mdvorak72 Monday, October 7, 2019 7:21 AM
    Tuesday, October 1, 2019 9:08 AM
  • Have you tried to bring both cluster nodes Online from the Paused state, then try to bring the cluster disks online?
    • Proposed as answer by Leon Laude Tuesday, October 1, 2019 10:08 AM
    Tuesday, October 1, 2019 9:11 AM
  • Yes, when I bring both node frome "Paused state to  > Resume > Fail Roles Back" then Start-ClusterResource -Name " .." work perfect. Thank you very much
    Tuesday, October 1, 2019 9:46 AM
  • Great! You’re welcome.
    (Please don’t forget to mark helpful replies as answer)
    Tuesday, October 1, 2019 9:47 AM
  • Hello,
    I'm Daniel, a technical support for Technet Forum.
    If the replies of forum users is helpful to your question, please take time out of your busy schedule to mark it as an answer, so that other users with the same question can quickly find it here.
    Really appreciated your contribution to Technet forum and understanding!
    Best Regards,
    Daniel
    Monday, October 7, 2019 6:25 AM
